Stucco Lathe Problem? - Page 2 - Masonry - Contractor Talk
Old 09-14-2012, 06:58 PM   #21
JBM's Avatar
Trade: Masonry
Rewards Points: 10,764
Re: Stucco Lathe Problem?
I was thinking of something witty to say about the stucco being rough on my rear end but came up with nothing lol.
JBM is offline
Old 09-15-2012, 10:49 AM   #22
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 474
He shouldn't have a problem with it if he knows how to run his trowel.
Usually on a gable end to save time, I will just tip the lath to run right up the soffit.
It is less important to get it going in the right direction than it is to make absolutely sure there are no bumps in it, or spans without enough fasteners.
NYCB is offline
Old 09-15-2012, 12:57 PM   #23
Mad Italian
TheItalian204's Avatar
Trade: Licensed Mason/Owner of small business
Rewards Points: 2,004
Originally Posted by Tscarborough
Acrylic stucco in shower = Fail.
Meh i did some installs six years ago.for designer...still zero moisture or water issues.
www.gabesmasonry.ca
Originally Posted by Mud Master View Post
I hate when a profitable job becomes a charitable write off.
TheItalian204 is offline
Old 09-16-2012, 12:35 PM   #24
Stone's Avatar
Trade: Stone Mason and Sculptor
Rewards Points: 93
Thin veneer stone manufacturers say to only nail into the framing. I usually do this but didn't on a current job and a building inspector called me on it. I had to do some fast talking to keep from tearing off 1200 square foot of lath and a few hundred of stone. It is hard not to have bumps when going over a 3/4 inch thick rainscreen drainage mat and only nailing into framing.
Stone is offline
Old 09-16-2012, 08:57 PM   #25
Mad Italian
How did they call you on it?
www.gabesmasonry.ca
Old 09-16-2012, 10:52 PM   #26
Stone's Avatar
Rewards Points: 93
The inspector initially called the builder, who called me in a panic. I have never had an inspector show any interest in exterior veneer work before but this office had seen some recent failures and were trying to get up to speed by reading the installation instructions online. I told them that nailing only into framing is a good idea but sometimes impractical and that the many failures I had seen were from lack of weather resistant barriers or kickout flashings or both, or generally poor workmanship. I also mentioned, as an example of ideal world versus real world, that every manufacturer calls for starting the stone 4 inches up from grade but most installers don't do that because it is unacceptable to the customers. I know that inspection of wall prep is happening in some areas with requirements to include drainage planes and weep systems, but I hadn't encountered it in my area before. No problem as long as I know what to expect and that everyone else has to follow the same rules.
Stone is offline
The Following User Says Thank You to Stone For This Useful Post:
TheItalian204 (09-17-2012)
metal halide lighting problem AustinDB Electrical 1 08-15-2008 04:20 PM
Problem with Bosch Table Saw arctic43 Tools & Equipment 3 06-24-2008 05:05 PM
Stone over stucco... ruskent Masonry 2 04-13-2008 05:12 PM
Stucco on block Jengle Masonry 9 03-22-2008 11:52 AM
Interior Stucco Fireplace Red Painting & Finish Work 2 05-21-2007 08:18 AM
