Removing Fireplace Brick - Masonry - Contractor Talk
Old 12-14-2018, 12:58 PM   #1
rblakes1's Avatar
Rewards Points: 2,806
Hi all,
I'm putting a bid together for a client of mine and when we were discussing design, the idea of lowering the height of the existing fireplace surround came up. Is this something that is generally feasible to do, or is my time and effort better spent on other ideas? I had thought about packing out the wall above, but I'm hoping to leave the existing crown in tact.
They will be going with a gas insert and some type of stone surround, cabinets flanking either side. We discussed putting a TV above, thats part of the reasoning for lowering the brick if possible
rblakes1 is offline
Old 12-14-2018, 05:47 PM   #2
Windycity's Avatar
Trade: Masonry
Rewards Points: 7,568
Re: Removing Fireplace Brick
The face brick you see is just a veneer
Windycity is online now
Old 12-14-2018, 06:25 PM   #3
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 19,583
If I may ask...
From an opening itself, what the minimum distance required to any finished wall like drywall?
How about for gas fireplaces with the horizontal "non-combustible" stud or header?
MarkJames is online now
Old 12-14-2018, 07:35 PM   #4
rblakes1's Avatar
Looked to me to be full brick, but I don't know what tricks you masons use! Would full brick be veneered over block?
House was built late 80s
rblakes1 is offline
Old 12-14-2018, 07:39 PM   #5
rblakes1's Avatar
Originally Posted by MarkJames View Post
If I may ask...
I believe 6" to the sides for combustible materials
rblakes1 is offline
Old 12-14-2018, 07:40 PM   #6
Full Monty's Avatar
Trade: Contractor
Rewards Points: 24
I think you could get in there gently with an air chisel, if the homeowner insists that it be done. I would expect it to take too much time for a minor change.
Full Monty is offline
Old 12-14-2018, 09:28 PM   #7
Fire up the BBQ
griz's Avatar
Rewards Points: 1,612
looks like a real masonry fire place.
could easily be full brick over the block fireplace structure.
griz is offline
Old 12-14-2018, 09:51 PM   #8
MTHB's Avatar
Trade: tree house building
Rewards Points: 54
maybe let code guide you? From the pics it looks like 8 ft ceilings... ...
MTHB is offline
Old 12-15-2018, 05:58 PM   #9
Windycity's Avatar
Trade: Masonry
The face brick you see is simply a decorative face over the firebox consisting of the actual fireplace...Yes They are full size brick.
Are you asking to remove the top part of the red Facebrick to lower it down, leaving the firebox untouched? Like this?
Old 12-15-2018, 09:51 PM   #10
rblakes1's Avatar
Yeah, just looking to remove a couple rows at the top. The fire box itself would remain intact
rblakes1 is offline
Old 12-15-2018, 09:55 PM   #11
Windycity's Avatar
Trade: Masonry
Shouldn’t be any issues with that
The Following 2 Users Say Thank You to Windycity For This Useful Post:
fjn (12-16-2018), rblakes1 (12-17-2018)
Old 12-16-2018, 03:01 PM   #12
fjn's Avatar
Trade: mason
Rewards Points: 10,158
Originally Posted by windycity View Post
shouldn’t be any issues with that
sent from my iphone using tapatalk
x 2
fjn is online now
Old 04-10-2019, 08:32 AM   #13
rblakes1's Avatar
Finally getting ready to sign this project, homeowner found a picture of the fireplace while the house was being built
rblakes1 is offline
The Following User Says Thank You to rblakes1 For This Useful Post:
hdavis (04-12-2019)
Old 04-10-2019, 02:12 PM   #14
tang's Avatar
Trade: Remodel contractor
Rewards Points: 417
I'm on a similar job, in a 100 year old house. Removing the lath and plaster to insulate. Cladding the brick with wonder board and granite, and building a new surround. Paint grade MDF....
Removing fireplace brick-20190405_102229-359x640-.jpg   Removing fireplace brick-20190313_091527-418x640-.jpg
tang is offline
The Following 2 Users Say Thank You to tang For This Useful Post:
hdavis (04-12-2019), rblakes1 (04-10-2019)
Old 04-12-2019, 10:38 AM   #15
rblakes1's Avatar
This one is only 30 years old, I bet there's fewer surprises with your project though!
-Rich
rblakes1 is offline
tang (04-14-2019)
Old 04-12-2019, 04:25 PM   #16
JBM's Avatar
Trade: Masonry
Rewards Points: 8,328
Take note how high the damper is, usually not good to get down to close to that area, or a couple courses above the top of it.
JBM is online now
The Following User Says Thank You to JBM For This Useful Post:
Fouthgeneration (04-14-2019)
Old 04-14-2019, 12:39 AM   #17
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,829
You could under pin the leaky chimney(water penetrating the sloped cap and pot?) eliminate the raised hearth.....tacky IMHO, and rebuild the roughness 12" lower to the floor....
Probably cheaper to demo and do over.
The craftsmanship is not apparent from the wonder bonds????? and saggy lintel, one more $ for another 1/16th of inch of thickness....
I don't think there would be enough masonry between the fire and the wood framing/mantel if two or three course were demoed IMO.
I'd review Vestal's masonry firebox minimums prior to reducing any masonry coursing or increasing any heat exposure to combustibles.
The dampener appears to be a course or two higher then needed, making it harder to safely lower the mantel.
I'd probably used insulated mulitwyth masonry above the mantel instead of wood framing out of general paranoia...
AS poorly built as the visible portion is, I'd definitely do fiber optic inspection of the flues and any possible cracks hidden by the house walls where the chimney joggs over. Before spending ANY $.
Fouthgeneration is offline
Old 04-14-2019, 04:42 PM   #18
rblakes1's Avatar
Which fireplace are you referring to?
-Rich
rblakes1 is offline
Old 04-14-2019, 06:20 PM   #19
JBM's Avatar
Trade: Masonry
-Rich
How many are we talk about?
JBM is online now
Old 04-14-2019, 06:25 PM   #20
rblakes1's Avatar
I posted one and tang posted his project.
The one I'll be working on is getting an insert and liner run through the chimney, so no real need to tear down the existing and rebuild
-Rich
rblakes1 is offline
Removing Tar on Red Brick Wall SRS-NY Sandblasting 9 10-08-2015 05:26 AM
Loose fireplace brick monkey Masonry 15 01-30-2015 01:57 PM
outside fireplace brickhook Masonry Picture Post 21 11-28-2012 10:23 PM
Historic Brick Fireplace Tommy C Masonry 11 10-04-2009 09:33 PM
Cultured Stone over Existing Brick Fireplace fakie99 Masonry 7 12-01-2008 06:10 PM
