Question On Block Lintel - Masonry - Contractor Talk
Thread Tools
Old 06-10-2014, 05:58 PM
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
I have this set of plans, and normally I dont do commercial, but I'd like to start expanding a bit, and start doing more of this.
The blueprint here has a call for block lintels 8x18, and shows what looks like an I beam of sorts to be used? Am I seeing that correctly? They are for openings for a car wash.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 06-10-2014, 06:18 PM
QCCI's Avatar
Trade: General Contractors/Specialty Contractors
Rewards Points: 952
Re: Question On Block Lintel
Yep, looks like W8x18 I-Beam lintel. Typically on commercial projects the mason will not include the cost of lintels in your bid. You will install them but not furnish them. The steel fabricator/supplier will furnish all steel on the project....lintels, bollards, embeds, structural, joists, decking, etc
If the lintels are over a certain weight, then the iron workers will install
QCCI is offline
The Following 2 Users Say Thank You to QCCI For This Useful Post:
6stringmason (06-10-2014), stacker (06-10-2014)
Old 06-10-2014, 06:22 PM
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 914
W8X18 is a steel beam term.
I don't quite know what to make of the detail as shown, it makes no sense.
www.gebcon.com
tgeb is online now
Trade: masonry
Thank you for the quick response!
Visit our website @
Old 06-10-2014, 06:23 PM
Trade: masonry
Same to me.
Visit our website @
The Following User Says Thank You to 6stringmason For This Useful Post:
tgeb (06-10-2014)
Old 06-10-2014, 06:25 PM
QCCI's Avatar
Rewards Points: 952
It is very typical for overhead door opening. There may be another page with lintel details. But most likely it will have a plate welded to it at the bottom.
QCCI is offline
Old 06-10-2014, 07:26 PM
JBM's Avatar
Trade: Masonry
Rewards Points: 9,330
It would be so much easier if people used precast beams up north.
JBM is offline
Old 06-10-2014, 07:43 PM
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
That is a very common detail. Couple ways this detail can go depending on the steel. The height and width of the steel and if there is a flange welded to the bottom.
Assuming the steel is 8" tall. And you're using regular CMU. Order some 2" or 3" block, depending on what will fit. Lay the block on each side. If using a decorative block and depending on how many you need. Cut the block into slabs.
If the steel is 16" talk double your order. If it is 12" tall. Lay one course of the slabs on either side and a course of KOBB upside down for the second course. Also be aware that there is mostly likely Nelson studs welded to the top to add additional reinforced cells above the opening.
NJ Brickie is offline
The Following User Says Thank You to NJ Brickie For This Useful Post:
superseal (06-10-2014)
Old 06-10-2014, 07:47 PM
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Traditional precast isn't readily available is very long lengths in many areas. Around here 144" is the longest length stocked at yards. I've used the precast bond beams in 24' lengths but they had to be shipped from the DC area. Steel is readily available and not hard to work with.
Old 06-10-2014, 07:52 PM
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Also if there is additional reinforced cells above the opening. Pay particular attention to isolating those cells so that the grout does not run into the beam and blow out block.
Old 06-10-2014, 08:50 PM
Renaissance Man
superseal's Avatar
Rewards Points: 5,816
Brickie is spot on. Flashing these details can be critical as well.
supersealconstruction.com
superseal is offline
Old 06-10-2014, 09:49 PM
JBM's Avatar
Trade: Masonry
Of coarse, thats the problem , its not available. It is so much easier to pop them in.
JBM is offline
Old 06-10-2014, 10:05 PM
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 530
We call those "soaps." You will have to lay those one day, then let them set overnight before grouting. Usually, we would lay one course of the soaps, the turn a bond beam upside down for the second course. Still allows access for grouting.
cdkyle is offline
Old 06-10-2014, 10:37 PM
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,249
Ask the architect/engineer to review the drawing and consult with his Masonry "Rabbi"
That detail is ca ca.
Ungrouted soaps on the W beam, # 5 bars 2-4" above W-beam, Nelson studs as needed drive on.
Fouthgeneration is offline
Old 06-11-2014, 03:16 PM
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Can a precast lintel be engineered at 20'+ lengths and still be easy to pop in? I'm only guessing, but I would imagine very long lengths would increase the height and width. I'm wondering what the pounds per foot would be compared to steel. Does the ease of using precast go away at very long lengths?
I do prefer using precast for most openings. But I think it has it limitations.
Old 06-11-2014, 03:17 PM
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
Letting them sit overnight is ideal. But not always possible and there are ways around it.
Old 06-11-2014, 03:48 PM
JBM's Avatar
Trade: Masonry
17'4" are popped in for garages down south without much fuss but 20 foot length not too sure about.
But for commercial 10 foot bays it would be so much easier and a better final product me thinks.
JBM is offline
Old 06-11-2014, 05:52 PM
Trade: Masonry
NJ Brickie, NEVER seen the soaps grouted or re-bars place inside soaps on a W-Beam. Would you weld Nelson studs to both sides of the bottom of top flange & the top of the top flange for bonding?
Old 06-11-2014, 07:45 PM
Tscarborough's Avatar
Rewards Points: 1,456
Soap it in, soft joint above.
Tscarborough is offline
Old 06-11-2014, 09:32 PM
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
I was thinking about this a little more. I haven't run into very many situations where having longer (20'+) would be a useful option. The larger opening are mostly on exterior walls. Which is a decorative block or has a veneer 90% of the time.
JBM (06-11-2014)
Thread Tools
Rate This Thread
Framing question glkirk Framing 17 12-15-2012 02:32 AM
Question on re-decking prices!! RHS Design Roofing 1 12-08-2012 08:48 AM
Panel Question? HVACinChicago Electrical 16 08-03-2012 09:46 AM
Question on Foam board over Block stupidcat69 General Discussion 0 07-19-2012 02:32 PM
fastening to block question shazamyman Framing 16 05-05-2008 10:54 PM
