Stained Stucco - Masonry - Contractor Talk
Stained Stucco
Old 12-18-2005, 02:12 PM   #1
dpack's Avatar
Stained Stucco
Long time listener, first time caller... Final clean up on a job and we aretrying to remove some difficult stains on the stucco (clay dirt splased up after rainand general roofing residue from newly cut composite slate tile) Tried pressure washer and did almost nothing! Also tried some elbow grease with some with stucco/siding cleanser from Home Depot...still nothing. Any suggestions..... Thanks.
dpack is offline
Old 12-18-2005, 05:31 PM   #2
jmic's Avatar
Rewards Points: 2,000
Re: Stained Stucco
Dpak,
Don't know but wondering what a little bleach would do? Or maybe some muriatic acid.
Joe
jmic is offline
Old 12-18-2005, 08:21 PM   #3
two kids's Avatar
Rewards Points: 75
Re: Stained Stucco
If it is clay ....IT AINT COMING OFF....sorry to tell you that , but here in TENN thats all we have and once it gets on masonry its there for life.....not even muriatic acid will bring it off. I have seen some take a pressure washer and " blow" the face of the wall off but that is the only thing I have ever seen work
two kids is offline
Old 12-19-2005, 01:00 AM   #4
dpack's Avatar
Re: Stained Stucco
I here that! I'll try the bleach idea, not the muratic (attacks the lime and not the stain) Someome recommended applying a thin layer of the same color stucco over the stain. Mix the stucco that same thickness as cream and apply it with a trowel or brush. Will this crack later or worse peel off?
Thanks for the takes.
dpack is offline
1 coat vs. 3 coat stucco finishing janrickey General Discussion 12 07-17-2011 10:22 AM
Tight Space Stucco Question - Undershot between roof sections CGofMP Construction 3 03-24-2009 08:10 AM
Some questions about painting outside stucco?? Zeebo Painting & Finish Work 10 09-20-2006 07:09 AM
Rubber membrane behind ledger on stucco? Woodcrafter74 Decks & Fencing 6 01-31-2006 08:27 PM
Stained stucco dpack General Discussion 9 12-29-2005 07:54 PM
