Opinion - Masonry - Contractor Talk
Opinion
Old 11-02-2018, 09:43 AM   #1
JBM's Avatar
Trade: Masonry
Rewards Points: 10,850
Opinion
I have a thin stone job coming up soon. It's on an interior chimney that looks like it should be in California. Its smooth stucco and painted white.
My question is, cup grind it with one of those vaccuum attachments or screw and glue cement board on it?
It's like 20-22 feet tall and around 600 sqft.
JBM is offline
Old 11-02-2018, 10:49 AM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Opinion
IMHO,the cement board reduces the chances of a problem down the line.As in the installation of most materials they are only as good as the substrate they go over.
fjn is offline
The Following 3 Users Say Thank You to fjn For This Useful Post:
AJobDunWell (11-06-2018), brickhook (11-15-2018), JBM (11-16-2018)
Old 11-02-2018, 10:58 AM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,398
Re: Opinion
Instead of cement board Is it possible to screw wire lath over It with a scratch coat?
Windycity is offline
The Following 3 Users Say Thank You to Windycity For This Useful Post:
AJobDunWell (11-06-2018), brickhook (11-15-2018), Fouthgeneration (11-02-2018)
Old 11-02-2018, 11:50 AM   #4
JBM's Avatar
Trade: Masonry
Re: Opinion
Sure I can do that as well
JBM is offline
Old 11-02-2018, 06:22 PM   #5
Renaissance Man
superseal's Avatar
Rewards Points: 5,836
Re: Opinion
I'm with windy...
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
cedarboarder (11-03-2018)
Old 11-02-2018, 08:06 PM   #6
Tscarborough's Avatar
Rewards Points: 1,460
Re: Opinion
Hardi backer is faster, easier, and cheaper.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
fjn (11-02-2018)
Old 11-02-2018, 08:32 PM   #7
Renaissance Man
superseal's Avatar
Re: Opinion
Lath is cheaper than hardie board and quicker to install...masonry stubs are cheaper than tapcons and as well, quicker to install. There's the scratch coat to consider, but being interior doesn't require a substantial base over lath...none at all actually...just lick'em and stick'em.
The Following 2 Users Say Thank You to superseal For This Useful Post:
AJobDunWell (11-06-2018), JBM (11-14-2018)
Old 11-02-2018, 09:30 PM   #8
fjn's Avatar
Trade: mason
Re: Opinion
I'm still sticking with the cement board. The stub nails and lath may be great over bare block,but not be long enough to get a solid bite through the stucco??
fjn is offline
Old 11-02-2018, 10:11 PM   #9
Renaissance Man
superseal's Avatar
Re: Opinion
I get stubs from 3/8" to 3"... mute point
AJobDunWell (11-06-2018), fjn (11-03-2018)
Old 11-03-2018, 06:11 AM   #10
Windycity's Avatar
Trade: Masonry
Re: Opinion
How are you going to anchor the cement board to the wall?
The Following User Says Thank You to Windycity For This Useful Post:
Old 11-03-2018, 06:12 AM   #11
Windycity's Avatar
Trade: Masonry
Re: Opinion
Originally Posted by superseal View Post
I'm with windy...
Thatís a pretty neat little magnetic nail holder thingy
AJobDunWell (11-06-2018), Fouthgeneration (11-03-2018), Rio (11-04-2018)
Old 11-03-2018, 10:46 AM   #12
JBM's Avatar
Trade: Masonry
Re: Opinion
I usually go tapcon with washer
JBM is offline
Old 11-03-2018, 10:49 AM   #13
test
cedarboarder's Avatar
Trade: General
Rewards Points: 1,815
Re: Opinion
You really find out what works when you have takin a couple chimneys down.
