Mortar Question - Masonry - Contractor Talk
Mortar Question
Old 06-25-2019, 11:14 AM   #1
arudam's Avatar
Trade: Paving stone
Mortar Question
Hey guys, working on my ICF pool, along the back side i want to stack a 2 foot wall of brick to make a retaining wall/waterfall, i have to lift the initial row about an inch off the poured concrete from the icf, a) to level it b) to lift it above my liner track. This wall im stacking will weigh about 6200lbs spread across 32ft, is type s mortar suitable to build up that
initial inch under that amount of weight? I currently have type s at home because im using it for my pool coping around the rest of the pool, open to suggestions or ideas? Thanks !
Mortar question-screenshot_20190625-111315_gallery_1561479216749.jpg   Mortar question-screenshot_20190625-111311_gallery_1561479228029.jpg
arudam is offline
Old 06-25-2019, 04:39 PM   #2
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,436
Re: Mortar Question
I would rather just cut the first row of brick than make a one inch mortar bed.
NYCB is offline
The Following User Says Thank You to NYCB For This Useful Post:
fjn (06-25-2019)
Old 06-25-2019, 05:31 PM   #3
arudam's Avatar
Trade: Paving stone
Re: Mortar Question
Not an option, i need to do it a) to level the existing concrete top so the bricks not wavy as ****, b) to raise it above my liner track as i want it to overhang into the pool
arudam is offline
Old 06-25-2019, 06:15 PM   #4
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Mortar Question
I'm with NYCB..
. For example, 3/4-inch-wide mortar bed joints produce only half the flexural strength and compressive strength of 3/8-inch-wide mortar joints, according to Tables 5-6 and 5-12 of Recommended Practice for Engineered Brick Masonry, published by the Brick Institute of America (BIA). Thus, width of bed joints should be at least 1/4 inch to permit proper tooling and no more than 1/2 inch to provide adequate strength.ASCE 6-88, Specification for Masonry Structures, provides for head joint widths from 1/8 to 1/4 inch and bed joints from 1/4 to 1/2 inch thick.
fjn is offline
Old 06-25-2019, 08:47 PM   #5
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: Mortar Question
They sell half height bricks.
JBM is offline
Old 06-25-2019, 09:03 PM   #6
arudam's Avatar
Trade: Paving stone
Re: Mortar Question
the issue isnt the height of the brick, the issue is the wall isnt level that i can just start stacking. cutting bricks or half bricks isnt a solution, the bricks are 12" wide x 8" deep and 4" high. i need to level the first row before i continue to build up the wall and im trying to ask if type s mortar will hold the 6000lbs ive mentioned or if there if a stonger product available.
you mentioned a 1/2" bed is maximum and i can work with that. 1 " i mentioned was approximate.
******So what is the best mortar to lay 6000 lbs on in a 1/2" thickness?*******
arudam is offline
Old 06-25-2019, 10:25 PM   #7
JBM's Avatar
Trade: Masonry
Re: Mortar Question
Probably Portland and sand 3 to 1.
JBM is offline
Old 06-26-2019, 12:43 AM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,797
Re: Mortar Question
Use some Stainless chicken wire as a mesh or some stain less dura-wall wire to re-enforce the thick joint.
6200/32 feet = 193.75 pounds a foot or ~16 1/7th pounds per face inch.....
Divide by four inch deep material bed.....= ~4 psi
The 3 tons will cause a little differential settlement, 1/16" to maybe 1/2" on total crap subsoil.
Add a few pounds of Portland for more strength, a little less lime bleeding, more Portland = harder to clean, more shrink cracks, less plastic, more brittle final assembly...
Same color mortar as brick might look more like rock if wanted...
White mortar/ cement allow deeper colors. but cost more$$
Cheapskates rake gray mortar out of joints and point with colored grout....
Fouthgeneration is offline
Old 06-26-2019, 05:33 AM   #9
NYCB's Avatar
Re: Mortar Question
Full brick on the low side, then find level on the high side. Cut the bricks in that course to your string line as you lay them.
Now you have a uniform mortar bed, and a level first course.
It's a pretty standard solution to thinks like uneven footing or brick ledges.
