Removing Oil Spots From Concrete. - Masonry - Contractor Talk
Old 10-01-2018, 07:40 PM   #1
Renaissance Man
superseal's Avatar
Rewards Points: 5,840
Like the title says...at my own home and I'm fixing up the old attached 1 car masonry garage and the previous worked on and owner parked his cars in here the whole 50+ years he lived here...I know this because I grew up next door and knew him well. I also know his old cars leaked oil pretty regularly and by the time I took ownership, it had baked in as much as an auto repair shop.
Through the years I've just used the garage for storage for the business and threw indoor/outdoor carpet over the floor to cover it up.
Recently, I decided to build some basic shelving in there, I want to paint the walls and floor, change out the garage door etc... in order to clean things up.
Anyhow I thought about busting it up and replacing it as it was so bad...then decided I would at least try and clean it the best I could and see where that took me. We all know oil, especially caked in oil is tough to remove, even surface grinding isn't enough in itself. We also know that most cleaners are chemical based and of the nasty variety that stink to high hell and make a serious mess.
My research continued and the consensus matched my own thoughts that I'd never get it all up when I came upon a old fella in a garage forum who stated he'd never met an oil stain he couldn't remove with basic TSP and hot water. I thought, chit, that seems easy enough and I have some TSP out in the other garage so it won't even cost me a dime to try.
Well, three applications of hot water/TSP/Dawn dish soap and quite frankly couldn't believe my eyes...all the oil is gone, and I mean gone. Absolutely unbelievable results from a product I always have in stock, yet rarely seem to use. The areas shown were crusted with oil so thick I had to scrape loose what I could before attempting to clean. They're still a little wet as well but you can see how well it worked. I'm still going to pressure wash and etch it on my next opportunity along with cleaning the walls to prepare for paint. Probably do block filler and an acrylic finish on the walls and epoxy on the floor.
Removing oil spots from concrete.-img_6704.jpg   Removing oil spots from concrete.-img_6705.jpg
supersealconstruction.com
superseal is offline
The Following 11 Users Say Thank You to superseal For This Useful Post:
Dirtywhiteboy (05-17-2019), fjn (10-02-2018), greg24k (10-02-2018), hdavis (10-01-2018), MarkJames (05-17-2019), Rio (10-10-2018), Seven-Delta-FortyOne (10-01-2018), Sir Mixalot (10-12-2018), Sisyphus (10-13-2018), stuart45 (10-02-2018), Tom M (10-02-2018)
Old 10-01-2018, 09:01 PM   #2
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,028
Re: Removing Oil Spots From Concrete.
Never would have guessed that.
Do you have any before pics?
Old 10-01-2018, 10:03 PM   #3
Renaissance Man
superseal's Avatar
I don't...mainly because I was convinced it wouldn't even touch it.
I will say the grooves in the floor were flush with oil sediment and the surface was absolute black, smooth and paint like.
I just went back out to look and dropped a bead of water on the surface and it absorbed readily...just what I'm looking for.
The Following 2 Users Say Thank You to superseal For This Useful Post:
Old 10-02-2018, 06:11 AM   #4
General Contractor
greg24k's Avatar
Rewards Points: 8,480
That stuff is the best. 1st time I used it, I was doing a job for a customer, and my power steering line had a leak in it. When I saw that huge stain on the driveway it blew my top and TSP sure did its magic.
greg24k is offline
fjn (10-02-2018)
Old 10-02-2018, 06:20 PM   #5
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Thanks guys for the tip. Never know when you need to use it.
fjn is offline
Frank Castle (10-02-2018)
Old 10-02-2018, 08:04 PM   #6
Tscarborough's Avatar
Rewards Points: 1,460
Even easier is to make a poultice of TSP and bleach, apply and cover with plastic and let it sit for a day or too. All gone, and it takes much less water to do.
Tscarborough is offline
The Following 4 Users Say Thank You to Tscarborough For This Useful Post:
fjn (10-03-2018), greg24k (10-02-2018), MarkJames (05-17-2019), superseal (10-06-2018)
Old 10-06-2018, 11:11 AM   #7
Renaissance Man
superseal's Avatar
I ground down half the floor using a diamond cup and sawed out some cracks...time for stitches!
I secured the patches with Em-Cryl 600 and 9000psi high strength flowable grout. Eventually this floor is getting a 2 part polyamine epoxy, aka, Armorseal 8100.
Removing oil spots from concrete.-img_6706-2-.jpg   Removing oil spots from concrete.-img_6712.jpg   Removing oil spots from concrete.-img_6727.jpg   Removing oil spots from concrete.-img_6748.jpg   Removing oil spots from concrete.-img_6750.jpg
Removing oil spots from concrete.-img_6751.jpg   Removing oil spots from concrete.-img_6753.jpg
fjn (10-06-2018), Fouthgeneration (10-06-2018), MarkJames (05-17-2019), mrcat (10-06-2018), onmywayup (10-06-2018), overanalyze (10-10-2018), Peter_C (10-21-2018), Rio (10-10-2018), Seven-Delta-FortyOne (10-06-2018), Sir Mixalot (10-12-2018), Tscarborough (10-06-2018)
Old 10-06-2018, 11:19 AM   #8
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
a fancy schmantzy repair there bub !
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
fjn (10-06-2018), superseal (10-06-2018)
Old 10-06-2018, 12:17 PM   #9
Renaissance Man
superseal's Avatar
Why spank you very much!
