Pump Jacks For Bricklayers? - Masonry - Contractor Talk
Old 12-12-2009, 06:39 PM   #1
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 662
I was on a job a few weeks ago, and the bricklayers had just finished up. They were gone, but their scaffold trailer was still on site. All that was on it was a bunch of 16' planks and pump jacks. I wish I had seen them set up. Is it really possible to lay brick off pump jacks? BTW this was the biggest residential masonry outfit in the country.
artisanstone is offline
Old 12-12-2009, 07:23 PM   #2
KemoSabe
loneframer's Avatar
Rewards Points: 12,218
Re: Pump Jacks For Bricklayers?
I use pump jacks for everything from framing/sheathing to papering and installing windows/siding. Why not lay brick? The only drawback is the weight limitation. I don't think I'd put a very big load of mudpans and brick on the work table.
loneframer is offline
Old 12-12-2009, 07:26 PM   #3
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
aluminum planks and fresh mud don't like each other
Tom Struble is offline
Old 12-12-2009, 08:19 PM   #4
KemoSabe
loneframer's Avatar
maybe so, but you can get 'em used cheap at Fazzios when they have mortar on them.
Old 12-12-2009, 09:35 PM   #5
Trade: siding
Rewards Points: 20
i have enough trouble liftin the clean ones i got
Old 12-12-2009, 09:37 PM   #6
KemoSabe
loneframer's Avatar
Heck yeah, I have a 2 man 28'er, 12 wide that will shorten you up by an inch when you lift it.
Old 12-13-2009, 02:00 AM   #7
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
You will never catch me laying brick off of pump jacks. A repair job is one thing. Biggest residential outfit in the country?? They are going to take the risk of a substantial OSHA fine to save a few bucks if any and not build proper scaffolding? What a joke!! No brick is worth my life or well being.
NJ Brickie is offline
Old 12-13-2009, 02:55 AM   #8
solar guy
naptown CR's Avatar
Trade: solar contracting
Rewards Points: 1,000
I have seen large commercial brick and block jobs where the scaffolding appears to be similar to pump jacks. I know it is a different animal but could be confused by some.
naptown CR is offline
Old 12-13-2009, 11:10 AM   #9
Trade: Stonemasonry
Rewards Points: 662
They were all loaded on the trailer, so maybe I didn't see them right. Definitely no scaffold frames, crank up frames, etc. I couldn't find any info on the web.
Old 12-13-2009, 11:21 AM   #10
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
It might have been either Non-Stop scaffolding or ezscaffold, sort of similar, and they are sort of like pump jacks...they crank with a steel cable...nice setups, everything is always belt high, thigh high, wherever you want it....really nice setups, but you really do need a lift to work with these.....nonstop has a new setup called workhorse, for lowrise apps, looks pretty good...is that McGee brothers you saw artisan? I know they're big down in those parts.....
Rockmonster is offline
Old 12-13-2009, 12:14 PM   #11
Trade: Stonemasonry
Rewards Points: 662
Yeah, it was McGee.
Old 12-13-2009, 07:40 PM   #12
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
This stuff? I would love some.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
The Following User Says Thank You to CJKarl For This Useful Post:
DJ9222 (12-14-2009)
Old 12-13-2009, 07:52 PM   #13
Working
Cole82's Avatar
Rewards Points: 2,276
What is that called I MUST get some.
EDIT:
found it
http://www.nonstopscaffolding.com/
The boss of awesome
Cole82 is offline
Old 12-13-2009, 10:30 PM   #14
Trade: Masonry
That's Non-Stop, outta Louisiana. I've got one setup, although it rarely gets used. Pipe staging is more agreeable for most of my stuff nowadays, but it is well thought out and very nice...
Pump Jacks pt. 2, searched the forum, no luck on WERNER vs. ALUMA-POLE jordanski Finish Carpentry 10 04-16-2009 06:54 AM
Exterior grade sump pump? Jeeper1970 Plumbing 1 12-27-2008 10:16 AM
myson controller pump 3 port?? big moo Plumbing 1 09-02-2008 02:48 PM
Pump Jacks 1967 chevell Roofing 6 05-23-2008 05:26 PM
aluminum pump jacks fieldsj Tools & Equipment 0 01-31-2008 07:34 PM
