Re Point. - Masonry - Contractor Talk
Re Point.
Old 06-21-2019, 11:28 AM   #1
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,268
Re Point.
Got to repoint this in lime to help with it's damp problems. The client wanted all the masonry paint removed and had an estimate for sandblasting for around 800, but I did it a bit cheaper with a needle scaler. It's mainly flint so it was not a problem, although it took a bit longer than sandblasting.
Fixing the gutter will help a lot as well. It's taking water from half of the main house.
stuart45 is offline
The Following 3 Users Say Thank You to stuart45 For This Useful Post:
fjn (06-21-2019), hdavis (06-21-2019), JBM (06-25-2019)
Old 06-21-2019, 12:03 PM   #2
hdavis's Avatar
Rewards Points: 1,868
Re: Re Point.
Never tried needle scaling for that, do you have a photo of the scaler you used?
hdavis is online now
Old 06-21-2019, 02:05 PM   #3
stuart45's Avatar
Trade: Brickwork
Re: Re Point.
I'll get one on Monday. It's an electric one rather than an air one. I hired from the Builders merchants for 54 per week. I've never used one for this before, but if used on a softer stone or brick it would probably wreck the wall. The Flint was fine and also it helped take out some of the joints.
stuart45 is offline
The Following User Says Thank You to stuart45 For This Useful Post:
hdavis (06-21-2019)
Old 06-21-2019, 02:32 PM   #4
stuart45's Avatar
Trade: Brickwork
Re: Re Point.
These 2 photos show the possible causes of the damp problem. The rainwater spills over from the downpipe from the main roof, there is a bulge in the wall that pulls the gutter in and down at the back, and there is no downpipe at the end of the gutter.
Where the wall has been repointed in the past with a strong sand/OPC mix the damp in the wall is much worse.
stuart45 is offline
The Following 2 Users Say Thank You to stuart45 For This Useful Post:
fjn (06-22-2019), hdavis (06-21-2019)
Old 06-22-2019, 12:48 PM   #5
stuart45's Avatar
Trade: Brickwork
Re: Re Point.
A good example of quality flintwork.
stuart45 is offline
The Following 4 Users Say Thank You to stuart45 For This Useful Post:
cdkyle (06-22-2019), fjn (06-22-2019), hdavis (06-23-2019), SmallTownGuy (06-23-2019)
Old 06-22-2019, 08:10 PM   #6
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Re Point.
He was Hard and sharp as a flint....solitary as an oyster
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
SmallTownGuy (06-23-2019), stuart45 (06-23-2019)
Old 07-15-2019, 11:13 AM   #7
stuart45's Avatar
Trade: Brickwork
Re: Re Point.
The needle gun worked well, and the wall is almost ready for a repoint now when I get the time, as I'm doing a barn up the road as well as the Chapel wanting a Buttress wall in stone with brick tumbling in done.
I had to do a few different mixes to get the right colour for the lady and put some in the wall as a tester.
stuart45 is offline
The Following 5 Users Say Thank You to stuart45 For This Useful Post:
fjn (07-15-2019), Fouthgeneration (07-18-2019), hdavis (07-15-2019), Sisyphus (07-19-2019), superseal (07-17-2019)
Old 07-15-2019, 11:38 AM   #8
hdavis's Avatar
Re: Re Point.
How long did that take with the needle gun?
Old 07-15-2019, 11:53 AM   #9
stuart45's Avatar
Trade: Brickwork
Re: Re Point.
In total around 15 hours. She had an estimate for sandblasting, and they reckoned a whole day, for about 800, but they said it wouldn't take off some sand/cement parging in the corner at the gutter leak. The needle gun got all of that off.
It probably took me a bit longer working off steps rather than a scaffold.
The one advantage of the sand blaster is that you can just stand back and reach the top and bottom easier.
You need ear defenders as it is a noisy method.
stuart45 is offline
fjn (07-15-2019), hdavis (07-15-2019)
Old 08-01-2019, 05:03 PM   #10
stuart45's Avatar
Trade: Brickwork
Re: Re Point.
https://www.diynot.com/diy/media/dsc00031.103103/
Took the bulge out of the wall today. Timber lintel was rotten, but luckily the lady had a piece of treated timber that she wanted to use.
Once you start taking these old stone walls apart it's tricky to know when to stop.
A few of the eaves slates dropped out in the process.
stuart45 is offline
fjn (08-01-2019), hdavis (08-01-2019), Idothat (08-01-2019)
Old 08-01-2019, 05:47 PM   #11
fjn's Avatar
Trade: mason
Re: Re Point.
She definitely has the right fella on the job !
fjn is offline
stuart45 (08-01-2019)
Old 08-01-2019, 06:55 PM   #12
hdavis's Avatar
Re: Re Point.
Originally Posted by fjn View Post
she definitely has the right fella on the job !
x2.
