How Did They Level, Square, And Plumb Ancient Stone Walls - Masonry - Contractor Talk
Old 06-21-2017, 05:18 PM   #1
matthew111's Avatar
Trade: handyman
Rewards Points: 92
I saw a picture of an old stone building in croatia which I think was from medieval times and was damaged in the war their and inside was smaller, uneven sized stones, it seems like it would have been difficult to make it level, square and plumb. I also noticed some older wood homes near me from the 1800's have stone foundations. Were old stone walls and buildings actually level square and plumb or did they just try to get it close enough?
matthew111 is offline
Old 06-21-2017, 05:30 PM   #2
B.Johnson's Avatar
Trade: Builder
Rewards Points: 2,840
Re: How Did They Level, Square, And Plumb Ancient Stone Walls
Plumb bob? Square isn't that complicated, you could check the diagonal with a piece of rope, or a wheel. I read that the Egyptians used a tube floating on a leaf in a bowl of water for a level.
B.Johnson is offline
The Following 2 Users Say Thank You to B.Johnson For This Useful Post:
Dirtywhiteboy (06-21-2017), SouthonBeach (06-21-2017)
Old 06-21-2017, 05:38 PM   #3
sparehair's Avatar
Trade: Painting, flooring
Rewards Points: 1,482
The theodolite was first mentioned in writing in 1561. The modern spirit level was invented in 1660.
Sent from my SM-N910T using Tapatalk
sparehair is offline
The Following 3 Users Say Thank You to sparehair For This Useful Post:
CharlieDelta (06-22-2017), Fundi (07-03-2017), Workingmanvan (06-21-2017)
Old 06-21-2017, 05:40 PM   #4
sparehair's Avatar
And of course once you had a plumb line you could use the pythagorean theorem to establish square/level.
Old 06-21-2017, 07:00 PM   #5
Capra aegagrus
Tinstaafl's Avatar
Rewards Points: 946
Wouldn't even need that. Once you have a plumb line, pick a center point. Measure up X", use a Y" length of string to draw an arc. Measure down the same distance and use the same string to draw another arc.
A line from where the arcs intersect to the original center point is at 90 to the plumb line. Look Ma, no math!
Tinstaafl is offline
The Following 3 Users Say Thank You to Tinstaafl For This Useful Post:
Dirtywhiteboy (06-21-2017), hdavis (06-22-2017), sparehair (06-21-2017)
Old 06-21-2017, 07:02 PM   #6
sparehair's Avatar
Geometry for the win!
The Following 2 Users Say Thank You to sparehair For This Useful Post:
MarkJames (06-21-2017), ScipioAfricanus (06-21-2017)
Old 06-21-2017, 07:04 PM   #7
matthew111's Avatar
Trade: handyman
Rewards Points: 92
That's not what I meant. We use brick and block the same size and shape now. It must have been hard to use stones all different sizes and shapes and get a level plumb and square surface, especially to put thing like windows and doors in.
The Following User Says Thank You to matthew111 For This Useful Post:
Old 06-21-2017, 07:43 PM   #8
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Take a look at old stone buildings,the corners in many instances have dressed stones on the corners and random rubble between corners. Even if the corners are not of dressed stone,the masons picked relatively flat stones for corners. Check out the book The Art of the Stonemason by Ian Cramb,you will see many examples in both pictures and line drawings.
fjn is offline
hdavis (06-22-2017)
Old 06-21-2017, 07:51 PM   #9
Talking Head
EthanB's Avatar
Rewards Points: 434
I'm good at geometry because I took it twice!
Planer.....
EthanB is offline
The Following 3 Users Say Thank You to EthanB For This Useful Post:
A&E Exteriors (04-01-2018), griz (06-29-2017), MarkJames (06-21-2017)
Old 06-21-2017, 09:47 PM   #10
Stevarino's Avatar
Trade: General contractor specializing in kitchen and bath remodeling and design
Rewards Points: 415
I once read that the Egyptians would dig a trench around the structure and fill it with water to have level reference point all around.
Stevarino is offline
The Following 6 Users Say Thank You to Stevarino For This Useful Post:
Calidecks (06-21-2017), Dirtywhiteboy (06-21-2017), KAP (03-28-2018), Rio (06-30-2017), sparehair (06-21-2017), TNTRenovate (04-03-2018)
Old 06-21-2017, 09:55 PM   #11
MarkJames's Avatar
Rewards Points: 18,873
I wonder how we figured out that they did that.
Egyptian stuff boggles my mind. History channel does some fantastic shows.
