Polymeric Sand For Irregular Bluestone? - Page 2 - Masonry - Contractor Talk
Old 11-11-2010, 05:40 PM   #21
Tommy C's Avatar
Trade: Mason
Rewards Points: 250
Re: Polymeric Sand For Irregular Bluestone?
I'll be using the Gator Dust tomorrow. I hope this stuff gets hard, I'm a bit worried about, say, a woman walking on it in high heels and digging out a chunk of it. Also worried about callbacks.
Tommy C is offline
Old 11-15-2010, 03:48 PM   #22
Tommy C's Avatar
Trade: Mason
Rewards Points: 250
The application came out pretty nicely, although in SOME spots it is still really soft.
Question - is there any type of masonry cleaner I should AVOID, that will negatively affect the polymers?
Tommy C is offline
Old 11-15-2010, 04:25 PM   #23
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
The only problem with polymeric sand is time and exposure.
Not normal on real paver installations for many reasons.
Dick
concretemasonry is offline
Old 02-23-2011, 12:15 PM   #24
Natural Stone Fabricator
Vieczorek's Avatar
Trade: Stone Fabrication
For dry lay you need 1.5" thick flagstone or better.
Vieczorek is offline
Old 11-23-2011, 01:11 PM   #25
jthampt's Avatar
Trade: landscaper
Used Gator Dust as recommended by the manufacturer in a project composed of a patio and a connected walk way.... about 400 sq ft.
The Gator Dust set up slower than advertised though it was 60-70 degrees out when we set it up. The hose has a mist setting that was perfect for what was required. Once it set up the wider joints (~3 in.) were a little spongy, but ok. The narrower joints were rock solid in most places.
Fast forward 3 weeks and we had a gentle rain/drizzle two nights ago that lasted throughout the night, but no more than 1/4 in. total and no standing water.
The Gator Dust has turned to MUD. Dog prints in the joints now. The entire job appears ruined and I have about 700 sq ft more to do with about 5 tons of bluestone flag sitting on pallets waiting.
This is not what I expected with the amount of time that's passed since installation. If this is the norm then this product requires more maintainance than it's worth at $32 / bag.
Any advice or is the job scrapped. This stands to cost me thousands and possibly postpone the job until spring.
Help please!
jthampt is offline
Old 11-23-2011, 05:32 PM   #26
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 3,198
Now that you bring this back up, I also have a Question for you poly gurus.
I just laid an irregular pattern in a very shady area.
100% it will turn green.
Never used poly, I was always afraid of the haze. Sand or grit is always the norm.
I laid this very tight, from nothing to maybe 3/16 at most, so I would use the poly-sand, if...
My question; Can you power wash the algae and pollen off the stones without blowing out the joints?
If not, I may as well just use regular sand.
Sorry for the coat tail,
Thanks for the input,
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 11-23-2011, 08:32 PM   #27
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Help please!
3" joints are as big a problem as the failure of the dust. Tighten up...
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 06-28-2015, 02:45 PM   #28
Fivestarmason's Avatar
Trade: Masonry
I've used sand, screening and almost every type of poly I can get my hands on..... So here it is, 6 parts screenings-1part Portland . Apply like polymetric. Get paid, go home, don't worry about it
Fivestarmason is offline
The Following User Says Thank You to Fivestarmason For This Useful Post:
dom-mas (06-28-2015)
Old 06-28-2015, 06:44 PM   #29
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I've done the same
www.dominionmasonry.ca
dom-mas is offline
Old 06-28-2015, 06:48 PM   #30
Trade: Masonry
Ever had any issues? Here in NL the screening are a quite dark, I'm going to be experimenting with adding a dye to the screening/Portland mix to see if I can get any type of coulor change
Old 06-28-2015, 07:39 PM   #31
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I don;t do much flatwork, but I've never had any call backs. I should say though that I wasn;t using screenings but sand mixed with portland 5:1 or so
dom-mas is offline
Old 06-29-2015, 05:38 AM   #32
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
I used some poly made by quickrete and the sand was pretty large. Luckily I was regrouting a failing bluestone patio, worked like a charm. It was more like stone dust.
JBM is offline
Old 06-29-2015, 05:58 AM   #33
Nick520's Avatar
Trade: Mason
Rewards Points: 514
Alliance makes a great polymeric sand
Nick520 is offline
Bluestone flaming natural1 Masonry 26 11-05-2014 11:46 AM
Mortar Sticking to Bluestone fakie99 Masonry 13 03-03-2011 11:10 PM
Lylac bluestone adhesion problems mcgyverdc Masonry 5 08-02-2009 05:02 AM
Bluestone Path damage from roof drain Jamboy Masonry 2 04-30-2009 10:15 PM
bluestone rain cap steve22l Masonry 1 09-11-2008 03:43 PM
