New Method Of Propping Wall. - Masonry - Contractor Talk
Old 12-03-2019, 07:16 AM   #1
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,268
Saw these in a trade mag today. Advantage over needles seems to be you don't need to go right through the internal masonry. This means no moving of baths,rads, fitted wardrobes and damage to floors etc.
Is there anything similar used in the USA?
https://www.sneedleprops.com/
stuart45 is offline
The Following 2 Users Say Thank You to stuart45 For This Useful Post:
fjn (12-03-2019), SmallTownGuy (12-03-2019)
Old 12-03-2019, 08:12 AM   #2
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,798
Re: New Method Of Propping Wall.
Personally I donít really see the advantage of that, it looks like whatever you need to do to the exterior of the masonry wall those damn things are going to be in your way and i would rather just use post shores with a longer beam and go all the way through
For example in this picture there is no reason to have 3 of these things in this small opening where shoring probably isnt even needed at all to put that beam in, if shoring is necessary you could simply just run one right in the middle
Windycity is online now
Old 12-03-2019, 10:27 AM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Here is another U.K. device I stumbled upon several years ago,it seems way more handy and less obtrusive.
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
cedarboarder (12-03-2019), SmallTownGuy (12-03-2019)
Old 12-03-2019, 11:30 AM   #4
hdavis's Avatar
Rewards Points: 2,124
I love it!
hdavis is online now
Old 12-03-2019, 12:28 PM   #5
Windycity's Avatar
Trade: Masonry
https://www.youtube.com/watch?v=hQJ8AuWfPWw
I saw that one a while back as well and thought it was pretty cool but I think the span only goes to 4 1/2 feet or something
If the masonry is bad enough to require a 4 foot opening to be supported I donít know if I would trust putting a couple lag bolts in the mortar above it to hold it all together! Haha
Although that would be pretty nice for something like a common brick opening where they are going to fall no matter what, but usually with openings like that I just pyramid the opening up And just have a couple extra Brick to fill-in
I really donít know if that would save any time or not
Old 12-03-2019, 01:38 PM   #6
stuart45's Avatar
Trade: Brickwork
I can see the advantage when doing an extension. A lot of extensions here require a knock through where much of the rear wall is taken out. When the steels are placed below the ceiling joists, it's not so much of a problem. However a lot of people don't want a beam in the middle of the room showing, so to get it level with the ceiling means putting needles through the exterior brickwork, through the interior brick or blockwork with props going through the floor to pick them up.
This means that with the needles coming through into the room above anything there such as a bath etc needs to be removed and out of action for a while.
With these props the rooms upstairs are left untouched.
stuart45 is offline
Old 12-03-2019, 05:52 PM   #7
fjn's Avatar
Trade: mason
Yeah I hear you Windy, think they actually span 6 ft.,still not much.Between the hassle of trying to source them ,I think I would just weld some up in my shop to accommodate the size I need.
fjn is offline
Old 12-04-2019, 07:29 AM   #8
stuart45's Avatar
Trade: Brickwork
In general people in the UK are less likely to make things up themselves.
Must be the old pioneering spirit in the USA.
The main worry isn't so much the external brickwork, although it's better to keep it in place, but the load bearing inner blockwork(often AAC) or brickwork from moving, as this causes cracking in the plaster, tilework etc. Blockwork always seems more likely to drop than the face brickwork.
stuart45 is offline
Old 12-04-2019, 06:58 PM   #9
fjn's Avatar
Trade: mason
I cannot even begin to count the "things" I have fabricated for various needs. Also,I would certainly not rely on one of those "gadgets" to prop a multi wythe wall.One for inside,one for out.
fjn is offline
Windycity (12-04-2019)
Old 12-04-2019, 11:36 PM   #10
Windycity's Avatar
Trade: Masonry
Exactly why i learned to weld!
Old 12-05-2019, 07:00 PM   #11
fjn's Avatar
Trade: mason
You betcha ! I can do gas or electric,been dong it for 52 years.
I can fix anything with a welder but a broken heart.
fjn is offline
