Renovation Customer Wants Permanent Dog Door In Brick. - Masonry - Contractor Talk
Old 05-01-2015, 01:35 PM   #1
kixnbux's Avatar
Rewards Points: 1,440
One of my customers I work for has asked me to also install a permanent dog door in her home. It won't be through a door but through the actual brick wall. Anything special I need to know here? Not done one through brick before. Also any tips on good brick cutting blades? Preferably something that would fit a tool I already have if possible.
kixnbux is offline
Old 05-01-2015, 01:42 PM   #2
mako1's Avatar
Rewards Points: 1,094
Re: Renovation Customer Wants Permanent Dog Door In Brick.
I'd want a demo saw to get the straightest cut I could.Or maybe a circular saw with diamond blade but your limited by depth.9" angle grinder would work but I don't know what you have.The cleaner you can cut it ,the easier it will be to frame and seal.
mako1 is offline
The Following 2 Users Say Thank You to mako1 For This Useful Post:
Gordon Forsyth (05-18-2015), kixnbux (05-01-2015)
Old 05-01-2015, 01:48 PM   #3
kixnbux's Avatar
I have both of those. I'm pretty well equipped with tools. But concrete and brick isn't something I do enough to have anything specialty there.
kixnbux is offline
Old 05-01-2015, 01:54 PM   #4
mako1's Avatar
I would use demo saw and cut the opening oversized so I could frame and flash it for a nice look..Would make the install go smoother and easier to remove and refinish if they sold the place or ever wanted to change it back.Sure never done it in brick .Just MHAO.That way you have a wood frame to attach the door to in place of trying to anchor it to whatever is there.Also would give you something to attach some trim to easily.
mako1 is offline
The Following User Says Thank You to mako1 For This Useful Post:
Old 05-01-2015, 01:56 PM   #5
madmax718's Avatar
Trade: General
Rewards Points: 3,272
In the brick? where's my kooky face.
madmax718 is offline
Old 05-01-2015, 02:00 PM   #6
mako1's Avatar
Yea.That is an odd request and I think they would change their mind quickly after getting my quote for that.Some people just don't get it.They think,you cut a hole and nail in a doggie door.What's the problem?
mako1 is offline
Old 05-01-2015, 02:06 PM   #7
kixnbux's Avatar
I agree on the quote. I'm still working up my idea on that. It's going to surprise her I bet. Not quite the piece of cake she's thinking
kixnbux is offline
Old 05-01-2015, 02:12 PM   #8
mako1's Avatar
It never is!!!
mako1 is offline
Old 05-01-2015, 02:49 PM   #9
TaylorMadeAB's Avatar
Trade: Renovations
Rewards Points: 1,686
Isn't it the worst working on an oddball quote that you're sure they won't accept? You can just feel the wasted minutes ticking by.
TaylorMadeAB is offline
The Following User Says Thank You to TaylorMadeAB For This Useful Post:
CarpenterSFO (05-02-2015)
Old 05-01-2015, 03:12 PM   #10
kixnbux's Avatar
Isn't that the truth. 😐
kixnbux is offline
Old 05-01-2015, 03:47 PM   #11
rselectric1's Avatar
Rewards Points: 858
I know masonry is strong. I'm curious what the masons here will say about if a lintel is needed even for this small an opening. I have no idea and am just asking.
How wide does the door need to be? Is it a Great Dane or an ankle biter?
rselectric1 is offline
The Following User Says Thank You to rselectric1 For This Useful Post:
dom-mas (05-01-2015)
Old 05-01-2015, 03:51 PM   #12
kixnbux's Avatar
I'll find that out when I go look at where she's wanting it. I bet it will be not over 14" wide according to her description. Even so it probably will need good brick support installed
kixnbux is offline
Old 05-01-2015, 03:55 PM   #13
Rewards Points: 858
I'm going to move this to the masonry section so maybe one of the brickies will pick it up tonight and give you some pointers and rules. Otherwise the ones who really know might miss this thread.
Old 05-01-2015, 08:13 PM   #14
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
14" I wouldn't worry about an angle, 18" I would. A wood buck is likely more than strong enough but I don't care for likely except at my house. An angle would be overkill but it's cheap and it could easily be mounted in the front and flashed to look Ok...not great but ok
www.dominionmasonry.ca
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
Old 05-02-2015, 07:05 AM   #15
JBM's Avatar
Trade: Masonry
Rewards Points: 8,942
Would need to make sure the gap between the house and bricks is water tight. Other than that cut away, no biggie. If it were me I would want to vac the dust as I cut it. a 7" blade on a 4" angle grinder can get nice deep cuts without a big machine in the way should you want to stick a shop vac in there to suck up the dust.
JBM is offline
Old 05-02-2015, 10:53 AM   #16
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 331
You'd be surprised what people will pay for pet stuff. We have seen several homes with pet showers, and recently installed an automatic doggie door that cost over a grand just for the door.
Easy Gibson
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
Rockmonster (05-06-2015)
Old 05-02-2015, 11:48 AM   #17
RiverBG's Avatar
Trade: Home rehab specialist
Rewards Points: 764
Renovation customer wants permanent dog door in brick.-imageuploadedbycontractortalk1430585262.973039.jpg
No kidding I had a client drop
4 grand on this dog shower
RiverBG is offline
The Following User Says Thank You to RiverBG For This Useful Post:
Old 05-02-2015, 01:51 PM   #18
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Let me guess? Dog but no kids. Had a client who was always talking about his girls. The conversstions never made any sense to me until he finally brought them around, his 2 golden retrievers. He had his whole basement designed for the dogs.
dom-mas is offline
Old 05-02-2015, 02:24 PM   #19
MSLiechty's Avatar
Trade: Bender Of Nails
Rewards Points: 428
I have one through a wood framed wall and stucco on the exterior Renovation customer wants permanent dog door in brick.-imageuploadedbytapatalk1430594558.878566.jpgRenovation customer wants permanent dog door in brick.-imageuploadedbytapatalk1430594579.845072.jpg. Ohh yeah no kids either I really should get around to trimming out the exterior
ML
ML
MSLiechty is offline
Old 05-02-2015, 02:35 PM   #20
CarpenterSFO's Avatar
Rewards Points: 2,044
I was at a supplier this morning and a guy was telling his friend that he's annoyed that his wife's $5MM dog policy won't pay for $10K cataract surgery. I figured it was all exaggeration, but I don't know - do people insure dogs for $5MM? Do dogs get $10K cataract surgery?
- Bob
CarpenterSFO is offline
Banks Can Legally Steal Customer Funds From Private Checking Accounts Snobnd Off Topic (Non Trade) 11 08-20-2012 11:14 PM
brick chimney leaking through brick? dave_dj1 Roofing 38 03-30-2012 03:28 PM
removing brick Yersmay Masonry 27 12-24-2011 11:46 PM
Up Against A Brick Wall Meticularius New Member Introductions 5 09-28-2011 05:06 PM
Adding a Brick Ledge to a Michigan Home bajafx4 Masonry 3 01-23-2009 07:19 PM
