Slab On Grade - Masonry - Contractor Talk
Slab On Grade
Old 01-28-2010, 04:33 PM   #1
Polaris900's Avatar
Slab On Grade
Hello,
I have a job that the owner wants a slab on grade for a two story garage that he wants attached to his house. Will a slab on grade be ok. Because the frost depth is about 4 feet. I am worried it might heave and detach from the house which is 40 years old.
Thanks
Steve
Polaris900 is offline
Old 01-28-2010, 04:40 PM   #2
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 196
Re: Slab On Grade
Handle the addition the same way as the house. Footings as per the building you are attaching it to.
For Northern, cold climates, you need to be at least below frost.
You don't list where you are from, so please edit your profile to state your area, if not your city.
jlhaslip is offline
Old 01-28-2010, 05:00 PM   #3
Concrete Mike
CONCRETE MIKE's Avatar
Trade: concrete
Rewards Points: 250
Re: Slab On Grade
CONCRETE MIKE is offline
Old 01-28-2010, 05:01 PM   #4
Concrete Mike
Trade: concrete
Rewards Points: 250
Re: Slab On Grade
You need concrete or block footers, no floating slab.
Old 01-28-2010, 06:30 PM   #5
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
Re: Slab On Grade
In our area, code requires that anything attached to a dwelling have a full foundation to below the frost line (5 ft. depth for us) Could only get away with a floating slab for a fully detached structure
bytor is offline
Old 01-28-2010, 08:35 PM   #6
Polaris900's Avatar
Re: Slab On Grade
Thats what I was thinking putting down to the original footing, so there won't be any issues.
Thanks
Old 01-30-2010, 06:13 PM   #7
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 170
Re: Slab On Grade
I definately agree with those above, footing to match existing or deeper.
BUT, we actually did a small project a few years ago where we did the foundation for a breeze-way connecting a house with full foundation to a floating slab garage. It's the only time I've seen it done permitted, as well as the carpenter/GC and building inspector. Everything needed expansion joint between the 2 structures, from footing to walls to siding to brick wainscoat. The roof was the most complicated element as I understand, as the breezeway roof literally rested on the garage - no actual fastening. It also required some real strange valley flashing procedure accordign to the carpenter.
All said & done, I'm sure it cost more than just tearing the garage down & starting over with full frost walls. I'm fairly sure the only reason they didn't go this route is that the garage was encroaching on newer set-back limitations.
jomama is offline
Old 01-31-2010, 07:06 PM   #8
Twisted Cameron
scrapecc's Avatar
Trade: Concrete, Metal buildings
Rewards Points: 254
Re: Slab On Grade
Some places you can use a thickened edge slab with piers. But you have to check with your local code authority.
scrapecc is offline
Old 02-01-2010, 04:54 PM   #9
JD3lta's Avatar
Trade: Stone Masonry
Rewards Points: 156
Re: Slab On Grade
It's got to be thick enough to hold serious weight unless they want a ramp, might as well bury it. Regardless there's probably a code unless it's on private property out of view somewhere far from the main road.
JD3lta is offline
Old 02-01-2010, 05:19 PM   #10
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
Re: Slab On Grade
The bottom of the footings should be at least as deep and the house footings and below frost.
Use stem walls high enough to get the sill 6" to 8" above the finished floor. Pour a true flat floating slab on compacted soil between the stem walls at the desired grade. This will allow you to easily slope the slab to a central drain or any direction you wish. This also gets your wood the required 6" above outside finished grade. It also is much easier to clean out or wash the garage floor.
Dick
concretemasonry is offline
The Following User Says Thank You to concretemasonry For This Useful Post:
skyhook (02-02-2010)
Old 02-02-2010, 08:52 AM   #11
Concrete Mike
Trade: concrete
Rewards Points: 250
Re: Slab On Grade
granite slab handling archibaldtuttle Kitchens & Baths 3 10-12-2009 07:25 PM
slab on grade mjaafreh2008 Construction 10 02-16-2009 08:35 PM
Slab on grade house. ICF? ARCS Construction 3 12-21-2006 04:00 PM
Slab on Grade fill options? James Ellis Construction 10 10-24-2006 12:55 AM
5" pored concrete slab on grade? Nac Masonry 1 04-25-2006 06:53 PM
