Started This One Today - Page 2 - Masonry - Contractor Talk
Old 04-06-2016, 08:17 AM   #21
EDM007's Avatar
Trade: chimney
Rewards Points: 2
Re: Started This One Today
The 316TI stainless steel flexible chimney liner is the best liner to vent any gas appliance. B-vent is more used when you do not have an existing chimney and the appliance is 80% or below. The kits they make for the stainless steel liners make it easy to install one. https://www.rockfordchimneysupply.co...ustom-kits.php
EDM007 is offline
Old 04-06-2016, 06:21 PM   #22
Renaissance Man
superseal's Avatar
Rewards Points: 5,840
Pretty cold start this morning and rain is expected to roll in this evening and tomorrow. We're expected to get up to 2" or so and it will be of the wind driven variety.
Speaking of winds, this is the 4th straight day of 30mph+ and quite frankly, i'm friggin' sick of it.
We had 60+ on Sunday and trees were down all over the place...I thought the winds of March were over
Anyhoot, I had to go see my accountant at 3pm today so I just buttoned up the rest of the chimney and wrapped it tightly so rain doesn't find my detached flashing.
Ahh, the Sucher boys are milling the streets today...these guys are local and get most of the Muni street paving contracts, they did my own street about two years ago.
There's goes my nice quiet day!
Started this one today-kerney-chimney-046a.jpg   Started this one today-kerney-chimney-048a.jpg   Started this one today-kerney-chimney-052a.jpg   Started this one today-kerney-chimney-050a.jpg   Started this one today-kerney-chimney-044a.jpg
supersealconstruction.com
superseal is offline
Old 04-06-2016, 06:33 PM   #23
Renaissance Man
superseal's Avatar
It's going down in the upper 20's again tonight and with the heavy rain coming, I wrapped this puppy tight. Hell, with those temps, it'll starty as snow if it comes overnight.
Thank God for stucco tape. I wrapped that flue right to the tip and installed the old cap for now.
Next up, flashing and shingle repair. Then I'll be moving on to lathing this thing up and getting the base on.
Here's the smoke pipe configuration in the basement I'll be dealing with come liner time...
Started this one today-kerney-chimney-058a.jpg   Started this one today-kerney-chimney-062a.jpg   Started this one today-kerney-chimney-063a.jpg   Started this one today-kerney-chimney-060a.jpg   Started this one today-kerney-chimney-064a.jpg
Old 04-06-2016, 06:47 PM   #24
fjn's Avatar
Trade: mason
Rewards Points: 11,202
The only thing you forgot when wrapping that puppy up was the bow.
fjn is offline
Old 04-06-2016, 07:36 PM   #25
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,436
Originally Posted by JBM View Post
Whatcha got the outriggers on for?
Funny i was wondering the same thing, usually if i put outriggers on that i dont need it's because I brought them, didnt need them and i dont want a scrapper stealing them so i put them up high so if they do steal them they have to work for em'. lol
Windycity is online now
The Following 2 Users Say Thank You to Windycity For This Useful Post:
dom-mas (04-07-2016), superseal (04-07-2016)
Old 04-07-2016, 10:04 PM   #26
Renaissance Man
superseal's Avatar
There is no inspection for installing new gas furnaces/water heaters into old masonry chimneys here. It seems solely up the the hvac/plumber to know his chit.
This one needs mechanical permit for the liner inspection, a building permit with plans for the chimney and a stucco permit with lath inspection prior to scratch. Also needs final to confirm chimney height which usually on take three seconds...towns around here have pretty strict enforcement and generally charge 45 clams per thousand of market value... swear, they're the real mob!
Old 04-08-2016, 05:31 AM   #27
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Interesting, cause I wa going to mention that it doesn;t look like that chimney is 2' 11" over the ridge. Or do you only have the 2' over 10' rule
www.dominionmasonry.ca
dom-mas is offline
Old 04-08-2016, 09:28 AM   #28
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,044
I did get a few courses up before I caved Overall, I would have welcomed a day off.
Truth be told, that brick would have hurt like hell and probably put me in a coma...lord knows, one of you guys would have had to cover for me until I woke up
Close enough, I'm outta here...
Not trying to be picky here, but do you just rely on caulk to seal the flashing instead of counter flashing laided into the brick as you are going up?
Randy Bush is offline
Old 04-08-2016, 05:33 PM   #29
Renaissance Man
superseal's Avatar
Depends on the job and what people are willing to pay for, sometimes they receive a full dpc tray, sometimes I'll lay soakers in along the way or sometimes I'll saw-cut and embed the counter.
This particular job is receiving a breathable, acrylic topped, hard coat stucco system which will be pretty ironclad in terms of water penetration.
The fiber mud crown will also be treated with a flexible seal coat and in addition, the liner install will squash any internal moisture issues.
I been battling rain and high winds on this job that just won't quit...I left the old flashing intact only so I could cover over it easier in the interim.
Today was no different, we had snow squalls and some wet precipitation early in combo with winds that were 30/40 mph sustained...tomorrow were expected several inches of wet snow and more rain on Monday.
I did battle the elements long enough today to pull up that mucked up shingle area behind the chimney and got the new flashing installed.
