Repoint - Grinding Advice - Masonry - Contractor Talk
Old 06-15-2019, 08:49 AM   #1
john2019's Avatar
Rewards Points: 40
Morning all, figured I would start a new thread to have it separate from my other post.
Looking for some grinding advice. I did get the Bon Tool router bit and the head that JBM recommended. Just need to find a grinder local that fits the head.
So, was grinding along with 1/8" blade, I also have 1/4", so question is do you guys just relief cut then start chiseling? I attached a couple pics, where I just let the grinder do all the work, but then you score the top and bottom of the brick. So I looked into the Trow & Holden tool...but for large areas just seams like that's not the right tool either. The mortar being removed is type N maybe a tad stronger.
So how do you guys handle this? Plus do you go with BIA standards? 2 1/2 time the joint depth?
Repoint - Grinding Advice-img_1272.jpg   Repoint - Grinding Advice-img_1273.jpg   Repoint - Grinding Advice-img_1274.jpg
john2019 is offline
Old 06-15-2019, 04:43 PM   #2
john2019's Avatar
Rewards Points: 40
Re: Repoint - Grinding Advice
N/a
john2019 is offline
