Stone Veneer In Cold Weather - Masonry - Contractor Talk
Old 12-30-2012, 12:21 PM   #1
deck aficionado
SelectDecks's Avatar
Trade: General Building
Rewards Points: 973
Quick question for you masons...I'm a deck guy so pardon my lack of knowledge on the subject
I need to apply some stone veneer to a couple colums made of concrete block (new block, not painted etc). Typically we would simply apply the 'stone' directly to the block w/o any barrier, mesh, etc but I'm not quite sure how I should approach it with the cold weather setting in - consistently in the 30's here now
My originial plan was to just add some accelerator to the type S but I don't want to do that only to find out it's not going to get the job done...so I thought I would hop on here and look for some expert advice.
Appreciate any help you can throw my way - thanks
James
www.selectdecks.com
SelectDecks is offline
Old 12-30-2012, 02:21 PM   #2
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Stone Veneer In Cold Weather
30's, that's right around freezing huh? I'd heat the pillars before install Say with a tiger torch or by placing a heater beside them while getting prepped,( gotta get the frost off them and get them warm right through,) and use mortar mixed with hot/warm water. After install I'd wrap the pillars with an insulated tarp. Should be fine. I don't like accelerators and no specs I've ever seen have allowed them to be used. If you can put a small electric heater under the tarp as well.
www.dominionmasonry.ca
dom-mas is offline
Old 12-30-2012, 02:34 PM   #3
Stone's Avatar
Trade: Stone Mason and Sculptor
Rewards Points: 93
I assume you are talking about applying manufactured thin veneer. Warm your sand and warm your water, and use a good non-chloride accelerator such as Accelguard 80. Work when it is in the 30's and rising or tent everything in and heat the space. Idealy don't grout joints much after noon and cover things up at the end of the day. A propane salamander heater blowing on the work or sometimes a big torch can speed things up. Winter sucks!
Stone is offline
Old 12-30-2012, 02:52 PM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 8,996
Im doing a thin stone chimney right now, my weather clock says low of 5 the next day or 2. We have a tent, heater running all day and night. For 30;s eh, just use warm material, admix, and heat it over night. 30 is pretty warm still lol.
JBM is offline
Old 12-31-2012, 10:27 AM   #5
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 156
If it's just a few small columns, I'd build a small enclosure, use a little electric heat inside, and move it around each column as needed. You don't necessarily need concrete-specific insulating blankets, even old blankets/comforters from the bedroom will suffice.........
jomama is offline
Old 01-02-2013, 10:27 AM   #6
deck aficionado
Rewards Points: 973
appreciate the info guys
James
www.selectdecks.com
Old 01-13-2013, 11:53 PM   #7
stonebuilder's Avatar
Trade: masonry
Rewards Points: 115
We build a tent and use propane heaters just a day time, works great for me
stonebuilder is offline
Old 01-14-2013, 10:34 AM   #8
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
We've been lucky this winter with moderate temps. 20*s some nights.
Typically we build a tent, run a kero heater during the day and blanket and run a small box heater at night. I bring a barrel of hot water from my house and double blanket the sand.
Hate any additives and only use them as a last resort. If it's any kind a nice finish work I never use them.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 01-14-2013, 03:21 PM   #9
JBM's Avatar
Trade: Masonry
Hey Karl, if you put one of those little square heaters in what used to be the fire barrel it will keep the sand warm even down to 0. There has to be some room for the air to circulate, so we just put a pallet on each side, or something. We keep the water in there too, it never freezes. Thats assuming the job has power.
JBM is offline
Natural Stone Veneer Around Windows euphoricme Masonry 17 06-17-2012 08:49 PM
Pavers in cold weather loumatt Landscaping 13 02-26-2011 10:45 PM
Makita LXT and Cold Weather HandyHails Tools & Equipment 56 01-02-2011 09:11 PM
Best sealant for vinyl replacement windows in cold weather remster General Discussion 4 01-19-2010 10:53 PM
Working in the cold weather Cjeff General Discussion 18 12-19-2009 11:03 AM
