Joint Removal On A Horizontal Surface - Masonry - Contractor Talk
Old 03-13-2016, 09:50 AM   #1
splitstone's Avatar
Trade: mason
Rewards Points: 12
I have a 500' brick patio that is laid in a herring bone pattern and needs to be repointed. The 4" grinder with the joint blade is getting old... like me. Is there any type of a small "stand up style" saw on the market ?. I have seen a universal saw cart, thought about mounting a worm drive saw to it and using a 6" joint blade, possibly fabricating a water feed. Thanks.
splitstone is offline
Old 03-13-2016, 04:32 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 10,710
Re: Joint Removal On A Horizontal Surface
I would rule out any type of saw, including a 4" angle grinder with a diamond blade. Reasons being,a herring bone pattern has no straight joints. You would constantly be nicking brick at stop points.
While I have used this method with good results (on soft lime mortar) I would try this method by rigging up a way to control the depth of cut and only shoot for a bout a 1/4" per pass. Reason being,bit does not cut easily through opc mortar.
http://www.bontool.com/product1.asp?P=MORTARROUTER
fjn is offline
dom-mas (03-13-2016)
Old 03-13-2016, 06:29 PM   #3
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Never seen that tool before. Thought about how there should be a tool just like it a million times but never seen one.
www.dominionmasonry.ca
dom-mas is offline
Old 03-13-2016, 10:10 PM   #4
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,048
I doubt you would find anything that you could stand and see what you are doing, with all the zigzagging in herringbone pattern you would cut too much of the brick. Sounds like a good kneeling board in needed
Windycity is offline
Old 03-14-2016, 09:21 AM   #5
splitstone's Avatar
Trade: mason
Rewards Points: 12
Thanks for your thoughts. I think I found the answer...not cheep though. Gorilla 4.5 inch crack chaser.
Old 03-14-2016, 10:28 AM   #6
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 13,525
For your job in question, it seems like it would be hard to watch the blade from behind.
MarkJames is offline
Old 03-14-2016, 01:28 PM   #7
heavyc's Avatar
Trade: masonry
Rewards Points: 945
Pressure washer?
heavyc is offline
Old 03-14-2016, 05:04 PM   #8
Nouveau Eccentric
Diamond D.'s Avatar
Trade: masonry/hardscaping
Rewards Points: 2,888
Did you read, fjn's reply?
Maybe you should read it again.
The crack chaser is no different than the tuck blade, except it leaves less of a key, you'd be better off with the tuck or stacked blade if you insist on going that route.
Watch those corners!
Don't forget dust extraction, it helps.
As far as cost goes, the last crack chaser I bought many,many moons ago, that I rarely ever use, was about what you could get the kit and 4 spare bits for.
Then there's always the hammer and chisel method or a small pneumatic chipper. No matter what, you'll be on your knees.
Good luck,
D.
" ROCK YOUR WORLD "
fb
Diamond D. is offline
Old 03-14-2016, 05:38 PM   #9
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Yes, i should have said that pneumatic hammer would always be my first choice, least possibility of accidentally cutting the units and the least dust as well
dom-mas is offline
Old 03-14-2016, 07:17 PM   #10
splitstone's Avatar
Trade: mason
Rewards Points: 12
I understand every ones thoughts but as usual I reject every ones reality and substitute it with mine. I've done split field stone for the last twenty five years and swinging that two pound Estwing has crippled my right elbow. I'm attempting to work smarter not harder.... or I'm getting lazy... So I do appreciate your opinion's. Thanks.
Old 03-14-2016, 07:27 PM   #11
MarkJames's Avatar
I don't know masonry, but I am lazy and stayed at a Holiday Inn express...
Any thoughts on this thing?
http://www.as170.com/index2.html
http://www.as170.com/videos/Arbortec...Technique.html
Old 03-14-2016, 08:03 PM   #12
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Air hammer is hardly hard work
dom-mas is offline
Old 03-14-2016, 11:47 PM   #13
Renaissance Man
superseal's Avatar
Rewards Points: 5,816
There's no easy way for herringbone although I've used my pneumatics and regulated the pressure down to the least possible punch to prevent blowout. Hopefully your mortar is softer than the brick...and you're not porty rich.
It'll be a gruelling job no matter how you do it...bid accordingly if you haven't already.
supersealconstruction.com
superseal is offline
Old 03-17-2016, 07:41 AM   #14
splitstone's Avatar
Trade: mason
Rewards Points: 12
I've been at it for two weeks...and I am close to working for free.
The patio was half covered with snow and frozen when I gave the quote, it thawed and the nightmare began. Over half of the area had to be removed and re laid.
I picked up a Ryobi 4" wet saw from Depot...that is the only good that has come from this, it's messy but keeps the dust down. "If your gonna be dumb you gotta be tough". I'm running out of tough.
Level 5 Misconceptions wallnatural Drywall 92 12-24-2013 05:53 PM
Concrete footing removal 18withtools Demolition 19 01-29-2013 07:34 PM
Sealer removal advice over exposed aggregate and stamped? oktex56 Concrete & Paving 10 01-14-2013 03:57 PM
coating removal bassinhunter Pool Construction & Enclosures 0 03-10-2012 12:28 PM
Gun plating - surface preparation borninfire Sandblasting 10 10-27-2010 06:30 PM
