Removing Fireplace Brick - Page 2 - Masonry - Contractor Talk
Old 04-14-2019, 07:13 PM   #21
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: Removing Fireplace Brick
Originally Posted by rblakes1 View Post
I posted one and tang posted his project.
The one I'll be working on is getting an insert and liner run through the chimney, so no real need to tear down the existing and rebuild
-Rich
Your fine then.
JBM is offline
Old 04-15-2019, 04:29 PM   #22
tang's Avatar
Trade: Remodel contractor
Rewards Points: 505
Same here, liner and insert.
tang is offline
Old 04-15-2019, 08:26 PM   #23
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,405
RBlake1: I conflated a gas insert with adding a Gas Log(still able to burn wood) My Error.
You could bring the supply air through the ash pit door and dump lid to increase the Gas Inset's efficiency.
The local Gas fireplace guru installs a spring opened dampener on the top of the flue with operating chain that drops to above the new insert, cutting heated and cooled air waste down when not in use.
Not code legal everywhere.
In general you want a unit you can use in a power outage...
Just make sure the final framing meets the fire box requirements for spacing away from flammables.
You still have water coming down the chimney and sloped pavers.
the cheapest thing on the sloped brick would a piece of tin that matches the house tin, or limestone colored, that wrapped down the exposed side ~ a course
And something similar on the Pot Around the flue(s)
Fouthgeneration is offline
Removing Tar on Red Brick Wall SRS-NY Sandblasting 9 10-08-2015 05:26 AM
Loose fireplace brick monkey Masonry 15 01-30-2015 01:57 PM
outside fireplace brickhook Masonry Picture Post 21 11-28-2012 10:23 PM
Historic Brick Fireplace Tommy C Masonry 11 10-04-2009 09:33 PM
Cultured Stone over Existing Brick Fireplace fakie99 Masonry 7 12-01-2008 06:10 PM
