I Messed Up, Thoughts? - Masonry - Contractor Talk
Old 07-11-2019, 05:00 PM   #1
Keith4hunter's Avatar
Trade: handyman
so, the raised concrete slab got poured wrong (no footer) so the dirt/gravel base underneath is loose and exposed once the forms came off. I know this was done wrong, but now my question is what to do, considering erosion is going to slowly compromise the base.
Should I work as much as possible to frame a pressure treated wood wall around the bottom?
If I build mounds around it will that help (I doubt it as I would assume the material under the slab would slowly dribble out as erosion on the mound happened….
Thoughts? Any other ideas to help fix my mistake?
here are some pics
https://drive.google.com/file/d/1-5k...ew?usp=sharing
https://drive.google.com/file/d/1no9...ew?usp=sharing
Keith4hunter is offline
Old 07-11-2019, 05:11 PM   #2
TimNJ's Avatar
Rewards Points: 852
Re: I Messed Up, Thoughts?
What and where are you building?
TimNJ is offline
Old 07-11-2019, 06:42 PM   #3
avenge's Avatar
Rewards Points: 322
So you put gravel on grade, concrete over that what did you think would happen?
avenge is offline
Old 07-11-2019, 06:47 PM   #4
fjn's Avatar
Trade: mason
Rewards Points: 11,202
A good concrete job costs lots of money.............and a bad one costs even more.
fjn is offline
The Following 4 Users Say Thank You to fjn For This Useful Post:
griz (07-11-2019), hdavis (07-11-2019), Morning Wood (07-11-2019), stuart45 (07-12-2019)
Old 07-11-2019, 07:00 PM   #5
Trade: handyman
yup, I realize the bone head move. The initial plan was dig down, but with all the roots I brought it to level with the deck and just forgot the footer.... hence the initial post, "I messed up". Building a hot-tub slab to go next to the deck.
Old 07-11-2019, 07:07 PM   #6
Fire up the BBQ
griz's Avatar
Rewards Points: 2,704
have a pro saw cut 8" all the way around the slab.
keep neat & tight.
demo this.
dig footings.
form so they are flush with slab.
fill any space between slab & footing with sikaflex or similar.
install hot tub.
hopefully you compacted the base in lifts before pouring....
on future projects make certain you are not experiencing a rectal cranial inversion prior to or during construction....
griz is offline
The Following 4 Users Say Thank You to griz For This Useful Post:
Calidecks (07-11-2019), mrcat (07-11-2019), Seven-Delta-FortyOne (07-12-2019), TheConstruct (07-11-2019)
Old 07-11-2019, 07:29 PM   #7
sunkist's Avatar
Trade: builder fl cbc
Rewards Points: 890
What's sitting on the slab now ? and what's that lumber going into grade ?.
So you poured a slab with no turn down, did you put any rebar any where or mating, fiber glass in the mix ?,
What Griz said or expand the foot print of the slab doing what Griz said, and maybe epoxy some rebar into the slab so the new mix can have something to hold on to, put 2 row's of #5 rebar on saddles in the turn down.
Still "Shakin" the tree boss
sunkist is offline
The Following User Says Thank You to sunkist For This Useful Post:
Old 07-11-2019, 08:12 PM   #8
Trade: handyman
Sunkist, this is exactly what I was looking for.... yup, we forgot the downturn (which is inexcusable)... yes we did good on the rebar and mating and mix, just missed the downturn when we went from a recessed slab to a raised slab last minute because of tree roots when digging. I'm going to, per your and others feedback, expand the footprint enough to basically add a turndown and do that with rebar connecting (as best as possible considering the situation). Thanks.
Thanks everyone for the quick (and witty) replys, I'm an idiot and agree with all your observations!
Old 07-11-2019, 08:13 PM   #9
dave_dj1's Avatar
Trade: general contractor
Rewards Points: 1,168
Just backfill around the slab, good compactable stuff and call it a day. It needs to be landscaped anyway.
dave_dj1 is offline
Old 07-11-2019, 08:37 PM   #10
Trade: handyman
I was thinking about that, backfilling it with QUIKRETE Hydraulic Water-Stop cement,.... that stuff becomes claylike so I could backfill it well (as a means to keep erosion at bay), and then skim it all over the surface to make a face/wall.... then landscape and put cover so water sheds away. That would be the easier and less effective way, but might work..... hmmm....
Old 07-11-2019, 09:05 PM   #11
Fire up the BBQ
griz's Avatar
it's your mistake and the basis for your reputation.
fix it right and consider the cost to be tuition paid.
you do not want to be known as a hack....
griz is offline
The Following 2 Users Say Thank You to griz For This Useful Post:
Calidecks (07-11-2019), fjn (07-12-2019)
Old 07-11-2019, 09:07 PM   #12
Trade: handyman
can't say you're wrong griz
The Following User Says Thank You to Keith4hunter For This Useful Post:
Mordekyle (07-11-2019)
Old 07-11-2019, 10:13 PM   #13
Fire up the BBQ
griz's Avatar
nice to see that you came on here admitting to a real phuck up, took your lumps and didn't run off crying needing to take a healthy dose of midol...
do it right, and keep us posted on the progress.
good luck to you.
griz is offline
The Following 3 Users Say Thank You to griz For This Useful Post:
Calidecks (07-11-2019), fjn (07-12-2019), rselectric1 (07-12-2019)
Old 07-11-2019, 10:24 PM   #14
diplomat
Golden view's Avatar
Rewards Points: 1,550
Not what was meant by backfill. He meant bring the grade up higher around the perimeter.
Golden view is offline
Old 07-11-2019, 10:39 PM   #15
GC/carpenter
Calidecks's Avatar
Rewards Points: 10,706
I have my PHD in advanced studies of hard knocks. Thinking of a book deal.
Mike.
_______________
Calidecks is online now
fjn (07-12-2019), griz (07-11-2019), Kowboy (07-12-2019)
Old 07-12-2019, 08:35 AM   #16
Fishindude's Avatar
Trade: Industrial
Rewards Points: 1,352
There are thousands of exterior slabs poured on grade without a perimeter footing.
If the grade is steep enough at the edge of the slab that fill material appears to be "leaking"out from under the slab edge, then you need to get on this quick and backfill more earth around the perimeter of slab in a real gradual taper away from slab so that this doesn't occur. Get some grass growing, sod it, or cover with stone so it doesn't erode and wash out over time with rains and you will be fine.
Fishindude is offline
The Following User Says Thank You to Fishindude For This Useful Post:
B.Johnson (07-12-2019)
Old 07-12-2019, 09:43 PM   #17
Goin' Down in Flames....
Seven-Delta-FortyOne's Avatar
Trade: Highwayman
Rewards Points: 1,972
Pretty sure that won't be an issue.
Dollars to donuts it's his own place.
The Following 2 Users Say Thank You to Seven-Delta-FortyOne For This Useful Post:
Calidecks (07-12-2019), SmallTownGuy (07-13-2019)
Old 07-13-2019, 05:09 AM   #18
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,510
Put some dirt around it.
NYCB is offline
