New Construction: Hearth Extension - Masonry - Contractor Talk
Old 11-07-2018, 10:20 AM   #1
Willin's Avatar
Trade: Retired
Rewards Points: 434
A freestanding woodburning fireplace will be built in a new house. Fieldstone faced, faces greatroom, one can walk around all four sides.
Foundation below basement floor is a 'crete pad, and a 4 sided column of 6" CMU rises to the main floor. The hearth and fireplace construction begins at that level.
Rather than a cantilevered slab for a base for the desired hearth extension, can the 12" hearth be supported on the wood-framed floor structure?
The mason proposes to cover the floor structure with felt paper, then lay a course of CMU on that, and do a stone hearth finish atop that.
Willin is offline
Old 11-07-2018, 06:21 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 10,154
Re: New Construction: Hearth Extension
Can it be ? Of course. Is it proper ? H no !
fjn is offline
brickhook (11-15-2018)
Old 11-07-2018, 09:21 PM   #3
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 7,829
Every open/ glassed in face will need a inflammable surface for 18-24" from the face(s) of the fireplace.
Raised hearths are silly IMHO, they shrink usable floor space, you could use 1/2 arches that spring from the fireplace's basement structure + rebar.
Is the basement footing acting as the ash dump and cold air supply path???
Did you plumb in a gas pipe for use as you age? or in power outages???
Multi opening fire places rarely are very efficient.....
I'd want to see a near exact copy of the planned fire place that worked or a 200% guarantee/bond, money for DEMO and replacement with a working design in an occupied home
Fouthgeneration is offline
Old 11-10-2018, 10:17 PM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 8,326
If you formed and poured 10- 12" of concrete over the floor, with paper under it, its ok, kinda hack but its do able.
If it isnt continous into the firebox area, itll crack at the joint @ the hearth.
JBM is online now
Old 11-11-2018, 06:52 PM   #5
Trade: Masonry
Tact down METAL under the concrete, any cracks open up in the next 100 years the hot cinder lays on metal, not the wood subflooring.....
IMHO raised hearths are just a brain fart hanging around from 10 Cent tract homes of the late 40s - 60s. where they X-out the under floor hearth structure to save time/money...
Few rooms are large enough for center of floor fireplace IMHO. If yours is, go for it.
Is the stone work being used as "Trombe" heat storing wall?
Don't let a lazy mason,
((6" CMUs fpr 30' plus of fireplace-chimney?=cheesy)+ poured on top of basement slab footing???= double cheesy IMHO))
shrink your room up. And install a gas line and cold(unheated outside) air supply to the firebox to lower the cost of actually having a fire/flame in the firebox
Old 11-20-2018, 11:24 PM   #6
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 134
Cantilevered hearths have worked for decades w/o issue if done decently. Laying masonry over (presumably) OSB subfloor has a less stellar track record. Not sure this is the place you want to cut a few dollars out on an otherwise expensive fireplace..........
jomama is offline
The Following 3 Users Say Thank You to jomama For This Useful Post:
fjn (11-21-2018), Fouthgeneration (11-21-2018), stuart45 (11-23-2018)
Commercial Construction NJ IM Contracting New Member Introductions 1 07-23-2015 06:37 PM
Construction Project Design Criteria rpurnell General Discussion 4 04-07-2013 09:25 PM
Extension Cord Deal GRB Tools & Equipment 6 05-30-2012 07:33 PM
Did you know Microsoft has Financial and Operational Software for Construction bdupper Accounting Software & Discussion 0 06-12-2009 08:25 AM
Construction vs. Manufacturing. Who wins? poole_3 General Discussion 10 04-04-2009 07:51 PM
