Need More Light. - Masonry - Contractor Talk
Need More Light.
Old 02-18-2010, 11:51 PM   #1
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Need More Light.
I was asked to fill in some ware house doors with block to help seal up an old ware house in town. The existing garage style doors have two roughly 16 X 32 windows that let a lot of natural light into a fairly dark interior. The owner would like to retain the natural light by using some glass block basically in the same layout as the existing windows.
The openings are 7'6" wide and 88" tall. I priced glass block and pre assembled panels. Panels are about $70 and the glass block are $8 ea. I haven't laid a lot of glass block, but I know they are a pain. I thought the block price was way high as the pre assembled panels were about the same as the raw block.
Any ideas that I am not thinking of here. I plan to weld 4" X 4" angle back to back and make a lintel and lay bond beam upside down for the header. No real weight issue, just need an opening. I could evenly space 2 glass block in every other course to help spread the light out. Open for more and better ideas. I got the job, cost is always a consideration so forget the glow in the dark, thermally activated, flashing CMU's.
I did a drawing with sketch up that looks pretty good, but I can't figure out how to post here. Any help would be appreciated on this front as well.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 02-18-2010, 11:55 PM   #2
lukachuki's Avatar
Rewards Points: 1,002
Re: Need More Light.
Take a pic with a camera or scan the sketch then just upload it to tinypic.com and then cut and paste the [img] code they generate for you into your post.
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 02-19-2010, 12:19 AM   #3
dakzaag's Avatar
Trade: mason
Rewards Points: 786
I use photobucket. Tried uploading the file, but photobucket doesn't recognize the skp files. Tried saving it as a photo, didn't work. Trying to scan without printing.
It's not that great of a picture, and this is about as simple as it gets for describing a potential project. Just trying to learn how to use my computer mo better.
D K & Sons
dakzaag is offline
Old 02-19-2010, 12:21 AM   #4
lukachuki's Avatar
ahh so you used sketchup....great program.
hmm let me think.
Old 02-19-2010, 12:26 AM   #5
lukachuki's Avatar
Ok real simple...just did it myself in sketchup. Instead of using the save as function use the export and 2d like the picture shows. This saves a png file which can be uploaded to photobucket.
Old 02-19-2010, 12:52 AM   #6
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Thanks Tim, looks like that is going to work. Although my sketches are a little small. Loading now.
Random Glass block
Traditional window style
Nuts, I forgot to resize them. Sorry about the wide screen.
I'm not exactly an artist yet, but you get the idea.
D K & Sons
dakzaag is offline
Old 02-19-2010, 12:54 AM   #7
dakzaag's Avatar
Trade: mason
Rewards Points: 786
How did you capture and post your screen like that?
I need to get to bed, its 1 am already.
D K & Sons
dakzaag is offline
Old 02-19-2010, 12:58 AM   #8
lukachuki's Avatar
Just use the printscreen button on my keyboard.
One of those buttons with the dust on it.
Old 02-19-2010, 01:06 AM   #9
dakzaag's Avatar
Trade: mason
Rewards Points: 786
I can't quite reach that from here, would you mind giving me a hand?
oops, did we just break a forum rule...?
Shhh...I hear Joasis coming, this is not going to end well.
If I am banned for life, remember this.
"Life has its ups and downs, but this I know. Focus on the donut, not on the hole." Ron S.
Turn out the light Gracie
D K & Sons
dakzaag is offline
Old 02-19-2010, 03:55 AM   #10
JD3lta's Avatar
Trade: Stone Masonry
Rewards Points: 156
"Capturing Screen images in windows": (at least in Vista), click the Start button, and type Snipping Tool (in the Start Search box). Before your done typing it should already show up. It's very versatile and easy-to-use. That drafting program looks promising!
JD3lta is offline
Old 02-19-2010, 08:21 AM   #11
Tscarborough's Avatar
Rewards Points: 1,450
Hold down the control key, then hit the prt sc button. Open the windows paint program, then hit control and V key.
Tscarborough is offline
Old 02-20-2010, 06:49 PM   #12
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Ok, thanks for all the tips on how to run a computer.
Back to the topic, any other ideas for additional light in a block wall?
D K & Sons
dakzaag is offline
Old 02-20-2010, 09:38 PM   #13
stacker's Avatar
Trade: masonry
Rewards Points: 542
i like the 2nd design more than the first one.i think it is more practical,and would allow for more light.i know that doesnt make sense,since more than likely there will be the same amount of glass block.
stacker is offline
Old 02-20-2010, 09:43 PM   #14
NJ Brickie's Avatar
Trade: Bricklayer
Rewards Points: 750
First thought I had was screen block, any design, with plexi-glass on both sides. I do not think I would like how it would look, but it would work.
NJ Brickie is offline
Old 02-21-2010, 02:10 PM   #15
JD3lta's Avatar
Rewards Points: 156
In my opinion the random glass block would work better. An analogy would be driving behind a trucker. His vantage points from the mirrors have 'blind spots'. If you agree with that, then I'm guessing the RGB idea would offer more coverage.
JD3lta is offline
Old 02-21-2010, 06:47 PM   #16
4th generation's Avatar
Trade: Masonry
Rewards Points: 75
The style of glass block that you use makes a difference, some are more opaque than others, and also which way the window/panel is facing + the time of day. Here is one that I put in the bathroom that I'm renovating in my own house.
From another angle
These are the type that I'm going to use for the back of the shower stall
4th gen
4th generation is offline
Old 02-21-2010, 08:56 PM   #17
Personally, I hate glass block. How about cutting random holes in the wall then filling them with stacked sheets of glass laid perpendicularly to the wall.
Leaky Roof & Cool Light Globe dougchips Off Topic (Non Trade) 4 01-28-2009 12:05 AM
How many forum posters does it take to change a light bulb? woodbutchr Off Topic (Non Trade) 15 01-22-2009 08:16 AM
How many forum members to change a lightbulb? Al Truistic Off Topic (Non Trade) 48 11-09-2008 01:46 AM
2 circuits controling a light TNRocks Electrical 4 01-28-2008 09:22 PM
How many members of CT does it take to change a light bulb? Bill Off Topic (Non Trade) 19 01-05-2008 01:13 PM