Old 10-06-2018, 01:06 PM   #10
90%-er
onmywayup's Avatar
Rewards Points: 2,236
I just did a commercial warehouse locker room.... Put that Armorseal 8100 on the floor. Worked out great. Nice product. Went farther than I would have expected from the can, too.
onmywayup is offline
The Following User Says Thank You to onmywayup For This Useful Post:
Old 10-06-2018, 01:14 PM   #11
fjn's Avatar
Trade: mason
Another great S.S. repair !
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
Old 10-09-2018, 11:05 PM   #12
Renaissance Man
superseal's Avatar
So roughly 20 staples up front and 27 in the back...Also found some hollow spots in the back which consumed huge amounts of liquid grout to fill. I got a feeling it was just a chitty tamp job on the sub base and she settled over the 75 years she's been down. Once I ran out of three full bags of rapid set, I made my own brew of beach sand, portland and some cement dust gathered by the dust deputy. whipped it up in 5 gal buckets all the way to the top and used seven of them...I poured it in with the wifes iced tea jug
Holy chit, I should have just repalced the slab
Can you see where the staples are?
Removing oil spots from concrete.-img_6772.jpg   Removing oil spots from concrete.-img_6773.jpg   Removing oil spots from concrete.-img_6774.jpg   Removing oil spots from concrete.-img_6775.jpg   Removing oil spots from concrete.-img_6776.jpg
Removing oil spots from concrete.-img_6777.jpg   Removing oil spots from concrete.-img_6778.jpg   Removing oil spots from concrete.-img_6783.jpg   Removing oil spots from concrete.-img_6785.jpg
The Following 4 Users Say Thank You to superseal For This Useful Post:
fjn (10-10-2018), Rio (10-10-2018), Seven-Delta-FortyOne (10-10-2018), SouthonBeach (10-10-2018)
Old 10-10-2018, 11:20 AM   #13
fjn's Avatar
Trade: mason
As usual,another great S.S. repair to the rescue !
fjn is offline
Fouthgeneration (10-12-2018)
Old 10-10-2018, 11:36 AM   #14
fjn's Avatar
Trade: mason
Hey S.S.,make up one of theses and leave your bosses' tools alone !
fjn is offline
The Following 4 Users Say Thank You to fjn For This Useful Post:
Fouthgeneration (10-12-2018), Rio (10-10-2018), SmallTownGuy (10-10-2018), superseal (10-10-2018)
Old 10-10-2018, 05:20 PM   #15
Renaissance Man
superseal's Avatar
https://www.youtube.com/watch?v=df3M9y7HCHA
Except I'm pouring down a 3/4" hole faster than I can fill up the jug!...by the 5 gal bucket to boot
The Following User Says Thank You to superseal For This Useful Post:
fjn (10-10-2018)
Old 10-10-2018, 07:14 PM   #16
Trade: Highwayman
So after all is said and done, was it quicker and/or cheaper to do the repair, or would you have just removed the slab and repoured?
Great looking repair, though.
superseal (10-12-2018)
Old 10-12-2018, 02:50 AM   #17
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
SS thanks for the schooling, I never would have considered "stone" cramps as crack spread stoppers... Going to try it on a 40 year old farm shop floor
Would you go stainless cramps in a salty garage floor? for a few extra years? The Ancients would never use iron ties in any upscale masonry work, they'll always rust pop eventually.
Like the mini-me CMU grout funnel....
Some one needs to make a bottom gate valve kit for buckets for soupy grouting, similar to a "IMER' brand wash tub vertical shaft paddle mixer....
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
Old 10-12-2018, 10:10 PM   #18
Renaissance Man
superseal's Avatar
If I had to pay myself for this work, replacement would have been the wise choice I'm afraid to admit
overanalyze (10-12-2018), Seven-Delta-FortyOne (10-16-2018)
Old 10-12-2018, 10:17 PM   #19
Renaissance Man
superseal's Avatar
I hear you with the iron and rust...thankfully the slab is fairly dry and not subject to weather. Stainless is always a choice and newer technologies like helical and carbon fiber splines make quicker work of this. In your salty environment, non ferrous would be recommended.
Old 10-13-2018, 10:13 AM   #20
fjn's Avatar
Trade: mason
Another possibility,there are claims out there that state cold galvanizing compound applied to re bar is just as effective as HDG. With that thought,one could buy a spray can and apply several coats to the bars after bending and prior to installation.
I have coated more than a few replacement lintels with it. While fiber glass bar would be the first choice,the down side,it can't be field bent.
Most web discussions claim fiber bars cost between 25-50 % more than steel. By me, mid-west,we are lucky to have a Menard's ,they recently started stocking fiber bars.....at about .80 cheaper than comparative sized steel. At twice the strength of steel and 1/7 the weight,that is all I use now if possible.
fjn is offline
SmallTownGuy (10-13-2018)
Removing coating from boardform concrete boardform Masonry 2 09-26-2016 06:19 PM
Removing Epoxy from concrete? MasterBlaster Sandblasting 3 11-08-2015 05:29 PM
Considerations for pouring a rather tall concrete pier? acro Construction 20 04-23-2013 09:04 PM
Concrete Slab breaking up in Barn Dustincoc General Discussion 7 02-14-2013 07:44 PM
Removing 2" rusted pipe out of a 7" slab of concrete? LMcustomstudios Masonry 20 02-23-2012 10:28 PM