Looks like the Sucher boys are back at it today as well getting started with their paving project.
Started this one today-kerney-chimney-067a.jpg   Started this one today-kerney-chimney-070a.jpg   Started this one today-kerney-chimney-068a.jpg   Started this one today-kerney-chimney-071a.jpg   Started this one today-kerney-chimney-072a.jpg
The Following User Says Thank You to superseal For This Useful Post:
Randy Bush (04-08-2016)
Old 04-08-2016, 05:42 PM   #30
Renaissance Man
superseal's Avatar
We use the 3/2/10 rule and I'm a little over 2ft above the peak... in addition, the chimney is 3'3" above the roof at the high side and my chimney liner extends this measurement another 6 inches due to the type cap I use...plenty high enough for my inspection.
Started this one today-chimney-2-3-10-rule.png   Started this one today-higgins-chimney-025a.jpg
dom-mas (04-09-2016)
Old 04-09-2016, 11:24 AM   #31
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Ok. Our code here is 2'/10' but if the ridge is within 10' it has to be 2'11" above the ridge.
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
brickhook (04-09-2016)
Old 04-10-2016, 05:06 PM   #32
Renaissance Man
superseal's Avatar
So even though my liner supply company is 125 miles away in Scranton, PA, a quick call before noonish and my stuff arrives at the shop or jobsite the very next day. It's one stop shopping and can be done over the phone during business hours or the net at anytime...Their pricing is great, the people are great and their product is great...That's my little kudo's to you Olympia!
Anyway, I was sorting through my delivery earlier to make sure everything is good and there's no damage. As usual, everything looks fine except one missing screw for the cap...probably vibrated off during shipping and slid through a crack in the box and more than likely inserted into somebodies tire right about now ...as long as it ain't mine, i'm good!
For those who aren't familiar with liners I've give you a little run down...buying them in kit form always saves money. You can swap out items like longer tee snouts, connectors and caps and still get kit pricing along with their famous free shipping. You step outside the box and order short of minimums and you'll paying for shipping and usually a longer wait time.
Since I always install stainless no matter what fuel I'm dealing with, my mainstay is the 316TI units. Pretty sure all the accessories are 304 and this company utilizes band clamps for a quick and easy installation. That is, once you get it down the chimney and the bottom opened up. Since this will be a 5" x 30ft liner, I don't expect too many issues.
I'll normally drop a dummy section with an attached nose cone and rope and pull it through to make sure the liner has enough room with no obstructions. If that doesn't go down the customer is charged a set hourly fee in order to clear the path...sometimes this means literally cutting a hole somewhere along the stack to free things up.
For 5" and 5.5" this is usually not an issue, move up to 6" and all bets are off, they can be a real bear.
So here's a visual of the components I'll be using for this job...all the smoke pipe to both appliances will be replaced as well using 26ga. galvanized.
Started this one today-kerney-chimney-074a.jpg   Started this one today-kerney-chimney-075a.jpg   Started this one today-kerney-chimney-076a.jpg   Started this one today-kerney-chimney-078a.jpg   Started this one today-kerney-chimney-080a.jpg
Old 04-10-2016, 05:11 PM   #33
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Just wondering...why are you replacing the liner?
dom-mas is offline
Old 04-10-2016, 05:21 PM   #34
Renaissance Man
superseal's Avatar
Downsizing the flue to increase draft and to meet the btu inputs of the appliances...the existing oversized 8.5 x 8.5 flue is what is killing this chimney from within...This process will increase draw, lessen the acidic condensation and maximize appliance efficiency, all the while preserving the condition of the masonry chimney.
dom-mas (04-10-2016)
Old 04-10-2016, 05:22 PM   #35
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Ive never put a liner in and never will, having it jam would be too much for my pea brain.
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
superseal (04-10-2016)
Old 04-10-2016, 05:24 PM   #36
Renaissance Man
superseal's Avatar
Have you not been paying attention Dom?
Old 04-10-2016, 05:29 PM   #37
Renaissance Man
superseal's Avatar
Well congratulations there J...
Old 04-10-2016, 05:38 PM   #38
Renaissance Man
superseal's Avatar
Here Dom...pretty much spells it out.
http://www.csia.org/homeowner-resour...y_Chimney.aspx
Old 04-10-2016, 05:46 PM   #39
Renaissance Man
superseal's Avatar
C'mon J, you could get one down here...look, you can see daylight above.
Is that a piece of wood in there...sure looks it
Started this one today-kerney-chimney-004a.jpg   Started this one today-kerney-chimney-001a.jpg
Old 04-10-2016, 05:49 PM   #40
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
No...I've got a good memory...it's just short
dom-mas is offline
New project started today superseal Windows, Siding and Doors 40 12-16-2014 11:12 PM
8500 sq ft started today blakeb92 Framing 46 10-16-2012 11:41 AM
Lost money today!!!! ash2042 Business 110 01-29-2011 11:35 AM
New helper today Hmrepairs General Discussion 10 01-20-2011 10:07 AM
I just figured out my problem today Mike's Plumbing Off Topic (Non Trade) 15 11-03-2010 05:21 PM
