Natural Fireplace Question - Masonry - Contractor Talk
Old 03-14-2012, 08:34 PM   #1
mbobbish734's Avatar
Trade: Property Preservation & Remodeling
I'm looking to buy a home that has a natural fireplace amd I have no experience with them. The chimney has what looks like 6 flues. It's also double stacked, meaning there is one on the main level and one directly below in the basement. I'd like to make sure its safe first but also looking to put an insert in it. I like to keep it a log fireplace. Is there anything I should look at. Anyone want to inspect it. I'm wanting to use it for supplemental heat.
mbobbish734 is offline
Old 03-14-2012, 08:38 PM   #2
Chief outhouse engineer
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Re: Natural Fireplace Question
Hire a certified chimney sweep, he will be able to determine the integrity of the fireplace and chimney.
Six flues doesn't sound right, but only someone on the scene can determine what's up with that.
D K & Sons
The maintenance schedule for brick
1. Stand back and say "man that looks nice!"
2. Repeat as often as needed.
dakzaag is offline
The Following User Says Thank You to dakzaag For This Useful Post:
2low4nh (03-15-2012)
Old 03-14-2012, 08:59 PM   #3
I got a call in to one but won't be out till Friday. Just want to educate a little. The top of the chimneys has six seperate flues. I figured 1 was for the furnace and water heater. Maybe 2 per fireplace?.
Old 03-14-2012, 09:06 PM   #4
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Never seen a fireplace with two flues. Not saying it can't be done, but never seen it and can't figure why it would be done.
I have seen cold air return flues, but I think they are likely to pull smoke back in.
You should be able to smell a water heater or furnace.
I like that stone.
Great retro look
D K & Sons
dakzaag is offline
Old 03-14-2012, 09:22 PM   #5
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
I have seen fireplaces done with double fluetiles.........I've only seen it twice, and both were enormous fireplaces, 6-7 feet wide and maybe 4 ft. high.......they used 'siamese' flues......probably to keep from having to lay those 280 lb. monsters......Are you saying that there are only 2 fireplaces? And six flues? Hmmmm.... That is odd, for sure. If any of the fireplaces have twin flues, it will be very evident just looking up through the damper, at the top of the smoke chamber......but that picture looks like an average size f-place.......Curious.....
Rockmonster is offline
Old 03-14-2012, 09:29 PM   #6
Yep two, one on top of the other.
Old 03-14-2012, 10:05 PM   #7
Tscarborough's Avatar
Rewards Points: 1,460
What is a natural fireplace? I have seen and recommended double flues for large or size limited chases.
Tscarborough is offline
The Following User Says Thank You to Tscarborough For This Useful Post:
mbobbish734 (03-14-2012)
Old 03-14-2012, 10:15 PM   #8
Natural wood.
Old 03-14-2012, 10:49 PM   #9
dbrons's Avatar
Trade: Masonry
Rewards Points: 608
Sometimes because of the position the flues in a wide chimney, there might be a dummy flue- a short piece of flue pipe that is installed just to make the chimney top look symetrical.
dbrons is offline
The Following 2 Users Say Thank You to dbrons For This Useful Post:
DJ9222 (03-15-2012), fjn (03-16-2012)
Old 03-14-2012, 11:44 PM   #10
lukachuki's Avatar
Rewards Points: 1,002
that would be my guess....dummy flues at the top.
I'm a little mean, but I make up for it by bein' real healthy. Earnest T. Bass
lukachuki is offline
Old 03-15-2012, 05:56 AM   #11
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,256
Here's one with 16 flues.
stuart45 is offline
Old 03-15-2012, 08:03 AM   #12
2low4nh's Avatar
Trade: Masonry/Landscaping
Rewards Points: 264
Could have spare thimbles we almost always add a secondary flue for future use in new homes.
2low4nh is offline
Old 03-15-2012, 08:38 AM   #13
The whole chimney from basement to roof is about 10 ft wide.
Old 03-15-2012, 12:36 PM   #14
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
I vote for dummy flues as well, just something to balance the size of the chimney.
dom-mas is offline
Old 03-15-2012, 04:08 PM   #15
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Well if you have a woodstove set up, a furnace, and 2 fireplaces thats 4 flues. Not sure where the others are from.
Ive done a chimney with 2x 12x18 flues but it was a very large firebox. The firebox in the picture looks rather squatty and small and could use a mantle.
The good news is there is no staining on the face of the fireplace. Thats a good indication that it draws well.
Your chimney sweep will tell you that you need a metal liner no matter what the tiles look like.
JBM is offline
Old 03-15-2012, 04:25 PM   #16
Chimneys guy inspected it today. He said flues are good and clean and that he didn't think wood was ever burned in it. There's one dummy flue. 2 flues for the fireplaces 1 each . 1 flue for the furnace/water heater. 1 unknown flue that goes to nothing.
Old 03-15-2012, 07:38 PM   #17
dakzaag's Avatar
Trade: mason
Rewards Points: 786
Be aware that if you decide to put a gas log in sometime down the road, that it will attack the clay liners aggressively. If it is only occasional use, then you should be fine, but if the gas log is used as a constant heat source, you will have to pay close attention and eventually replace the liners.
Since your planning to burn wood, it won't be a problem, but sometimes guys get tired of the wood thing and then the real damage begins.
D K & Sons
dakzaag is offline
Old 03-15-2012, 08:45 PM   #18
I think I'm going with an insert, so what I was told there will be a stainless steel liner going in. What makes the gas attack the clay that a wood fire don't? Just curious.
Old 03-16-2012, 03:02 AM   #19
Handle It!
MALCO.New.York's Avatar
Rewards Points: 2,000
Temperature and RESIDUE.
Ultimate Wisdom---------
MALCO.New.York is offline
Old 03-16-2012, 07:09 AM   #20
dakzaag's Avatar
Trade: mason
Rewards Points: 786
The results of burning a gas appliance are very acidic fumes that draw moisture into the chimney. This moisture condenses on the flue walls and eats into the liner until it completely desintigrates.
The best description I have heard is it basically causes a micro environment of acid rain in the chimney that agressively attacks the clay liner. Since the gas appliance doesn't exhaust the amount of fumes as a natural wood burning fire, the chimney is way oversized and doesn't draw as well and often the gasses never leave the chimney.
High quality stainless steal is the only product I am aware of that resists the acid corrosion over extended times. If some of the flues currently in use are venting a gas appliance, I would have expected the sweep to discover problems in those flues.
D K & Sons
dakzaag is offline
Demoing block fireplace, question about RRP. VinylHanger Lead RRP Discussion 3 10-14-2011 12:23 AM
California Question!! MTN REMODEL LLC Electrical 10 11-20-2010 12:10 AM
Code Question on Lamp wiring question ABLE1 NEC Discussion 8 06-16-2010 07:48 AM
