Ideas On Driveway Against Foundation - Masonry - Contractor Talk
Old 03-28-2020, 09:43 AM   #1
kev324's Avatar
Trade: Property manager
Rewards Points: 4
I am installing a 6" reinforced concrete pad, basically a driveway, except it doesn't go to the street. I am planning to run the pad up to the foundation of the house. The foundation originally had pressure treated 2x4s embedded into it. These ran below grade, and rotted, so I removed them.
I am looking for ideas to make the installation look right and shed water properly. If I just pour the slab as is, the concrete will fill these voids, like interlocking teeth. What is the best way to resolve this?
BTW obviously I am still awaiting the crushed stone, rebar, etc.
Ideas on driveway against foundation-.jpg   Ideas on driveway against foundation-b.jpg
kev324 is offline
Old 03-28-2020, 10:02 AM   #2
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,448
Re: Ideas On Driveway Against Foundation
Cut some 1.5" blue foam to fill the voids with.
You could also just pour right into them and use them as a guide for your control joints.
I don't think they would lock in enough to affect either the slab or the wall in any appreciable way.
NYCB is offline
Old 03-28-2020, 10:09 AM   #3
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,310
Or maybe pour a little curb right alongside the building, becoming part of the building, this would also provide a little protection. Then pour the slab right up to the curb.
Fishindude is offline
Old 03-28-2020, 11:20 AM   #4
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,798
I would place 1/2 thick insulation board against the foundation, pour the concrete and after the concrete is dry cut the insulation flush with the top of the concrete then finish it with a bead of polyurethane sealant. That would make a good combo expansion joint/vapor and water barrier
Windycity is offline
Old 03-29-2020, 02:46 AM   #5
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
a proper repair would excavate the grooves, clean them, fill with non- shrink concrete, then re install the tar / damp proofing with insulation this time, then pour your slab , half assed and water front exposure = sure rot.
Never pour a SOG next to a home with out an expansion joint between, IMHO
Drain to the water of course, no puddles near house.
Fouthgeneration is offline
Old 03-29-2020, 05:43 AM   #6
kev324's Avatar
Rewards Points: 4
Thanks for the replies. I've never seen an issue like this before.
I will install 1.5" foam in the voids, and 0.5" foam against the foundation.
I appreciate the help!
kev324 is offline
