Need A Favor.... - Page 2 - Masonry - Contractor Talk
Need A Favor....
Old 03-24-2015, 09:54 PM   #21
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Re: Need A Favor....
Originally Posted by superseal View Post
I still think the front door is worse than the stonework
Agreed I figured it's a temporary, until the ordered one arrives? Looks like interior door. But I'm just a Mason.
heavyc is offline
Old 03-25-2015, 05:14 PM   #22
fjn's Avatar
Trade: mason
Rewards Points: 10,524
Originally Posted by 6stringmason View Post
I cant say enough that hes a hard worker, fixes things without being asked on his own time(though I tell him to add the hours but he wont), and doesnt complain about weather, long days, or much of anything.
Then hold on to him with both hands. He has many positive attributes. Stick with him and work along side him,you can correct the skill deficiencies because he seems like a good guy and willing to learn. The bad attitudes are the aspects of a worker that are most difficult to correct. This guy is worth your effort IMHO.
fjn is online now
Old 03-25-2015, 07:15 PM   #23
Texas Wax's Avatar
Rewards Points: 1,642
Dunnage (sic?) door.
Was quite common in southern WI, in 6 strings neck of the woods maybe still. Boys in da nort woods hang on to the 'older' ways longer LOL
Texas Wax is offline
The Following User Says Thank You to Texas Wax For This Useful Post:
6stringmason (03-28-2015)
Old 03-25-2015, 10:30 PM   #24
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
6,
First off, yes you can sell that wall. I applaud you for not settling for ok and pushing your guy to be a great mason. Way too many guys out there who are just happy to get the check and move on.
The pillar on the right gets pretty wonky, but it might be the camera angle. Zipper joints every where, but the stone is small, so that is tough to control. My biggest beef is the coursing of random stone. Bed joints need to be broken up just as much as head joints on random stuff and this job is more like brick than stone.
It's kinda funny how in a tight area we think there is no way to screw it up and then when we get done, it looks like there is no way to do it right.
Three rules on stone work will cure most of the problems we see everywhere.
1. Keep it level and plumb (I like to use a string or snap a line to help keep odd shape stuff in line, admittedly the adhered stuff follows the wall so not much you can do there.)
2. Stack one on top of two. (Some ledge stone can be stacked once in a while, but don't make a habit of it.)
3. Break up your head and bed joints.
If you follow these rules, you just end up with nice looking work.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 03-25-2015, 10:38 PM   #25
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Did you run short on stone? Seems like a lot of small stuff ended up around the door, where are the bigger pieces.
If the guy left stone in the box, but was working too hard to use up every last piece, that's a problem. Conversely, if you were down to the last box and had to use every piece on the ground then whoever ordered the material needs to be talked to.
There could be more to this picture than meets the eye...
D K & Sons
dakzaag is offline
Old 03-26-2015, 06:05 AM   #26
heavyc's Avatar
Trade: masonry
Rewards Points: 945
So how did your employee take the criticism?
Exactly how long has he worked for/with you?
I'm assuming that was not his first solo attempt. The biggest problem/issue with our trade is no younger generations are interested in working hard for their money.
At least in heavy commercial side of masonry. We are contracted to only work journey men level and above. No apprentice level work can be performed.
heavyc is offline
Old 03-27-2015, 12:05 AM   #27
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,111
Lots of good advice, my 2 cents is that you and him didn't pick a bond and stick to it, some panels the bed joints travel through, others they quit ~3 feet, Random coursed ashlar vs coursed ashlar maybe? stack joint in inside corner brakes illusion of full bed stones... the manufacturing/sawing of the NVT favors smaller pieces then full bed. The stone supplied doesn't have the correct ratio of heights IMO.
Keep any thin bed products off the the 3-D piers and arches, it would be cheaper to get full bed product to use on the 3-D fixtures.
Some have an eye for stone work some don't, the semi- coursed bonds IMO are the toughest to keep consistent, most of my jobs I can tell where I started, the rest blurs together.
