Mortar Question - Page 2 - Masonry - Contractor Talk
Mortar Question
Old 06-30-2019, 08:40 AM   #21
natural1's Avatar
Trade: Landscape contractor
Rewards Points: 428
Re: Mortar Question
so is the liner track going to be all wobbly up and down around the pool? What about the rest of the coping?
What did you wind up using to smooth the walls for the foam layer?
Be nice if you gave updates on some of the previous questions you asked
Mike
http://www.natural-designs.com
natural1 is offline
Old 06-30-2019, 12:24 PM   #22
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,436
Re: Mortar Question
Originally Posted by arudam View Post
if i did a 3/8-1/2" bed only for leveling the first row, type s suitable?
Both type S and a 3/8" bed are basically the standard.
Are you going to cut the brick to fit to keep the uniform bed?
NYCB is offline
Old 06-30-2019, 03:55 PM   #23
arudam's Avatar
Trade: Paving stone
Re: Mortar Question
Be nice if you gave updates on some of the previous questions you asked <img src="http://img.contractortalk.com/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
The liner track is pretty straight, i just raised it above the top of the icf so that the front of the bullnose paver would sit on the track and i would have space to mortar on the back,
I have extra brick from my retaining wall thats why i decided to stack some on the backside (the reason for this thread) i wanted it to sit over the coping but ive decided to do a minimal layer of mortar and sit these bricks behind the liner track and ill cut the bullnose edge off my extra, gluing them on this wall to cover the track.
Also i decided to just put the liner right on the ICF face, if im not happy with the turnout next year ill slip some dibond material behind it. But i ran an orbital sander on it and spray foam to smooth it out and touch it up so its ok for now
arudam is offline
Old 06-30-2019, 03:58 PM   #24
arudam's Avatar
Trade: Paving stone
Re: Mortar Question
Originally Posted by JBM View Post
How many courses you got to work with? I can fix 2" in probably 5-8 courses.
its 6 rows high of stone, each is 4" making a 2ft wall, but i just wanted to confirm the strength of the initial row of mortar to level the first row bottom, all other rows will be just PL'd and stacked
arudam is offline
Old 06-30-2019, 07:51 PM   #25
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,797
Re: Mortar Question
Your water fall feature will leak expensive treated water constantly, unless built in water tight pocket.
Even then it will evaporate a considerable amount of water, cooling the pool....
Maybe a timer or motion detector to reduce in-use on the pump?
Fouthgeneration is offline
Old 07-01-2019, 09:23 PM   #26
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: Mortar Question
That look on my face may look serene but it's really inner frustration.
JBM is offline
