Leaking Window - Masonry - Contractor Talk
Leaking Window
Old 01-30-2013, 12:47 PM   #1
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Leaking Window
I have a client with a leak at the top of the window. Could the water get in through a tiny crack in the mortar? The. Head flashing is caulked, I wonder if that is trapping water.
Attachment 85911
MEL
MEL is offline
Old 01-30-2013, 12:51 PM   #2
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
Originally Posted by MEL View Post
I have a client with a leak top of the window. Could the water get in through a tiny crach in the mortar? The. Head flashing is caulked, I wonder if that is trapping water.
Does the stone require some type of sealer? The mortar is developing cracks in various places.
MEL
MEL is offline
Old 01-30-2013, 01:55 PM   #3
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
Re: Leaking Window
Water can definitely get through cracks, and a sealer should probably be used......but still the window should not leak. If water 'wicked' through, it should still finds its way out.
I see a weephole. When you say the head flashing is caulked, where is it caulked? It doesn't look to me like the head flashing comes out far enough on the head casing, and water could possibly/easily come in under the head flashing, depending how it was done.
If it was all done correctly, this should be pretty much watertight before the stone ever went on.
Rockmonster is offline
The Following 3 Users Say Thank You to Rockmonster For This Useful Post:
concretemasonry (02-02-2013), hdavis (01-30-2013), Tom Struble (01-30-2013)
Old 01-30-2013, 02:04 PM   #4
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
The head flashing is plastic. It is caulked where it meets the mortar joint, the entire length of the window. I don't have a close up it, but I'll try to upload another photo.
MEL
MEL is offline
Old 01-30-2013, 02:10 PM   #5
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
Here is a photo of another window, they are all caulked the same.
MEL
MEL is offline
Old 01-30-2013, 02:14 PM   #6
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
It's the middle window on the first floor. There is a small gap in the corner of the vinyl window that could be caulked. Also there are small cracks in the mortar, some are only hair line cracks.
I wonder if the caulk on the head flashing should be removed so the water can drain out?
MEL
MEL is offline
Old 01-30-2013, 02:19 PM   #7
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
Here's a close up of a hair line crack, could this cause a leak?
If a sealer is used what type?
Do you seal the stone also or only the mortar joints?
MEL
MEL is offline
Old 01-30-2013, 03:00 PM   #8
CarpenterSFO's Avatar
Rewards Points: 2,044
Re: Leaking Window
Don't start chasing hairline cracks or trying to seal the mortar. The homeowner will blame you for not fixing the problem, after you've fixed 50 cracks and the window still leaks. There's something wrong with the flashing, including maybe that weep holes have been caulked and water's backing up, or that the head flashing is wrong. Water does get behind masonry and stucco, where the housewrap/flashing system should take care of it. The hairline crack may be a symptom of water problems, from wood swelling beneath, rather than a cause.
- Bob
CarpenterSFO is offline
The Following 3 Users Say Thank You to CarpenterSFO For This Useful Post:
concretemasonry (01-30-2013), jkfox624 (01-30-2013), Tom Struble (01-30-2013)
Old 01-30-2013, 03:22 PM   #9
JBM's Avatar
Trade: Masonry
Rewards Points: 9,386
Re: Leaking Window
I would bet there is a problem with the flashing detail over the window.
JBM is offline
The Following 2 Users Say Thank You to JBM For This Useful Post:
dom-mas (01-30-2013), jomama (02-03-2013)
Old 01-30-2013, 04:06 PM   #10
fjn's Avatar
Trade: mason
Rewards Points: 10,702
Re: Leaking Window
It looks like phony glue on stone to me. First off, the return on the window is almost nonexistant. Secondly,who knows what is behind the "stone". Looks like a recipie for disaster.
fjn is offline
Old 01-30-2013, 05:13 PM   #11
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
The mortar joints are flush with the window in most places. The mortar joint has been caulked where it meets the window and the head flashing is caulked.
MEL
MEL is offline
Old 01-30-2013, 05:16 PM   #12
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
The head flashing is caulked, so if water is penetrating above it can't weep out unless it makes it way to the side of the window and drains out at the base of the wall.
MEL
MEL is offline
Old 01-30-2013, 05:24 PM   #13
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: Leaking Window
what makes you think the paper is even lapped properly over the head flashing,this is deeper than sealer your going to have to bash some stones off to check it properly..no way around it
those windows have a flange..they shouldn't be leaking even without a drip cap
Tom Struble is offline
The Following 3 Users Say Thank You to Tom Struble For This Useful Post:
CarpenterSFO (01-30-2013), fjn (01-30-2013), jomama (02-03-2013)
Old 01-30-2013, 05:32 PM   #14
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
Here's another photo. If you look at the corner of the window at the far right of this photo you can see the clear plastic head flashing. The lip comes down over the window about a half inch.
MEL
MEL is offline
Old 01-30-2013, 05:33 PM   #15
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
I took this from far away but zoomed in.
MEL
MEL is offline
Old 01-30-2013, 05:35 PM   #16
Trade: siding
Rewards Points: 20
Re: Leaking Window
nice pics Mel..but your problem is higher up the wall,may be no paper idk..
where is the water coming in? bottom/top? is the roof above them ok?
Old 01-30-2013, 05:36 PM   #17
Tscarborough's Avatar
Rewards Points: 1,456
Re: Leaking Window
Definitely fake stone, so it could be coming in from anywhere above.
Tscarborough is offline
Old 01-30-2013, 05:41 PM   #18
MEL's Avatar
Trade: Roofing
Rewards Points: 516
Re: Leaking Window
The water is dripping in at the top of the window near the center of the window. I did not go on the roof, the peak is about 20 feet above the window.
I originally went there for a roof repair on the porch roof to the right. I did notice some of the cap shingles were cracked at the gable ends, probably from bird sitting there. The house has a ridge vent. If the roof is leaking it would have to leak directly over the wall. They have not reported any water on the second floor.
MEL
MEL is offline
Old 01-30-2013, 06:07 PM   #19
JBM's Avatar
Trade: Masonry
Re: Leaking Window
The paper isnt overlapping right, or it is compromised. Or there isnt any.
JBM is offline
Old 01-30-2013, 06:29 PM   #20
concretemasonry's Avatar
Trade: Masonry consultant
Rewards Points: 2,960
Re: Leaking Window
Instead of nit-picking details trying to isolate where the water is coming from (or really showing up), look up and along the wall since water will obviously flow down, horizontally of possibly upward.
Look at the possibility of improperly installed windows above since historically 2/3 are improperly installed and water gets behind the absolutely necessary primary moisture barrier. After all, and masonry veneer is not waterproof, but it is miles better than other cladding/veneers, but water finds a way in eventually if it gets behind the primary moisture barrier.
A good moisture intrusion specialist can make a few pokes in the dry wall with a good moisture meter and long, thin probes to check the moisture of the insulation to determine exact source. Some times a couple of 1/8" holes can isolate a particular window or lead you upward/elsewhere to the source without tearing anything out.
Dick
concretemasonry is offline
Replacement Window Question? Max10 Windows, Siding and Doors 41 11-03-2013 12:01 PM
Kleer PVC for Bay Window Spencer Windows, Siding and Doors 7 12-08-2012 02:58 PM
Making A Window Frame (Video) Cole Tools & Equipment 2 11-19-2012 09:21 PM
Shower Window jrr02005 Remodeling 69 09-03-2012 06:25 PM
