Red Spots On New Concrete??? - Masonry - Contractor Talk
Old 02-18-2013, 10:09 PM   #1
JGCConcrete's Avatar
Trade: Concrete
I'm hoping someone has experience the same problem and can help out. I recently poured a slab in a back yard, less than three weeks ago and have been told by the owner of the home that "RED SPOTS" have developed on the surface of the slab. I have read around the web that it could be the reinforcing agent or the mesh wire should I say that is corroding. Has any one encounter a problem like this? Or could it be any thing else? Is there anything that can remove these red stains or spots?
JGCConcrete is offline
Old 02-18-2013, 10:14 PM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 2,354
Re: Red Spots On New Concrete???
I doubt you are having oxidation problems from your reinforcing unless it is not set deep enough.
Did you pour over red clay? or were there any other job site contaminants around?
Was it a one load drop from the batch plant?
Perhaps you got a contaminated load of mud.
griz is online now
Old 02-20-2013, 12:20 PM   #3
Mooman Master Mason or 3M
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
Pictures could help tremendously!
Mooman is offline
The Following 2 Users Say Thank You to Mooman For This Useful Post:
2low4nh (02-20-2013), fjn (02-22-2013)
Old 02-20-2013, 09:32 PM   #4
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 400
Any leaves fall in it while you were screeding?
NYCB is offline
Old 02-21-2013, 06:46 PM   #5
ebautista88's Avatar
Trade: Masonry/framing
did u use rebar or mesh reinforcement? maybe it could be rust if you had placed the rebar too close to the finished surface
ebautista88 is offline
Old 02-21-2013, 06:55 PM   #6
Trade: Concrete
We used mesh wire, and very few to little dobe's were used. From what I've been reading it does sound like its rust, have any idea how to remove it without harming the surface of the slab? Also once it's removed will it come back? Thanks
Old 02-21-2013, 06:59 PM   #7
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
Attachment 87607
If it is in fact rust coming from within, removing the stain isn't going to keep the rusting metal from coming right back. And, if it is in fact rust coming from within, an epoxy might seal it under.
Mooman is offline
Old 02-21-2013, 07:06 PM   #8
Trade: Concrete
An epoxy? Any kind you can recommend? Most importantly what would be the process of applying?
Old 02-21-2013, 08:02 PM   #9
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
While I'm not going to recommend any one product, (because my suggestion was simply an idea), and not based on personal experience. I will say that I am positive at least one of the pros hanging out in this forum knows of something you can try. Also, I have been reading up over the last year about this company.........Give them a look, and do your research.
http://www.westcoat.com/
Mooman is offline
Old 02-21-2013, 08:06 PM   #10
QCCI's Avatar
Trade: General Contractors/Specialty Contractors
Rewards Points: 952
Are you sure you didn't spill coffee on it? Lol
QCCI is offline
Old 02-21-2013, 08:59 PM   #11
mart4005's Avatar
Trade: concrete leveling
Rewards Points: 81
If you poured over some muddy water it would look like that.
mart4005 is offline
Old 02-21-2013, 09:07 PM   #12
QCCI's Avatar
Rewards Points: 952
I think you're right, that's what it looks like to me.
QCCI is offline
Old 02-21-2013, 09:07 PM   #13
Trade: Concrete
Is there a way to get rid of that?
Old 02-21-2013, 09:09 PM   #14
QCCI's Avatar
Rewards Points: 952
Not really. Did you pour over muddy water?
You could acid etch it and then stain it.
QCCI is offline
Old 02-21-2013, 09:13 PM   #15
Trade: Concrete
I do recall wetting it down pretty heavy the day before
Old 02-21-2013, 09:18 PM   #16
Elyrain's Avatar
Rewards Points: 442
Just pressure wash the thing and get back to us.
Elyrain is offline
Old 02-21-2013, 11:06 PM   #17
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
Found another in my list...
http://www.super-krete.com/vCategory.aspx?ID=20
Mooman is offline
Old 02-22-2013, 01:21 AM   #18
Every time i have poured, i wet the dirt and never had that happen then again I make sure its not wet like a puddle..how long ago did u pour it? U can power wash it or acid wash it ... If anything u can always stain it like other members mentioned
Old 02-22-2013, 02:49 AM   #19
Trade: Concrete
Going on close to 5 weeks now since it was poured. I am going to pressure wash it and see from there.
Old 02-22-2013, 05:55 AM   #20
SfcLee's Avatar
Trade: General contracting
Sometimes the concrete truck was used for a dye job & the truck was not cleaned well or at all. Even if it was cleaned the dye hangs up on the blades & instead of mixing completely into your batch it just gets slightly mixed with your Crete & just sits on top. The first time it gets wet it bleeds. Contact your local concrete tool, forms, & cure/ seal provider ( Euco ) for a good product.
SfcLee is offline
If you're not on Facebook, you should be. Sir Mixalot Marketing & Sales 1854 02-24-2019 04:59 PM
Help Thinking outside the box here... CONCRETE HELL!! JeremyBCalnan Tools & Equipment 37 06-24-2014 10:33 PM
Lightweight concrete alternative in a condo DanFreysinger Flooring 17 11-14-2012 10:10 AM
Raised concrete deck Bearded Wonder Construction 10 12-07-2011 02:09 PM
Recommendation on changing concrete color with breathable product? RDBD Specialty Coatings 0 06-07-2011 08:57 AM
