Polyurethane Foundation Repair Injection Kit? - Masonry - Contractor Talk
Old 11-26-2018, 07:48 PM   #1
BrooklynBravest's Avatar
Trade: Carpentry - Welding/Fabrication
Rewards Points: 804
Framing a basement and it turns out they have a large crack from floor to ceiling that seems to be seeping water.
Its for a family friend so I told them i'll take a crack at using the DIY repair kit if it saves them a buck.
Any recommendations on which brand is the move? I am on amazon and theres just too many choices ranging from $100-500.
BrooklynBravest is offline
Old 11-26-2018, 08:22 PM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 12,779
Re: Polyurethane Foundation Repair Injection Kit?
For a non-structural crack fill, use urethane. I don't know the products, but the basic is to add some injection ports, patch the remainder of the crack (inside and out), and fill it bottom to top.
I have a gallon of Stratathane ST-520 I never used, along with some ports. If interested, PM me and maybe we can work something out.
MarkJames is online now
Old 11-26-2018, 09:08 PM   #3
tgeb's Avatar
Trade: Excavation, Foundation, Professional Painter!
Rewards Points: 710
https://www.concretenetwork.com/conc...urethanes.html
Some education.
There are plenty of products/systems out there, making the choice is up to you.
Search crack injection you'll get a lot of results.
www.gebcon.com
tgeb is online now
The Following User Says Thank You to tgeb For This Useful Post:
greg24k (11-27-2018)
Old 12-05-2018, 05:43 PM   #4
Designer/Contractor
Rio's Avatar
Rewards Points: 1,490
We've got a similar situation, 8" wide concrete tilt up buildings with hairline cracks that are going all the way through, non structural so it looks like polyurethane injection will work.
Found a company called Emecole that has a good product, it has a removable sealant for the inside of the wall that is stripped off after the product is applied on the outside. The ports should be every 4-6" which is okay, the surface needs to be dry to attach the ports, can be done with a heat gun, it all sounds good but it's a little pricey, almost $500.00 for about 40' of cracks.
Does anyone know of a similar product that is a little less expensive or is this pretty standard for concrete crack waterproofing?
Rio is online now
Old 12-05-2018, 07:50 PM   #5
hdavis's Avatar
Rewards Points: 7,374
I haven't seen a cheap repair kit yet. It's chraper if you put together your own kit, which is a PITA.
hdavis is offline
Rio (12-05-2018)
Old 12-08-2018, 11:36 AM   #6
natural1's Avatar
Trade: Landscape contractor
Rewards Points: 394
Krystol repair grout should do the job. Made by kryton.
https://www.kryton.com/products/krystol-repair-grout/
Mike
http://www.natural-designs.com
natural1 is offline
The Following User Says Thank You to natural1 For This Useful Post:
Rio (12-08-2018)
Foundation Repair JBM Masonry Picture Post 2 07-18-2013 09:36 PM
How not to repair a joist! BCConstruction Plumbing 13 05-07-2013 09:52 PM
Piers for foundation repair medusa Excavation & Site Work 13 01-28-2011 08:33 AM
Foundation repair (New business) Help! crosshair66 Business 10 05-18-2008 08:19 AM
