My Heater Died - Page 3 - Masonry - Contractor Talk
My Heater Died
Old 02-24-2015, 07:26 AM   #41
6stringmason's Avatar
Trade: masonry
Rewards Points: 1,136
Re: My Heater Died
I switched to LP for simplicity. I was sick of fixing all the muilt fuel heaters I had, and filling up jugs all the time. Now I just get some 100lb cylinders for running during the day, or 20's for smaller jobs, and its so much less head ache. And they run, without fail for me all the time.
Kamps Masonry 920-680-3195
https://www.facebook.com/pages/Kamps...31566206923069
Visit our website @
http://www.concretecountertopsdesign.com/
6stringmason is offline
Old 02-24-2015, 09:02 AM   #42
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: My Heater Died
Do you find much difference in fuel cost?
www.dominionmasonry.ca
dom-mas is offline
Old 02-24-2015, 09:10 AM   #43
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 1,357
Re: My Heater Died
LP is nice, but most of the sizable heaters I've seen have no thermostat. They have to be manually ignited. Not so much of a factor outside/in a tent, but not practical to keep fiddling with when they can stay ahead of the cold.
Tinstaafl is online now
dom-mas (02-24-2015)
Old 02-24-2015, 09:17 AM   #44
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: My Heater Died
Also many of them can't be dialed down except at the tank. they are either on or off. And when they do fail they are difficult if not impossible to service at home. The big pigs/hogs or salamanders (I've heard both terms) are so stupid hot and loud that they can make for a very unpleasant day.
dom-mas is offline
Old 02-25-2015, 07:37 AM   #45
Trade: masonry
Re: My Heater Died
I havent specifically done the math on fuel costs, but LP up here is hovering around $1.80 per. Kerosene is above that, and diesel is at $2.50 ish.
I also like not smelling the diesel or kerosene fumes all day, or having to slosh around and fill the 5 gallon jugs all the time. Its nice to have 500 gallon tanks dropped off for bigger jobs, or just drag around 100lbers and 20's for the smaller ones.
I did find some LP heaters for about $200 that have a thermostat and can be changed from 130k to 170k from Fleet Farm, an upper midwest chainstore. They've also got the auto ignite on them, no priming involved. I've been running the LP's now for 4 or 5 years, and other than having to fix a cord, or put a new fan on. they turn all day without fail.
I guess its just personal preference.
Visit our website @
The Following User Says Thank You to 6stringmason For This Useful Post:
Tinstaafl (02-25-2015)
Old 02-25-2015, 05:01 PM   #46
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: My Heater Died
I did the math on LP and diesel when I was first starting and the difference was over 2x more for propane. If I had figured Kero it would have been the same. Diesel cost was $40 per day and propane was almost $100.
dom-mas is offline
Old 02-25-2015, 06:58 PM   #47
JBM's Avatar
Trade: Masonry
Rewards Points: 9,472
Re: My Heater Died
If my heating cost 100 a day thats what I would charge additional.
JBM is offline
Old 02-25-2015, 09:19 PM   #48
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
Re: My Heater Died
Get a 'Hot Box' (by Red Dragon).....I've got two of them, you can dial em down, and they will crank when needed......plus, you can put about 200 lbs on top of them as well........when you need to heat up, or melt ice off of stock......
A true 5 star product.....
Rockmonster is offline
The Following User Says Thank You to Rockmonster For This Useful Post:
dom-mas (02-26-2015)
Old 02-26-2015, 06:37 AM   #49
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: My Heater Died
I can't always get heating cost out of a project. If the project is too expensive they'll wait til spring. There's no doubt about it...I make less money in the winter for more out put of work, with or without heating cost. If i could just add $2k to the cost and still get the job I would...but I can't so I either eat the heating cost or only add $1k to the cost and get the work. I still make more than sitting at home
dom-mas is offline
The Following 3 Users Say Thank You to dom-mas For This Useful Post:
blacktop (02-26-2015), Fancis Casini (02-26-2015), JBM (02-26-2015)
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 09:51 PM
Water Heater Fail Dr Heat HVAC 8 11-28-2012 05:53 AM
weird water heater tank connection?... BuenaHomes Plumbing 28 10-02-2012 04:33 PM
15 kw pool heater pat c Electrical 6 06-13-2012 07:38 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
