Lime Wash Brick - Page 2 - Masonry - Contractor Talk
Lime Wash Brick
Old 04-24-2016, 06:57 PM   #21
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Lime Wash Brick
This discussion prompted me to do a google search. There are numerous recipes posted. Most have salt as an ingredient,here is one of the many.
http://www.theprairiehomestead.com/2...barn-coop.html
fjn is offline
Old 04-24-2016, 07:30 PM   #22
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
Re: Lime Wash Brick
If I were to try to get a paint wearing off look on a building (not sure if thats what your looking to do) ive used the lime paint found at limeworks.us with good results and believe it would make a great wash.
http://www.limeworks.us/limepaintsmore.php
JBM is offline
Old 04-24-2016, 07:35 PM   #23
Tscarborough's Avatar
Rewards Points: 1,460
Re: Lime Wash Brick
This is a differentiation between doing a lime wash on brick and a lime wash on wood I would assume. I am not sure of the chemistry of a wood lime wash, but for a brick one, there is no mechanism whereby table salt would assist or improve bond, stability, or any other function of the lime wash itself.
Tscarborough is offline
Old 04-25-2016, 06:11 PM   #24
fjn's Avatar
Trade: mason
Re: Lime Wash Brick
Well,I did a google search on lime wash. There are numerous sites that pop up directing to 'Ask The Builder" AKA Tim Carter,his recipe for lime wash for masonry does in fact list salt as one of the ingredients.
For whatever reason,I can't post the connections to his site,one would have to do their own search.
Not wanting to take his word for it,I pulled out my trusty copy of Building With Lime by Wingate nad Holmes. Here is what they have to say on the topic.
SALTS: When limewashes are used in historic buildings,it is unthinkable to introduce chloride salts,even in very small quantities,which might cause harm to the fabric of the masonry.However,it is well known that the addition of sodium chloride (common salt) or calcium chloride (crude commercial grade)can greatly assist the performance of a limewash. The salts act in two ways:they increase the solubility of the lime and they provide wetting and drying cycles which benefit the carbonation. The increased solubility means that the calcium hydroxide penetrates further into the surface for a better bond. The hygrosopic action,attracting moisture from the air,prevents rapid drying. On an internal wall this hygrosopic action would cause dampness to appear whenever the conditions are humid,but externally the salts would gradually wash off.
fjn is offline
dom-mas (04-25-2016)
Old 04-25-2016, 06:41 PM   #25
Re: Lime Wash Brick
I can't speak to it definitely, but intuitively, using calcium chloride or sodium chloride go against everything I think I know about masonry. Calcium is used as a convenience, but it is not used to improve anything but production.
I will see what I can find about sodium chloride in addition to what you have found.
Old 04-25-2016, 08:25 PM   #26
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Lime Wash Brick
Interesting, never would have thought.
www.dominionmasonry.ca
dom-mas is offline
Old 04-26-2016, 08:04 AM   #27
Re: Lime Wash Brick
I could not find anything from the industry that recommended adding salt to lime mortars or plaster, just the normal cautions that soluble salts are always to be avoided.
Lime paint may be different, but for the purpose of giving brick a lime wash, do not add salt.
Old 04-26-2016, 06:26 PM   #28
fjn's Avatar
Trade: mason
Re: Lime Wash Brick
Here is the recipe I mentioned yesterday by Ask the builder AKA Tim Carter.
www.askthe builder.com/ whitewash-recipe
fjn is offline
Old 04-26-2016, 08:40 PM   #29
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Re: Lime Wash Brick
www.askthebuilder.com/whitewash-recipe
Maybe this will work
http://www.askthebuilder.com/whitewashing-brick/
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
fjn (04-27-2016)
Old 04-27-2016, 04:00 AM   #30
Knows less all the time
Fundi's Avatar
Trade: Brick Contractor, Manufacturer
Rewards Points: 582
Re: Lime Wash Brick
I started using lime wash last year. I am a convert. For what it is worth-
Years ago it was used frequently and the mix had salt in it. I dont use salt as it does the job without it.
Tsar and the site above mixtures are much thicker than mine.
I use 1 part lime 4 water. You need to mix with almost every brush. Put it on thin The first coat you think it hasn't done anything . then when as it dries it becomes whiter and whiter . And each layer becomes whiter and whiter. I try to keep it wet for a month and it dries hard.
I might even whitewash bricks.
It you want it even harder you add............................ clay! clay and lime bond. Oh course that changes the pigmentation but I like the brown color i get. White whitewash can be blindingly bright.
I Whitewashed a roof and after 4 weeks of hard rains there is hardly any deterioration.
Some garden walls whitewashed.
Fundi is offline
The Following 2 Users Say Thank You to Fundi For This Useful Post:
dom-mas (04-27-2016), fjn (04-27-2016)
Old 04-27-2016, 06:52 AM   #31
Re: Lime Wash Brick
We are still talking about 2 distinct things here. One is a lime wash to apply to a finished wall, the other is to coat individual bricks before use. As such they have different requirements, chief among them the need to maintain a bondable surface and durability.
The Following 2 Users Say Thank You to Tscarborough For This Useful Post:
fjn (04-27-2016), Fundi (04-27-2016)
Old 04-27-2016, 09:25 AM   #32
fjn's Avatar
Trade: mason
Re: Lime Wash Brick
Very true. Are you saying when the bricks are coated prior to installation more than the face gets coated ? If so,I can easily see the need not to utilize salt.
fjn is offline
Old 04-27-2016, 09:31 AM   #33
fjn's Avatar
Trade: mason
Re: Lime Wash Brick
Just some trivia that may aid some of your customers wanting "that" look. I just bid a job yesterday that had a need to match an existing brick While the perfect match was no longer produced,Belden brick had a very close match.
Belden has several offerings that imitate the worn white wash look. Here is the one that was chosen
http://www.beldenbrick.com/onlinecat...frosted-whites
fjn is offline
Old 04-27-2016, 10:47 AM   #34
Re: Lime Wash Brick
The brick are dipped into a slurry, so generally the whole brick is coated.
The Following User Says Thank You to Tscarborough For This Useful Post:
fjn (04-27-2016)
Chicago Cut Brick Veneer Installation sokoleoko Masonry Picture Post 6 05-28-2015 02:50 AM
What is your favorite brick & why? fjn Masonry 43 09-09-2013 12:14 PM
lime application spreader settings dale rex Landscaping 0 07-21-2012 03:13 PM
Brick sidewalk edge restraints red_cedar Masonry 16 07-18-2012 06:28 PM
cement wash or concrete rub a thin layer over brick pavers brownstone89 Masonry 14 08-25-2008 06:14 PM