MarkJames is online now
Robie (06-24-2017)
Old 06-21-2017, 10:56 PM   #12
GC/carpenter
Calidecks's Avatar
Rewards Points: 8,658
That makes perfect sense. They could just transfer to a several benchmarks then demo the trench.
Mike.
_________
Calidecks is offline
Old 06-21-2017, 11:46 PM   #13
Dirtywhiteboy's Avatar
Rewards Points: 14,562
The water in the ditch was for the slaves to drink too.
Dirtywhiteboy is offline
heavy_d (06-28-2017)
Old 06-22-2017, 12:11 AM   #14
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,268
The Romans used a Groma to get a building square.
http://legioneromana.altervista.org/...ma?language=en
The plumb lines would be dropped into a bucket of on a windy day to steady them.
In years gone by the masons would usually spend the winter cutting the quoin stones etc to shape.
stuart45 is online now
The Following 6 Users Say Thank You to stuart45 For This Useful Post:
fjn (06-22-2017), Fouthgeneration (06-27-2017), Fundi (07-03-2017), Rio (06-30-2017), sparehair (06-22-2017), superseal (06-28-2017)
Old 06-22-2017, 02:14 AM   #15
VinylHanger's Avatar
Rewards Points: 12,894
It is amazing there aren't really any real firm records about how they did some impressive things. They probably figured it was so commonplace and simple why waste time explaining it. Or maybe the real secrets were so secret they couldn't write or draw them or they would die.
VinylHanger is offline
Old 06-22-2017, 10:39 AM   #16
fjn's Avatar
Trade: mason
Just some trivia,the three Pyramids on the Giza Plateau are approximately 13 acres at their bases. They have found they are all about three inches out of square. It is thought that it was not a miscalculation on the builders side,they are all short on their West elevation. That is attributed to the West wind sandblasting away the stone after thousands of years.
fjn is offline
The Following 3 Users Say Thank You to fjn For This Useful Post:
Calidecks (06-22-2017), Rio (06-30-2017), Robie (06-24-2017)
Old 06-28-2017, 08:01 PM   #17
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,725
No power tools, or high wear cutting edges.....
1. Use soft stone.... limestone, sandstone, etc...
2. Use every size of material that has parallel top and bottom planes out side of the veneer face.
3.Remember lime based mortars have near zero tensile strength, thus gravity & mechanical bind is the mason only friends.
Most very large medieval structures are just a stone wall wythes with rubble ( well drained and usually alot of lime, some bond tie cross webbs prehaps...)filled
centers.
almost Every large town had some Roman era work to monkey copy.... See PR China.
Fouthgeneration is offline
Old 06-29-2017, 08:20 PM   #18
Tscarborough's Avatar
Rewards Points: 1,460
1. But they didn't.
2. But they didn't.
3. Don't even use mortar.
How did they level, square, and plumb ancient stone walls-041c-image-peruvian-stonework.jpg
Tscarborough is offline
The Following 7 Users Say Thank You to Tscarborough For This Useful Post:
Calidecks (03-25-2018), cedarboarder (04-14-2018), concretemasonry (03-30-2018), Fundi (07-03-2017), KAP (06-30-2017), Rio (06-30-2017), SmallTownGuy (06-30-2017)
Old 06-29-2017, 09:43 PM   #19
Fire up the BBQ
griz's Avatar
Rewards Points: 1,762
ah hell, the aliens had lasers....
griz is offline
The Following 4 Users Say Thank You to griz For This Useful Post:
A&E Exteriors (04-01-2018), Dirtywhiteboy (06-29-2017), KAP (06-30-2017), sparehair (06-29-2017)
Old 06-30-2017, 09:20 AM   #20
hdavis's Avatar
Rewards Points: 1,076
I think you have to talk about stone walls separately, and there is a lot of variation even in them.
Up here, the stone walls around farms used stacked rocks of whatever size, generally no flat faces. The walls followed the topography. Level didn't come into play at all. These were just stacked, and some farmers were better at it than others. The next step up used some big rocks with at least one flat-ish face as a foundation, and the flat face was more or less leveled. The rest of the wall building was done as before.
That was all due to the materials at hand, and very little was done to the rocks found in the field. There were a bunch of feldspar quarries in this area, so quite a few house foundations used rocks that were a byproduct of working those mines. They were built similarly to the stone walls with a flat rock foundation, with little further concern about level until getting to the top part of the wall.
The more expensive foundations and walls around here used quarried granite, and that was all prepared for use in foundations, walls, whatever. They kept rough level all the way up.
hdavis is offline
fjn (06-30-2017), GC_contractor (03-25-2018)
