My Heater Died - Masonry - Contractor Talk
My Heater Died
Old 02-06-2015, 05:51 PM   #1
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
My Heater Died
I have a fairly new 170/210k heater. Worked great until now. Blows smoke all over until I take the cover off, then it works great.
Im about ready to smash it with a sledge. Ive cleaned everything I can think of, the fuel pressure is fine. Its always when you need it the most.
No one anywhere has any heaters for sale.
Rant over.
I have another one to use, but it burns your eyes a bit, so ill have to use propane during the day.
The good news is I get to plow snow for 3 days in a row.
JBM is offline
Old 02-06-2015, 06:19 PM   #2
Drywall Slave
blacktop's Avatar
Trade: drywall contractor
Rewards Points: 294
Re: My Heater Died
Rant over.
Domas can tell you what's wrong .. Sounds like the air intake .
Is it a multi fuel heater ? What are you running?
"Always listen to your heart . Always listen to your dog ." Quote. Gauge key .
blacktop is online now
Old 02-06-2015, 06:21 PM   #3
JBM's Avatar
Trade: Masonry
Re: My Heater Died
It's a dynamic pro kero heater. I'm running kero.
JBM is offline
Old 02-06-2015, 06:37 PM   #4
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Re: My Heater Died
Maybe the wick is f'ked up...if indeed it has a wick
supersealconstruction.com
superseal is offline
Old 02-06-2015, 07:17 PM   #5
JBM's Avatar
Trade: Masonry
Re: My Heater Died
Nope no wick lol
JBM is offline
Old 02-06-2015, 07:27 PM   #6
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: My Heater Died
What type of igniter does it have ?
fjn is offline
Old 02-06-2015, 07:35 PM   #7
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 676
Re: My Heater Died
Sounds like a clogged air filter. Try just removing the filter(s).
Tinstaafl is online now
The Following 2 Users Say Thank You to Tinstaafl For This Useful Post:
dom-mas (02-08-2015), JBM (02-06-2015)
Old 02-06-2015, 07:43 PM   #8
JBM's Avatar
Trade: Masonry
Re: My Heater Died
A forked type of sparkug.
JBM is offline
Old 02-06-2015, 07:49 PM   #9
fjn's Avatar
Trade: mason
Re: My Heater Died
Just AWAG, put in a new one.
fjn is offline
Old 02-06-2015, 07:55 PM   #10
JBM's Avatar
Trade: Masonry
Re: My Heater Died
I'll try to clean it tomorrow. It starts great without the cover on thou
JBM is offline
Old 02-06-2015, 08:29 PM   #11
pappagor's Avatar
Trade: general contractor
Rewards Points: 32
Re: My Heater Died
try the air hose trick
pappagor is offline
Old 02-06-2015, 08:35 PM   #12
JBM's Avatar
Trade: Masonry
Re: My Heater Died
What is the air hose trick?
JBM is offline
Old 02-07-2015, 11:20 AM   #13
fjn's Avatar
Trade: mason
Re: My Heater Died
x 2 ?
fjn is offline
Old 02-08-2015, 01:22 PM   #14
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: My Heater Died
It's a lack of air. you need a NEW air filter not just cleaned. There's that paper filter that has carbon or something in it, that needs to be replaced. I can only find them on Amazon. What i do in that situation is to put the lid back on but only 2 or 4 screws towards the front and wedge something in the back so air can be sucked in directly, hopefully it works until you can get a new filter. Order 4 at a time
So long as the front is fully covered foreward of the fan there is no more risk of fire than if the whole thing is covered
www.dominionmasonry.ca
dom-mas is offline
The Following 2 Users Say Thank You to dom-mas For This Useful Post:
blacktop (02-08-2015), JBM (02-08-2015)
Old 02-08-2015, 01:55 PM   #15
JBM's Avatar
Trade: Masonry
Re: My Heater Died
I ordered the filters. The paper one is black , completely. I tried to run it without the paper filter and it didn't improve it.
JBM is offline
Old 02-08-2015, 02:06 PM   #16
rustyjames's Avatar
Rewards Points: 1,808
Re: My Heater Died
http://www.reddyparts.com/sp_tips.htm
This site helped me figure out what my heater problem was.
rustyjames is online now
The Following 2 Users Say Thank You to rustyjames For This Useful Post:
blacktop (02-08-2015), JBM (02-09-2015)
Old 02-08-2015, 03:51 PM   #17
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: My Heater Died
Yeah i've tried that too, doesn't work, I think it needs some resistance to draw or soemthing
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
JBM (02-08-2015)
Old 02-10-2015, 09:17 AM   #18
mason contractors
Fancis Casini's Avatar
Trade: mason contractor
Rewards Points: 1,109
Re: My Heater Died
Rant over.
lol I have the same sized heater same problem [internals are all the same basically] at first it would run fine but run out before it was empty.....i found the fuel pick up tube hose too long so it curled upward in the tank bottom.
I had much down time as they are very temperamental. Ive bought pump blades;the pressure gauge; all the filters;nozzle etc etc..and each time I got it running but slowly it regressed to needing the cover slid forward a bit and now wants it off!
I noticed the plastic along the heat chamber getting hot...I took the chamber off and the metal supports were giving out allowing it to settle towards the tank top. I put in strap supports and it helped but I think the chamber is terribly under gauged!
Other fixes were the air and fuel tubes flare at the fittings ie nozzle and filter and pump. The nozzle spins with air flow and has spiral grooves which get filled and the spin is easily stopped or slowed with either dirt or faltered air flow. I take the nozzle apart and clean them and do all the filters but it still demands the cover removed....has to be the chamber air flow. Just a hunch as yours is new look at the end of the fuel tube in the tank...make sure it's not curled and be sure they cut it in a point ie 45 degree cut from it center. it wont get clogged by bottoming that way. I actually replace all those **** hoses and used ideal clamps because they leak after a while. B careful with the igniter,just looking at it will fracture it and its expensive like a gas dryer igniter! Funny though the replacement is a lot more durable!
Talk about no heat I've been plowing without it. Damned duramax has a head gasket problem that results in over pressurized coolant and air pockets in the heater core. I put in blue devil last spring [5000$job] and it worked great but now the core is clogging! Put in 2 by bass tees and air blew it and water hose blew it both directions. It works for a while three times then it goes cold.This morn I'm putting in bar's and pumping it for an hour both directions. I thought I was done with the no heat **** and scraping ice off the inside windows...I used to have a 36 horse vw that did the same thing, but we piled in anyway!
Fancis Casini is offline
The Following User Says Thank You to Fancis Casini For This Useful Post:
JBM (02-10-2015)
Old 02-13-2015, 12:34 PM   #19
JBM's Avatar
Trade: Masonry
Re: My Heater Died
All new filters and it wont run with the cover fully on. Runs amazing with little shims in the back though.
JBM is offline
Old 02-13-2015, 02:37 PM   #20
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: My Heater Died
Hmm. You're sure you have the right pressure? You're running kero? Can you switch yours between 170 btu and 200? if so does it work on one but not the other? It's been bitterly cold here lately, maybe the fuel is just too thick without more air?
Definitely sounds like an air flow problem...I'm really surprised the new filter didn't fix it.
dom-mas is offline
Barn Water Heater - line frozen artinall Plumbing 16 01-23-2013 09:51 PM
Water Heater Fail Dr Heat HVAC 8 11-28-2012 05:53 AM
weird water heater tank connection?... BuenaHomes Plumbing 28 10-02-2012 04:33 PM
15 kw pool heater pat c Electrical 6 06-13-2012 07:38 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