NYCB is offline
Old 06-28-2019, 12:25 AM   #10
Trade: Masonry
Re: Mortar Question
Dry lay the first course, on shims(1/4"-5/16ths") if needed. laser level bench marks each end, snap a line ~2" up on faces of block, rip saw on 14"-20" diamond bladed table saw, You should be able to use the "waste" cut on half the wall thus, 16 good cuts = 32 usable pieces.
If you don't want a 2" high nominal first course, snap chalk line at highpoint of LOWEST block level across dry laid first course, cut all 32 pieces.
8" wide bed units are less sensitive to bed joint thickness, but Cmus will have much lower f sub m then ceramic units that test by themselves North of 10,000 psi.
Other then looking like a busted sphincter, 3/4" joints aren't an issue in my opinion...
Frost is your # 1 issue followed by corrosion of any iron or steel embeds in your walls/ floors.
If you have ANY trees or bushes you've created a labor pit till the day you fill it in for a flower bed....Save up for an automated tarp with an exit method for walk overs/ entrapped users...
Old 06-28-2019, 08:43 AM   #11
jomama's Avatar
Trade: Concrete & masonry
Rewards Points: 170
Re: Mortar Question
Type M mortar is stronger than S, is is probably a better option in your situation and environment. We've laid block on some pretty terrible footings through the years, laying solid block with ~1" bed joint is easy.......
I do like the idea of Dura-wall in the first joint as well.
jomama is offline
Old 06-28-2019, 08:48 AM   #12
JBM's Avatar
Trade: Masonry
Re: Mortar Question
When I moved back to mass, laying block with type n was so frustrating after using type m lol
JBM is offline
Old 06-28-2019, 08:55 AM   #13
arudam's Avatar
Trade: Paving stone
Re: Mortar Question
im still hearing cut the brick lol they are 12" wide and 8" deep folks how on earth would i cut them
arudam is offline
Old 06-28-2019, 10:05 AM   #14
fjn's Avatar
Trade: mason
Re: Mortar Question
Not exactly sure of what you are trying to communicate with those numbers 12 " and 8 ". However,if the 12 " is what is called the bed depth,find a local stone supplier,they have saws that would easily cut them,just mark them out. By me there are many such yards we can call on.
fjn is offline
Old 06-28-2019, 07:50 PM   #15
JBM's Avatar
Trade: Masonry
Re: Mortar Question
Just bed the first course in 3:1 Portland and sand, were not splitting the atom right lol
JBM is offline
The Following 2 Users Say Thank You to JBM For This Useful Post:
SouthonBeach (06-29-2019), stuart45 (06-29-2019)
Old 06-28-2019, 08:37 PM   #16
NYCB's Avatar
Re: Mortar Question
Fire up a demo saw, cut one side, flip it and cut the other.
The same solution on a bigger brick saw would also do it.
NYCB is offline
Fouthgeneration (06-28-2019)
Old 06-29-2019, 01:44 AM   #17
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,268
Re: Mortar Question
The simple answer is often a good one.
If the joint is on the large side we sometimes bed a course or 2 of slate in as well. As slate was used as a DPC course in the past it's more than capable of taking the weight.
stuart45 is online now
The Following User Says Thank You to stuart45 For This Useful Post:
JBM (06-29-2019)
Old 06-29-2019, 01:41 PM   #18
arudam's Avatar
Trade: Paving stone
Re: Mortar Question
if i did a 3/8-1/2" bed only for leveling the first row, type s suitable?
arudam is offline
Old 06-29-2019, 06:59 PM   #19
JBM's Avatar
Trade: Masonry
Re: Mortar Question
How many courses you got to work with? I can fix 2" in probably 5-8 courses.
JBM is offline
Old 06-29-2019, 07:19 PM   #20
cdkyle's Avatar
Trade: Concrete & General Construction
Location: The Heartland of the United States of America
Rewards Points: 626
Re: Mortar Question
https://giphy.com/gifs/voy-h36vh423PiV9K
cdkyle is offline
The Following 2 Users Say Thank You to cdkyle For This Useful Post:
Fouthgeneration (06-29-2019), JBM (06-29-2019)
