How To Build A Sea Wall In A Lake That Is Never Lowered? - Masonry - Contractor Talk
Old 08-27-2014, 02:07 PM   #1
ruskent's Avatar
Trade: Outdoor D/B
Rewards Points: 1,028
I have a client with a lake front property with 125' of frontage. They want to remove the exist native rock wall along the shoreline and replace with a masonry wall. Ideally, we would like to build a cmu or poured concrete wall and veneer with 1" natural veneer stone.
How do I even do this? This lake never gets lowered and the water height stays constant?
Any advice?
Matt
ruskent is offline
Old 08-27-2014, 02:16 PM   #2
Accidental Painter
Driftweed's Avatar
Trade: Who's paying?
Rewards Points: 1,262
Re: How To Build A Sea Wall In A Lake That Is Never Lowered?
Just a guess: reroute the water.
Build a temp damn, pump out work area, build said wall, remove temp damn.
www.callbathdoctor.com
Driftweed is offline
Old 08-27-2014, 02:29 PM   #3
stacker of sticks
jlsconstruction's Avatar
Rewards Points: 590
If talk to the dec before doing anything to see if they will even let you
jlsconstruction is offline
The Following User Says Thank You to jlsconstruction For This Useful Post:
CarpenterSFO (08-27-2014)
Old 08-27-2014, 02:35 PM   #4
skillman's Avatar
Rewards Points: 1,968
Call a sheet pile company .
skillman is offline
The Following 3 Users Say Thank You to skillman For This Useful Post:
dom-mas (08-29-2014), fjn (08-27-2014), slowsol (08-27-2014)
Old 08-27-2014, 02:45 PM   #5
hdavis's Avatar
Rewards Points: 1,136
Better get a knowledgeable engineer. This is going to take some cores down into the bottom to see what you'll have to do to support it in place.
Keep in mind, making that change isn't allowed in many locations, you can only maintain the current sea wall. Around here, approval would require both local and state to agree.
hdavis is offline
tedanderson (08-27-2014)
Old 08-27-2014, 03:08 PM   #6
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 5,824
Can't put in concrete walls around here anymore, has to be natural stone now.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is offline
hdavis (08-27-2014)
Old 08-27-2014, 03:10 PM   #7
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Same, can't have a chain link rubble wall either.
Inner10 is offline
Old 08-27-2014, 05:33 PM   #8
I'm The BOSS
jaydee's Avatar
Trade: builder / remodeler
Rewards Points: 4,733
Better check with the local Departments.
Your going to have so many hoops to jump through.
You'll think you join the circus.
We'll give your home a NEW IMAGE
New Image Construction & Design
New image Construction.com
Facebook
jaydee is offline
Old 08-27-2014, 07:00 PM   #9
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Around here,south end of the big pond (Lake Michigan) if you want a durable wall,you drive sheet piling.
fjn is offline
skillman (08-27-2014)
Old 08-27-2014, 07:05 PM   #10
NCMCarpentry's Avatar
Rewards Points: 860
Let it be. The fish and other aquatic life will thank you.
NCMCarpentry is offline
The Following User Says Thank You to NCMCarpentry For This Useful Post:
aaron_a (08-27-2014)
Old 08-28-2014, 07:51 PM   #11
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 1,436
There is a guy on one of the lakes here that pretty much has that market cornered, there are lots of DEC regulations to abide by, he has them all and a barge with all his equipment on it, he can float right up to the jobsite and start working.
On the ones I have seen the water was dammed off with sandbags and a pump was going to keep water out of the work area.
NYCB is offline
Old 08-29-2014, 12:36 AM   #12
CanCritter's Avatar
Trade: bricklayer/stonemason
Rewards Points: 342
best check with local regs,,,they take screwin around with lakefronts pretty seriously in some parts..big fines$$$
me..l would form and use prescribed concrete mix..concrete will displace the water
up north we wait till its frozen
CanCritter is offline
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 10:56 PM
Marble Wall / Floor Grout Maintenance ? We Fix Houses Tiling 4 08-14-2012 12:00 PM
Couple questions on Double Stud Wall duburban Green Building 10 01-06-2012 09:46 PM
removing a retaining wall Cache Excavation & Site Work 30 07-16-2008 04:57 PM
