Outdoor Fireplace Question - Page 2 - Masonry - Contractor Talk
Old 10-30-2012, 06:35 PM   #21
JBM's Avatar
Trade: Masonry
Rewards Points: 10,796
Re: Outdoor Fireplace Question
You only need 80 or so firebrick on edge and what maybe 120 if you lay them flat.
I think you would save yourself a lot of headache by prepping the footing and hiring a mason. It is foolish to think that you can mix mud and build a functional chimney and fireplace, let alone not have it look like an abortion.
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
dom-mas (10-30-2012)
Old 10-30-2012, 06:57 PM   #22
Tscarborough's Avatar
Rewards Points: 1,460
Refractory mortar is just that: Mortar. If you parge the inside with it, it will simply pop off. So, you have been given best practice, do what you want, because I for one do not give advice to those who only want to argue against that advice.
Good Day!
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
Old 10-30-2012, 11:24 PM   #23
Geiri's Avatar
Trade: Gardner
I don't want to argue against that advice. I know what is the correct way to do things.
I live in Iceland the price here for firebrick for this fireplace is 1000$ that is to high for the budget
So I looked into other ides. I have been wondering about Iron sides, tiles, cement etc...
Everything to keep the cost down
I can cut the cost to less than 200 if I go with tiles
Firebricks are just so expensive sold at 4 dollars a pice's 4 by 8 inces
I will post photos of this project as it evolves
Geiri is offline
Old 10-31-2012, 03:55 AM   #24
Stonemason
bytor's Avatar
Trade: masonry
Rewards Points: 638
What is the typical method of building a firebox in Iceland if not using firebrick?
If you did use tile, how would you adhere them? (i.e. what type of mortar would you use?)AND to what would you be adhering them? Simply adhering them to the concrete block would not work as the heat will transfer through and ultimately, as Tscarborough says, the blocks WILL fail.
Firebrick are expensive everywhere. That's just the cost of building a fireplace.
bytor is offline
The Following User Says Thank You to bytor For This Useful Post:
Geiri (10-31-2012)
Old 10-31-2012, 05:36 AM   #25
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 10-31-2012, 07:04 AM   #26
JBM's Avatar
Trade: Masonry
You need 80 if you lay them on edge for a 36" firebox. Thats only $320.
JBM is offline
Old 10-31-2012, 06:40 PM   #27
MasonryToronto's Avatar
Trade: masonry
MasonryToronto is offline
Old 11-13-2012, 08:07 PM   #28
Geiri's Avatar
Trade: Gardner
This is what this first Fireplace looks like. It is only stacked up no cementing yet..
All comments welcome this is a learning process
If you look inside the fireplace the roof is flat should I build it downwards in the front (1 or two 2 stoens) to keep the heat and smoke in the fireplace and allow the heat to stream more easily up the small chimney?
The back of the burn chamber tilts inwards to the fire and makes a smoke that is in parallel with the roof lower line.
Is it correct to think that the hotter the fire the more upstream and better exhaust in the chimney?
Geiri is offline
Old 11-13-2012, 08:18 PM   #29
That is fine until you put a fire in it. Line it with firebrick or watch it decompose quickly.
Old 11-13-2012, 08:23 PM   #30
Here is what you will have:
Geiri (11-14-2012)
Old 11-13-2012, 09:02 PM   #31
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I wouldn't worry too much about how the fireplace will draw. Unfortunately with outdoor fireplaces they are in an uncontrolled environment....outdoors. Wind acts in unpredictable ways and will cause even the best built fireplace to smoke on occasion. As T scar says tho, heat will ALWAYS cause concrete to deteriorate. You really NEED a fire resistant material in there so that the homeowner isn't pissing their money away.
www.dominionmasonry.ca
dom-mas is offline
Old 11-13-2012, 09:15 PM   #32
And FYI, that is after 2 (admittedly large) fires.
Old 11-13-2012, 09:28 PM   #33
lukachuki's Avatar
Rewards Points: 1,002
must of used the wrong brand of glue!
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 11-14-2012, 09:42 AM   #34
Geiri's Avatar
Trade: Gardner
There will be some sort of fire shield in it, Fire brick or other.
I did light a small fire in it and I got some smoke coming out in the front .
I thought maybe I would have to but stones under the top in the front to make the fireplace build up more heat and increase heat flow through the chimney.
Geiri is offline
Old 11-14-2012, 05:55 PM   #35
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
The design that you have built is definitely not the best. Heat and smoke both like to roll, when they hit a square area they sort of bounce around in weird ways and usually come out the face. A box with an open face and a hole on top is not the best firebox but the real problem is the wind and more importantly the fact that you have the same pressure at the face of the firplace as at the top of the chimney since they are both outside. The reason a fireplace indoors doesn't smoke outside is that it's almost always warmer indoors (higher pressure) than outdoors on days that you would have a fire. Outdoors it's the same both places. You could try to extend the chimney to get a better draw but you will always have down draughts
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
Geiri (11-14-2012)
Old 11-14-2012, 07:11 PM   #36
Geiri's Avatar
Trade: Gardner
I will keep posting pictures as the project goes on. There is a throat and a smoke shelf in that fireplace ... I am thinking of lovering the opening at least one stone down. I might widen the throat opening a bit.
still a long way to go.. thank you for your advice and input guy's
Geiri is offline
Old 11-14-2012, 08:26 PM   #37
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
a smoke shelf won't do much in an out door FP. A smoke shelf does not do what count rumford thought it did, it does not "bounce" smoke back up the chimney but it does work as a restriction, creating a venturii effect increasing flow/velocity. However all that only works in a still environment. With wind going into the FP opening and down the chimney (especially a low chimney) there is a huge amount of turbulence. I think that making the opening smaller/lower is probably not a bad idea, it should help to keep the wind out and particularlyhelp to keep the wind from getting into the throat.
dom-mas is offline
Geiri (11-15-2012)
Old 11-15-2012, 11:39 AM   #38
Geiri's Avatar
Trade: Gardner
I am still thinking of tiles inside the fireplace..
Maybe it's not going to work but I thought I would ask you guy's.
The idea is to build a Iron frame inside the fireplace spacing it 1" or 2" from the walls
Ether U shaped so you can slide the tiles in or L shape with a overlapping / Locking flat Iron welded or bolted in place to keep the tile secure..
In the space behind the tiles and Iron you could fill it up with none flamable glass whool to isolate the tiles from the stones...
Is this out of the question?
Geiri is offline
Old 11-15-2012, 11:56 AM   #39
I think you are working to hard to avoid the simple and obvious solution. I smell Homeowner.
Old 11-15-2012, 12:19 PM   #40
Geiri's Avatar
Trade: Gardner
No just looking for alternatives to firebrick tho I might end up having to use them.
If I get an idea I try to stick with it and work in solutions and be creative. I just see how the tiles would look classier than the firebrick
The firebrick sold here is around 8.6 x 4 inches and only an 1" thick is that sufficient?
Geiri is offline
New? Have A Question? Read This First. Seven-Delta-FortyOne General Discussion 58 07-31-2019 02:46 AM
I have a question about my truck loan VinylHanger Vehicles 23 06-08-2012 11:00 AM
Concrete repair question german Excavation & Site Work 22 05-17-2012 11:38 AM