Fouthgeneration is offline
Old 03-27-2015, 03:26 AM   #28
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 2,876
Originally Posted by dom-mas View Post
Don't know why there isn't a sill under the door...
Not on your helper, but on a side design note, if I may...
Regardless of whether the door slab is being changed out, a piece of bluestone, (or any type of kick board, for that matter), would have gone a long way to anchor the entry door assembly and even, hopefully eliminate the stackers on the right.(Ok, I guess that would be your helper)
On a personal note, I have absolutely no tolerance for cross intersections under any circumstances, let alone 3 on top of each other, that includes flat work, but then, that's just me.
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
The Following 2 Users Say Thank You to Diamond D. For This Useful Post:
6stringmason (03-28-2015), Fouthgeneration (03-28-2015)
Old 03-28-2015, 02:24 PM   #29
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
I agree on the intersections Diamond. When Im there if they put them I make them pull stone off and re do it.
They didnt send a very good selection of stone to begin with in my opinion. Not many jumpers at all, and many of the pieces were the 3 to 4 inch tall and 8-10" long. Not great to work with.
And yes, they always hang old doors on up here until the house is almost done. Save on knicks and dings when people are hauling material in.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 03-29-2015, 09:36 AM   #30
dbrons's Avatar
Trade: Masonry
Rewards Points: 608
Interesting discussion. Thanks for posting 6string. One thing I'll say first off is I build sample panels very frequently for homeowners or designers. I do it gladly because otherwise you risk having to tear down a job you've started when they decide they don't like it after all.
I would say I agree with the sentiment that this house is built of somewhat modest materials and so I think the work looks OK. I've had to work with very blocky, similar sized pieces which can lead to an issue when you try to break up the horizontal. Of course alternating the stones properly at the inside corner is very simple with these stones so that certainly should have been done.
One thing I've done with this sort of material is to get a different stone which matches but is much larger - I've used random sized pieces of flagstone - and stick one on the wall every so often then just cut your other stones into it. Makes a more interesting look.
Personally I don't like the edge of veneer stones showing on the left wall - maybe that should have stayed low wainscot height there. And the one thing I would probably make the guy take out is the notched stone at the very bottom left of the right side column. I don't like notched or pistol stones I don't like triangles either.
dbrons is offline
Old 03-29-2015, 04:17 PM   #31
dakzaag's Avatar
Trade: mason
Rewards Points: 786
I had a customer who loved pistol stones. (never called them that, but it is the perfect description.) The more of them she seen the happier she was.
I kicked myself for a week for putting the first one in.
D K & Sons
dakzaag is offline
Old 04-01-2015, 10:31 PM   #32
kingcarpenter's Avatar
Trade: G.C./carpenter
Rewards Points: 544
Door is a construction door. Why would anybody not put in a temporary door to be abused until house is much further along.
kingcarpenter is offline
Old 04-03-2015, 02:42 PM   #33
S.U.M's Avatar
Trade: Brick/Stone Mason
Rewards Points: 1,286
You would be surprised Sir, currently on a job where we built the brick veneer on the side and front of the
house, the $9000 door and frame was installed before we got there.
The brick is finished but still gotta do the stone. I asked for it to be covered but the g.c never did, got that request in an email.
S.U.M is offline
Old 04-06-2015, 11:37 AM   #34
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Ha, we call them "dog legs" or "pork chops" to be avoided at all costs.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Sometimes, it's best to decline a project. Sometimes, it works in your favor.... rdr8887 General Discussion 82 05-30-2012 06:54 AM
Quick Favor , can you check this out for me (Site Resolution) plazaman Websites and SEO 11 12-19-2011 03:37 PM
Any folks near Taucoma want to do a favor for me in the name of history? rosethornva Off Topic (Non Trade) 12 04-24-2011 12:24 PM
Need a Texas (Ft. Worth) sized favor. wizendwizard Windows, Siding and Doors 0 08-27-2008 08:32 PM
