Re Laying A Firebox - Masonry - Contractor Talk
Re Laying A Firebox
Old 11-24-2016, 11:57 PM   #1
DLynch0009's Avatar
Trade: Residential Remodeling
Rewards Points: 308
Re Laying A Firebox
I have a fireplace in my basement I tend to burn wood in pretty much all fall and winter. Whenever the temperature requires it anyways. The room is a finished room under my garage, which has a suspended slab. The fire brick in the fire box are loose and need to be taken out and replaced and re laid. I'm a carpenter by trade but since I can lay tile I naturally have an unwarranted confidence that I can lay it myself. I know deep down that is not the case. My question is should I attempt this (I think the risks outweigh the money I'd save when dealing with fire). Or is it not that big of a deal and I should give it a shot? Fire brick seems pretty expensive for a rookie trial run.
DLynch0009 is offline
Old 11-25-2016, 07:02 AM   #2
brickhook's Avatar
Trade: masonry
Rewards Points: 7,586
Re: Re Laying A Firebox
If you believe you can lay it, give it a try. If you dont do a good job, you can always redo it.
I have to say though, a firebox might not be the easiest thing to lay if you haven't ever laid brick. If I was you, I'd just hire a good mason to come by one day and lay it back in. It's hard to beat someone at their own game.
Good Luck! Post some pictures
brickhook is offline
The Following User Says Thank You to brickhook For This Useful Post:
fjn (11-25-2016)
Old 11-25-2016, 10:46 AM   #3
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
If you do it, get some heatstop50 from a brickyard, mix 20oz or so, a small amount, at a time. Lay the bricks with either a margin or tuck point trowel.
To get the sidewall angles lay them out like this, you could put them the other way so you dont have so many courses as well. The bottom number is 17.5" make the top 14". Left is right , right is left.
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
Rio (11-25-2016)
Old 11-25-2016, 10:48 AM   #4
JBM's Avatar
Trade: Masonry
I have a cheapo mitre saw with a 10" diamond blade. I cut the angles so I can run a brick past them, otherwise the corners dont rest on much, makes a crappy line sometimes.
JBM is offline
Old 11-25-2016, 10:48 AM   #5
JBM's Avatar
Trade: Masonry
Use the seams in the plywood to keep it square, for anyone with plywood
JBM is offline
Old 11-25-2016, 12:44 PM   #6
MikeFL's Avatar
Trade: Engineer
Rewards Points: 200
On top of the firebox is the throat and on top of the throat are the flue liners. That's a tremendous amount of weight. You can't just remove and rebuild the firebox. You're going to have a disaster on your hands.
What is the problem you are trying to fix?
Can you post a picture of your problem?
Michael Gookin, President
GPS LightLock Astronomical Timers
www.GPSLightLock.com
(239) 848-6675
MikeFL is offline
Old 11-25-2016, 02:31 PM   #7
JBM's Avatar
Trade: Masonry
I took a firebox out wed, actually.
JBM is offline
freddie smith (12-06-2016)
Old 11-25-2016, 02:33 PM   #8
Smarter than the brick...
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
Uhm, when I build a firebox the throat doesn't sit on the firebox.
Kniggit is offline
Old 11-26-2016, 08:39 AM   #9
MikeFL's Avatar
Trade: Engineer
Rewards Points: 200
Are you laying a solid 4 behind the box and building a 4" throat on that?
(239) 848-6675
MikeFL is offline
Old 11-26-2016, 03:46 PM   #10
JBM's Avatar
Trade: Masonry
Here is what im working on. It was actually a raised hearth too, had to remove 2" of concrete. Not fun.
JBM is offline
Fouthgeneration (12-01-2016)
Old 11-26-2016, 05:06 PM   #11
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
And that advice is worth the price he paid for it. Masons like JB and I routinely rip out out fireboxes and re-build them...might wanna polish up your book smarts before posting ignorant information.
supersealconstruction.com
superseal is offline
Old 11-30-2016, 07:15 PM   #12
JBM's Avatar
Trade: Masonry
Might as well show completed pics, nothing amazing for sure, but bread and butter work.
Re laying a firebox-1ec1abf1-0036-4629-93bb-8dea08150a6a.jpg   Re laying a firebox-7dfce7af-7a4b-4321-98f1-1d416f4fadc6-1-.jpg
JBM is offline
The Following 4 Users Say Thank You to JBM For This Useful Post:
AustinDB (11-30-2016), fjn (11-30-2016), Fouthgeneration (12-01-2016), superseal (11-30-2016)
Old 11-30-2016, 07:36 PM   #13
WBCarpentry's Avatar
Rewards Points: 212
Look good. I'd be proud of that.
WBCarpentry is offline
The Following User Says Thank You to WBCarpentry For This Useful Post:
JBM (11-30-2016)
Old 12-01-2016, 09:26 PM   #14
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,939
JBM, your picture posted @ 10 above has given me another possibility to investigate on a smokey three flue chimney in a large farm house, I never considered, too save space, the original masons omitting a wythe of brick/block around the flue by-passing the higher fire box(es) as done in your photo.
Thanks for the posts and pictures, I'll post after New Years on the smokey farm flue, I am trying out a smart phone/ flue inspection camera cobble...
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
JBM (12-02-2016)
Old 12-01-2016, 09:37 PM   #15
Renaissance Man
superseal's Avatar
J, looks like a fat joint for heatstop...you using regular mud on that one?
Turned out nice btw...
Old 12-02-2016, 06:50 PM   #16
JBM's Avatar
Trade: Masonry
Nah it was heatstop, but I kicked it in on a Sat, roughed in and driving away by 12. I paid for it when I sponged it though, smeared a bit.
JBM is offline
Dry Pack for laying porcelain tile on exterior patio Kyong Tiling 9 07-31-2019 11:37 AM
Learning curve laying block dielectricunion Masonry 29 08-01-2014 07:15 AM
Kiva Fireplace Firebox Expansion Question frankwil Masonry 4 03-05-2014 08:02 AM
Laying treads... Rich D. Masonry 16 10-01-2013 02:46 PM
Soapstone firebox EC Craftsman Masonry Picture Post 6 05-22-2013 10:08 PM