The old wire method is a huge pita to take apart. It works well .
cedarboarder is online now
The Following 2 Users Say Thank You to cedarboarder For This Useful Post:
AJobDunWell (11-06-2018), Fouthgeneration (11-05-2018)
Old 11-03-2018, 03:47 PM   #14
Windycity's Avatar
Trade: Masonry
Re: Opinion
You can say that again, thatís the most miserable thing tearing down a wall with that wire in it
The Following 2 Users Say Thank You to Windycity For This Useful Post:
AJobDunWell (11-06-2018), cedarboarder (11-04-2018)
Old 11-03-2018, 10:33 PM   #15
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,335
Re: Opinion
If its bone dry/interior work, I use TAPERED masonry nails with a stucco washer after hammer drilling a partial pilot hole, far cheaper then tapcons, no screwing around.... make sure the nail heads aren't too proud and waste scratch coat mortar.
you can use screws on the first few fasteners...
Make sure you hang the mesh the right direction with the spacing dimples to the old work.
If it is Real thin veneer stone, make sure the units are CLEAN of all saw dust and BONE dry, some units still might need anchors, especially the corners.
Fouthgeneration is offline
Old 11-04-2018, 05:09 PM   #16
fjn's Avatar
Trade: mason
Re: Opinion
First have to identify the backing,wood or masonry. If wood,screws,if block,tapcons
fjn is offline
Old 11-05-2018, 09:10 PM   #17
Trade: Masonry
Re: Opinion
If the Stucco/plaster is sound and the paint well bonded, you might consider adhering the NVT stone with adhesive products to the existing, and grouting the joints if required with bagged delivered mortar.
Old 11-14-2018, 09:01 PM   #18
JBM's Avatar
Trade: Masonry
Re: Opinion
The paint is like the day it was put on....I'm wondering if I rolled on https://laticrete.com/masonry-veneer...-water-barrier couldn't I stick on the rocks after.
My paranoia says no, but I'm missing the science part...
JBM is offline
Old 11-14-2018, 09:16 PM   #19
Renaissance Man
superseal's Avatar
Re: Opinion
Use Em-Cryl600
Em-Cryl 600
Acrylic Latex Fortifier
For Cement and Gypsum Mixes
Interior and Exterior Use
MANUFACTURER:
Empire Blended Products, Inc.
250 Hickory Lane C Bayville, NJ 08721
(732) 269-4949 C Fax (732) 269-0497
www.empireblended.com
PRODUCT DESCRIPTION:
EM-CRYL 600 is a non-reemulsifiable, architectural grade, modified acrylic latex admix for Portland cement and gypsum based mixes. EM-CRYL 600 has been formulated to enhance performance by improving the strength, flexibility, adhesion, water resistance and curing properties when added to mixes.
USES:
EM-CRYL 600 is the gauging liquid for EMPIRE BLENDED FLOOR ALL and the bonding liquid for EMPIRE BLENDED SEAL MASONRY COATING when applied over dense or previously painted concrete or masonry. It is used in many other EMPIRE BLENDED products such as SURFACE BONDING CEMENT, FOUNDATION COAT and THIN SET, as well as in:
Repointing mortars
Bedding mortars for tile, brick, flagstone, etc.
Pool, pipe and tank lining
Stucco, thin set and terrazzo
Thin overlays to patch, level, and resurface existing floors and walls
JBM (11-16-2018)
Old 11-14-2018, 09:45 PM   #20
JBM's Avatar
Trade: Masonry
Re: Opinion
Probably can do more than one easier method. I always go back to, if you think a Good Mason is expensive, hire a bad one. I'm essentially terrified not to do the best I can, always lol, first world problems...
JBM is offline
The Following 2 Users Say Thank You to JBM For This Useful Post:
fjn (11-15-2018), Idothat (11-15-2018)
In Your Professional Opinion, How Stupid Is This? Seven-Delta-FortyOne Tiling 39 04-20-2014 11:51 PM
Need an opinion from door guys. workingintx Windows, Siding and Doors 24 01-28-2013 10:47 AM
New DeWalt 716 First Day Opinion. MF Custom Tools & Equipment 25 07-08-2012 09:46 AM
advice or opinion on finish guns Sampietro Tools & Equipment 27 03-05-2012 11:24 PM
need 2nd opinion on exterior stair trim issue jordanski Finish Carpentry 1 03-15-2009 04:15 AM
