Question On Block Lintel - Page 2 - Masonry - Contractor Talk
Old 06-11-2014, 09:35 PM   #21
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Re: Question On Block Lintel
Originally Posted by Fouthgeneration View Post
NJ Brickie, NEVER seen the soaps grouted or re-bars place inside soaps on a W-Beam. Would you weld Nelson studs to both sides of the bottom of top flange & the top of the top flange for bonding?
Something got mixed up here. I was not talking about grouting the slabs. I was saying to isolate the cells above with the Nelson studs from the slabs below. To avoid blowing out the slabs when grouting.
NJ Brickie is offline
Old 06-12-2014, 07:44 AM   #22
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 170
Neither have I, and I think that's where a lot of the confusion is coming from here. The drawing shows the soaps grouted solid to the beam with horizontal rod between the flanges of the beam.
6string, what you want is to find someone who can build the "beam lintels" for you. Typically, you'll want an 8" narrow flange beam (~3.5" wide) with a 1/4" x 7" plate stitch welded to the bottom. I've got a fab shop that does them regularily here and has standard pricing if you can't find any quick enough.........
jomama is offline
The Following User Says Thank You to jomama For This Useful Post:
6stringmason (06-12-2014)
Old 06-12-2014, 08:40 AM   #23
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,339
NJ Brickie, The detail shows a "soaped" bond beam(U-Block) laid on the w-Beam grouted and calls for the 2-# 5 rebars 4" from bottom of w18...
Options:
A, Build it as drawn, weld Nelson studs to top of metal beam every 16"( or weld the vertical bars to iron, add couple of stirrups(loops of # 2-3 bar from Beam to top bar at roof bearing) at each end.
The issue with the as drawn construction is will the grouted rebar stay bonded to the W-beam and act compositely for the foreseeable future?
B1. Shut up and build it with rebar in the course above the beam with Studs, tie Vertical to top bar again. Dead legs under the steel for a few days or a week if GC wants to land core decking ASAP.
A2. Add two horizontal bars above the steel in notched out block, Rest as A1. Keep calm, carry on--my recommendation.
C.Call the detailer's boss for some new pictures....
Fouthgeneration is offline
Old 06-12-2014, 03:11 PM   #24
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Options:
You are correct. I've never seen that before either. My guess is its a mistake. Is it noted on the structural drawings that way?
Old 06-12-2014, 04:53 PM   #25
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
I spoke with General today. They will be supplying the steel, but I brought up concrete lintels and they replied that it wouldnt be out of the question. I might try to get them to go that route. The longest span is 10' so I dont think that will be a problem.
I appreciate the input. Doing commercial plans is relatively new to me, so its nice to have resources like this to fall back on.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
The Following User Says Thank You to 6stringmason For This Useful Post:
QCCI (06-12-2014)
Framing question glkirk Framing 17 12-15-2012 02:32 AM
Question on re-decking prices!! RHS Design Roofing 1 12-08-2012 08:48 AM
Panel Question? HVACinChicago Electrical 16 08-03-2012 09:46 AM
Question on Foam board over Block stupidcat69 General Discussion 0 07-19-2012 02:32 PM
fastening to block question shazamyman Framing 16 05-05-2008 10:54 PM
