Stone Chimney Tuckpoint - Masonry - Contractor Talk
Old 05-05-2016, 08:04 AM   #1
wazez's Avatar
Trade: masonry
Rewards Points: 784
I had someone call me about this " in her words beautiful chimney" they uncovered after a house fire. I haven't been there but these are the pics she sent me.
I can't see it on my phone but she says it will need repair to be left exposed on two sides.
I don't get into a whole lot of stone work so I'm wondering does this have a chance at looking good?
Stone chimney tuckpoint-1462453067164.jpg   Stone chimney tuckpoint-1462453096896.jpg
wazez is offline
Old 05-05-2016, 09:27 AM   #2
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
Re: Stone Chimney Tuckpoint
I think so. We don't do alot of river rock around here, but I think thats a good looking chimney.
brickhook is offline
Old 05-05-2016, 09:33 AM   #3
brickhook's Avatar
Trade: masonry
I don't see any damage in the photos that needs to be repaired...
Old 05-05-2016, 02:38 PM   #4
wazez's Avatar
Trade: masonry
Rewards Points: 784
Yeah I don't see any damage either. ..not sure if I even should go look at it. I'm afraid if I start chiseling joints then little stones will fall out.
wazez is offline
Old 05-05-2016, 02:51 PM   #5
brickhook's Avatar
Trade: masonry
You can still go look at it. If it's damaged in any way, I would suggest putting a stainless liner in it, And then pointing up what ever needed.
But the last person who works on a chimney owns it.
The Following User Says Thank You to brickhook For This Useful Post:
fjn (05-06-2016)
Old 05-05-2016, 05:00 PM   #6
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
If the homeowner thinks it's a beaut then who am I to argue? If you used a grinder to score the joints first they should chip out a lot easier and will break towards the cut
www.dominionmasonry.ca
dom-mas is offline
The Following 2 Users Say Thank You to dom-mas For This Useful Post:
brickhook (05-05-2016), fjn (05-06-2016)
Old 05-05-2016, 06:33 PM   #7
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
That's a good candidate for a parge coat and a nice looking lick and stick.
supersealconstruction.com
superseal is offline
Old 05-06-2016, 04:40 PM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,917
Structures built out of round stones have no inherent stability when the mortar bond fails.. If you need the the chimney flue, I'd wrap it with mesh than plaster it top to bottom. A smoke bomb test or internal fiber optic video might relieve some doubts to its soundness/uncracked state.
If the chimney was in the heat of the fire, make sure to check every joint is still intact, so that the flue isn't the only thing holding the rubble erect.
After looking again at the photos the craftsmanship is definitely DYI or school kid, the left jamb in the first picture doesn't match at with the rest of the c r a p . If the Owners love it , it is great as always..
The stones might be just a home made lick and stick surface mount?
Fouthgeneration is offline
Old 05-06-2016, 07:34 PM   #9
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Is that not the truth ! I have been saying that on a number of threads for quite some time. Glad someone else has taken over.
When someone calls me and wants me to "stack cannon balls" I quickly pull out my excuse book and head to the door.
fjn is offline
brickhook (05-24-2016)
Old 05-07-2016, 04:43 AM   #10
wazez's Avatar
Trade: masonry
Rewards Points: 784
That's why I'm leery to be chipping on that thing.
wazez is offline
The Following User Says Thank You to wazez For This Useful Post:
fjn (05-07-2016)
Old 05-07-2016, 03:20 PM   #11
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
The interior looks fine, the roof may be a pos though.
JBM is offline
Old 05-07-2016, 07:03 PM   #12
fjn's Avatar
Trade: mason
Just an idea to throw out there,how about brushing on a top quality bonding agent,mixing a tad in on the pointing mud and going that route? I 'm with you on that I would not be thrilled to be grinding and chiseling on that chimney.Plus,it is never fun to be grinding indoors,vacuum dust control or not.
fjn is offline
Old 05-13-2016, 08:35 PM   #13
splitstone's Avatar
Trade: mason
Rewards Points: 12
I have to disagree with no stability. There is stone work here in Michigan over a 100 years old that is still standing with no motar joints. This is a picture of work that I have done on our house. My theory is if the stone will not support its self dry laid then it will not support itself with mortar.
I would not be afraid of that job, if a stone falls out then dampen the socket and the stone then apply a thin layer of hydralic cement and plug it back in.
splitstone is offline
Old 05-13-2016, 08:51 PM   #14
splitstone's Avatar
Trade: mason
Rewards Points: 12
Old 05-15-2016, 08:11 AM   #15
dbrons's Avatar
Trade: Masonry
Rewards Points: 608
But that's fourthgeneration, and fjn's point splitstone. You couldn't build a wall with river rock with no mortar joints. It would be like stacking bowling balls
dbrons is offline
The Following 2 Users Say Thank You to dbrons For This Useful Post:
fjn (05-15-2016), Fouthgeneration (05-15-2016)
Old 05-15-2016, 10:51 AM   #16
fjn's Avatar
Trade: mason
Exactly. That is why bricks are made flat instead of round.
fjn is offline
Old 05-15-2016, 11:25 AM   #17
splitstone's Avatar
Trade: mason
Rewards Points: 12
The key to it is sorting thru the material to find stones with flat tops and bottoms..bowling for dollars.
Stone chimney tuckpoint-screenshot_2016-05-15-12-16-34_1463329381026.png   Stone chimney tuckpoint-screenshot_2016-05-15-12-16-25_1463329401968.png
Old 05-15-2016, 07:28 PM   #18
JBM's Avatar
Trade: Masonry
I wouldnt use round rocks as a structural material, veneer sure.
JBM is offline
Old 05-19-2016, 03:06 AM   #19
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,536
But aren't there a lot of very old cellars, foundations and even structural walls built that way in your neck?
What about the dry fences and retaining walls?
Not that the field granite or river jacks are all total bowling/cannon balls, but still pretty round.
My BIL's cellar, porch, porch columns , steps up to porch and down into cellar, all river jacks. (Belmont, not all that far from you)
Not sure of the age but well over 100. All in good shape. That includes the 2+ story frame structure above it.
I know they can be difficult to build and tie together, just a couple miles north, we have a band of glacieral deposited granite boulders (round stones), that I've used dry and wet, structurally. Hate it but have done it. Same goes for the abundance of river jacks around the area. No fun at all and personally, not my taste.
However, as you said, today's new work in mostly veneer.
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
The Following User Says Thank You to Diamond D. For This Useful Post:
JBM (05-19-2016)
Old 05-19-2016, 02:09 PM   #20
JBM's Avatar
Trade: Masonry
D.
The foundations around here that look like that are in most cases 2' thick and incorporate huge mfing rocks as well.
JBM is offline
Putting veneer Stone over an old chimney? Antropovsky Masonry 36 05-19-2015 09:36 PM
Natural Stone Installation Rob Branca Masonry 52 05-01-2015 09:28 PM
Paint over block chimney 2low4nh Masonry 5 07-14-2014 10:40 PM
Natural Stone Veneer Around Windows euphoricme Masonry 17 06-17-2012 08:49 PM
Stone fireplace facelift..before and after stonecutter Masonry 30 05-22-2012 09:00 PM
