Skinny Stem Wall - Page 2 - Masonry - Contractor Talk
Skinny Stem Wall
Old 05-25-2019, 09:39 PM   #21
Randy Bush's Avatar
Trade: Exterior Remodeling
Rewards Points: 2,592
Re: Skinny Stem Wall
When I encounter a situation where the siding would run into the ground I will flash the wall , I/W then use a PVC board , 8", then a drip cap and side. Might be better ways , but I have found it works pretty good.
Randy Bush is offline
The Following User Says Thank You to Randy Bush For This Useful Post:
Rio (05-25-2019)
Old 05-26-2019, 06:42 AM   #22
Tom M's Avatar
Rewards Points: 11,368
I considered a water table with boral. I'm not a fan of PVC and paint limitations.
Tom M is offline
Old 05-26-2019, 08:12 AM   #23
Randy Bush's Avatar
Never have used boral , not common here. The paint limitation on the PVC can be a problems at times. Lots of time I have white trim on a house so the PVC white works out.
Old 05-26-2019, 08:49 PM   #24
META's Avatar
Trade: General and Trades
Rewards Points: 7,146
Boral is rated for ground contact.
META is offline
The Following User Says Thank You to META For This Useful Post:
Randy Bush (05-26-2019)
Old 05-26-2019, 09:41 PM   #25
Randy Bush's Avatar
I don't know why it is not carried around here. When I ask about it normally get the deer it the headlights look. Lol Think I need to push for some to be brought in.
Sent from my SAMSUNG-SM-T377A using Tapatalk
Tom M (05-27-2019)
5 coats of new paint peeled right off wall 18delta Painting & Finish Work 53 12-27-2015 03:13 PM
Dead wall sconce box. bob_cntrctr Electrical 5 03-09-2013 06:50 PM
Shear Wall Plywood Nailing & Structural Issues sbebuilders Framing 12 02-04-2013 11:35 PM
Wet basement, just making sure my thoughts are correct HandicappedHome Excavation & Site Work 7 10-12-2012 06:17 AM
Have Questions Regarding erection of Exterior Block wall rxotik Masonry 1 09-10-2012 10:42 PM
