Natural Stone Thin Veneer Vs Cultured Stone - Masonry - Contractor Talk
Old 02-20-2013, 05:37 PM   #1
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
For those of you guys who have installed both the "real" thing and manufactured, what if any time difference have you found.
I have to give a price to some customers who want thin veneer on their foundation. They aren't set on a product yet but they do know what style of stone they want. I want to give them a natural stone price and a cultured stone price but I've only installed the fake stuff. Does the natural stone take much longer to install or is it on par?
www.dominionmasonry.ca
dom-mas is offline
Old 02-20-2013, 06:44 PM   #2
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
Re: Natural Stone Thin Veneer Vs Cultured Stone
I have limited experience with both, so take it with a grain of salt...but, I saw little difference other than the natural is a little heavier and prices were the same.
Besides the fact it wasn't made of concrete, I also liked that I could chisel or chip edges of thin stone veneer to tighten up the fits, whereas you have to live with what you have with manufactured...because you end up exposing aggregate.
www.thewoodfiredenthusiast.com
stonecutter is offline
The Following User Says Thank You to stonecutter For This Useful Post:
dom-mas (02-20-2013)
Old 02-20-2013, 06:45 PM   #3
artisanstone's Avatar
Trade: Stonemasonry
Rewards Points: 662
It's slower. How much slower would depend on the pattern/style. The worst comparison would be the infamous "drystack style". In this case the Cultured has the huge advantage of being modular, while the NTV requires much chipping, etc. per piece.
The more favorable comparison would be a random polygonal pattern, with a mortar joint. The natural stone may actually be faster in this case.
I would say, for a ballpark, figure about a 30% decrease in production.
artisanstone is offline
The Following User Says Thank You to artisanstone For This Useful Post:
Old 02-20-2013, 06:59 PM   #4
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
the style they have in mind is square(ish) random rubble with varying sized joints, anywhere from 1/4"-3/4". I've already signed for the fireplace which will be done in the same style. Off the top of my head I had a 25% price increase in mind.
Can you use a chisel on the thin stuff? I've worked with thin stones before as flagstone so i guess it's about the same...mostly grinder with a chisel to finish
dom-mas is offline
Old 02-20-2013, 07:10 PM   #5
Trade: Stonemasonry
I have used a carbide hand chisel like this...
Or just use a mason hammer with the chisel end.
Old 02-20-2013, 07:19 PM   #6
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
When i do thin stuff i try to find 2 sides that "fit" and trim the rest if I need to. I rock almost every edge that I can. I trim off the stuff that is paper thin so that takes time. all of that takes more time.
JBM is offline
Old 02-20-2013, 08:02 PM   #7
Tscarborough's Avatar
Rewards Points: 1,460
I prefer adhered real stone hands down. It can be worked, so you spend less time putting the puzzle together, even if you end up cutting half the stones. I have a tiny fireplace to do on Friday, it would be impossible with faux stone because I will literally have to cut every piece. Plus it is cheaper around here because the stone is local.
Tscarborough is offline
Old 02-20-2013, 10:26 PM   #8
Mooman Master Mason or 3M
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
I've done tons of each and in various styles and in my opinion, its all relative. While its true, the natural stone is easier worked(but only because you can work it harder). You can do the same thing with the cultured(cut to fit), but I back cut it slightly and grind away to a scribed line, and maybe nip at it a little with the hammer. This allows the fitment without exposing the aggregate.
Heres a shot of the Natural thin...
Mooman is offline
Old 02-21-2013, 01:02 AM   #9
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
That looks pretty tight.
A close up shot would help us see it better.
What type of stone is that?
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
Old 02-21-2013, 08:22 AM   #10
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
The owner picked it out and had it delivered. I just showed up and installed it. I'ts granite....not sure what type exactly.
Mooman is offline
The Following User Says Thank You to Mooman For This Useful Post:
dakzaag (02-21-2013)
Old 02-21-2013, 02:18 PM   #11
stacker's Avatar
Trade: masonry
Rewards Points: 542
i think the only difference in time is the amount of time needed to allow grout to dry before it can be struck up.
the pictures included is of an 18'x 10' fireplace with natural thin stone.this was completed in less than 2 days.no help other than home owner helping with lifting mud and stone to me.
stacker is offline
The Following User Says Thank You to stacker For This Useful Post:
brickhook (02-21-2013)
Old 02-21-2013, 02:52 PM   #12
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
Stacker, is it the picture or is does that mantle look crooked? Must be an optical illusion.
Mooman is offline
Old 02-21-2013, 06:26 PM   #13
stacker's Avatar
Trade: masonry
Rewards Points: 542
optical illusion.the homeowner had a couple large cedars in his pasture and was going to take them to a mill to make his mantle.he decided to try it himself with his chainsaw.he did a great job,except that the one side of the mantle is thinner than the other making it look like it is out of level
stacker is offline
Old 02-21-2013, 06:42 PM   #14
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
stonecutter posteda pic of a FP he did that used a reclaimed timber from a barn. Same deal. Top was level but the timber was 10" one end and 9" at the other (or whatever), looked out of level even though the top was good
dom-mas is offline
Old 02-21-2013, 06:50 PM   #15
Hey! Whats wrong with using a chainsaw to cut a log. It matches the brickwork.
Old 02-21-2013, 07:01 PM   #16
Mooman's Avatar
Trade: Stone Mason
Rewards Points: 75
That is one sweet oven! I should bite the bullet and build one for myself.
Mooman is offline
Old 02-21-2013, 07:24 PM   #17
Trade: Stonemasonry
I did?
Old 02-21-2013, 07:26 PM   #18
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Originally Posted by stonecutter View Post
I did?
I think so. It was posted here. I'll try to find the post
dom-mas is offline
Old 02-21-2013, 07:29 PM   #19
Trade: Stonemasonry
Please do, I have no clue which one you mean.
Old 02-21-2013, 07:38 PM   #20
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Huh, maybe i was wrong and it wasn't you. I thought it was that one that you did for the older couple back in Connecticut(sp?) I'm going to keep looking
dom-mas is offline
Beveling cultured stone TheItalian204 Masonry 17 10-04-2011 05:07 AM
Cultured Stone vs- Stone question enforcer Masonry 26 06-16-2011 04:30 PM
Sill installation over cultured stone Moneypit Masonry 5 11-08-2010 11:55 PM
need ADVICE ON CULTURED STONE thermax Masonry 3 09-24-2009 09:38 PM
Cultured Stone grout question HigherLivingLLC Masonry 13 09-14-2009 07:34 PM
