Leaning Block Wall - Masonry - Contractor Talk
Leaning Block Wall
Old 07-03-2019, 11:14 AM   #1
EppNation's Avatar
Trade: Underground Construction
Rewards Points: 14
Leaning Block Wall
Its part of a retaining wall 'system' I guess I'd call it, but strangely was never tied into wall perpendicular to it.
From grade level it was closed off ~3.5" and a planter with a tree that should have never been planted. The tree buckled out the front wall (tree, front wall and remaining soil have already been removed) and this adjacent one.
I've got a plan, but this isn't something I've done before so looking for any tips/tricks, do's & don'ts
The plan is putting bolts through the wall(s) and through 2x6s (appropriate size? 4x6s?) vertically on the left side of leaning wall and right side of the wall to the right of it which cannot be seen in photos (outside to outside). Using chain and turnbuckles connecting bolt heads. I figure 3 wide and 3 across, a total of 9 pull points & 9 anchor points.
After securing compromised wall remove all the debris that has made its way in between the perpendicular joining of the 2 walls, make a cut if I have to clear any obstacles, and soak the soil around both sides of the footer.
Then turn turn turn them buckles gradually and uniformly until its back where it belongs.
The front wall (like in the picture with the tree) is going to be rebuilt, and filled with soil to be a planter again, but this time only with shrubs
EppNation is offline
Old 07-03-2019, 11:16 AM   #2
EppNation's Avatar
Rewards Points: 14
Re: Leaning Block Wall
Wont let me upload last pic of how it was before this project started, upload keeps failing. It's not important though, just picture it closed off, with a tree in it
Old 07-03-2019, 11:39 AM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Just shooting from the hip,that is a pretty tall wall having to deal with unbalanced fill. IMHO,it was not designed correctly from the get go,trying to correct it is even iffy-er . There are prescriptive steps to follow when designing retaining walls; if not followed initially,don't think a "retrofit" will accomplish much.
fjn is offline
griz (07-03-2019)
Old 07-03-2019, 11:54 AM   #4
Fire up the BBQ
griz's Avatar
Rewards Points: 2,402
very possible that you will expend more time and money trying to retrofit that wall than if you tear it down & do it right.
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
cedarboarder (07-03-2019), fjn (07-03-2019), Fouthgeneration (07-03-2019)
Old 07-03-2019, 03:07 PM   #5
EppNation's Avatar
Rewards Points: 14
8' tall by 5'8" wide
I doubt this was ever intended to have any 'retaining' function otherwise it would have been tied into the adjacent wall, right?
There is a pool under screen enclosure. Use concrete tele pole as a reference point.
Old 07-03-2019, 04:32 PM   #6
fjn's Avatar
Trade: mason
Among other things such as, re-bar,grout,bond beams,pilasters battered wall,counterforts and or counterfort footings. Any / or all of those items mentioned.
fjn is offline
Old 07-03-2019, 05:01 PM   #7
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
Brace the existing long wall, demo tower of Pisa, replace near footing with an Engineered footing, rebuild a large Pilaster that comes out at most 32" x 16" nominal, stay away from the hurricane ready power pole. Its hole probably caused the issue.
Fouthgeneration is offline
Old 07-03-2019, 06:15 PM   #8
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
It doesn't look like its retaining anything, am I missing something?
JBM is offline
The Following User Says Thank You to JBM For This Useful Post:
EppNation (10-28-2019)
Old 10-28-2019, 02:42 AM   #9
EppNation's Avatar
Rewards Points: 14
This was the tree that caused the 'lean'. As you can see, it also buckled out the front pretty good too.
