Hollowing Out Granite - Masonry - Contractor Talk
Old 09-21-2012, 12:31 PM   #1
stacker's Avatar
Trade: masonry
Rewards Points: 542
okay,my stepson is starting a new business.he will be making headstones with a video screen to show videos of the deceased.
anyway,he asked me about hollowing out part of the stone to make room for the componets,needs to be about 3-4 inches deep.i am thinking i could use a 4 or 7 inch grinder with diamond blade to score a couple inches deep at a time and then use a chisle to remove the granite,then do it again to get the depth needed.am i pissing in the wind or am i on the right track?
stacker is offline
Old 09-21-2012, 01:19 PM   #2
r4r&r's Avatar
Trade: Contractor
Re: Hollowing Out Granite
Not sure what it is, but man there's got to be a better way.
r4r&r is offline
Old 09-21-2012, 04:54 PM   #3
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
A cousin of mine did monuments for a while. Most of the cutting is done in a shop with saws and routers in the $100k area. I mean i guess you could go that route with the grinder, but why not order the monument with the area already cut out?
www.dominionmasonry.ca
dom-mas is offline
Old 09-21-2012, 06:09 PM   #4
stacker's Avatar
Trade: masonry
Rewards Points: 542
i agree.the one i am doing is a prototype for them.i also suggested using concrete and polishing it like a countertop.this way we could form out the area needed.
i started in it this afternoon.i have to say it easier than i thought it would be.i think the only thing that would help would be add water to the diamond blade.i have it about 2 1/2 in deep now.another 1 1/2 to go.
stacker is offline
Old 09-21-2012, 09:03 PM   #5
r4r&r's Avatar
Trade: Contractor
Just talking out my a&& here but what about a two piece? Cut the opening all the way through the front piece and then epoxy or similar to back piece, sand and polish the edge to hide the seam?
r4r&r is offline
Old 09-21-2012, 09:21 PM   #6
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
It would make for a weak piece and you would always see a seam
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 09-21-2012, 09:39 PM   #7
JD3lta's Avatar
Trade: Stone Masonry
Rewards Points: 156
If there's no machine to set/program for the cutting and doing it manually is the only way. I would venture to say that the exposed edge would be the only facet controllable to a degree. If the screen goes into the hollow, the exposed edge would be the only 'finish' reveal. Even if there were a makeshift gauge for depth, the hollow would turn out as different depths. Using a blade to cut grids and tooth'ing out with a chisel in lifts would be efficient and careful.
" What the Eyes See, and the Ears Hear, the Mind Believes. " ~ Lesson from a Friend
JD3lta is offline
Old 09-21-2012, 10:06 PM   #8
General Contractor
Doctor Handyman's Avatar
Rewards Points: 408
How about a diamond core bit? Drill necessary number of cores to the required depth, snap free with a wedge, then clean up with this finger twist bit.
http://www.granitecitytool.com/finger-bit-twist-segment
Doctor Handyman is offline
Old 09-22-2012, 09:49 AM   #9
stacker's Avatar
Trade: masonry
Rewards Points: 542
they are talking about doing something like this.cutting all the way thru and then adding a 1 or 2 in piece to the back.
stacker is offline
Old 09-22-2012, 09:49 AM   #10
stacker's Avatar
Trade: masonry
Rewards Points: 542
love that idea!!
stacker is offline
Old 09-22-2012, 09:54 AM   #11
Every now and then poster
ohiohomedoctor's Avatar
Rewards Points: 3,544
Make it easier and have said step son fit said electronics into said round whole.
Just curios, these solar powered?
ohiohomedoctor is offline
Old 09-22-2012, 09:54 AM   #12
I thinks his idea could work.
Old 09-22-2012, 10:00 AM   #13
BCConstruction's Avatar
Trade: Construction
Rewards Points: 2,394
The head stones I have seen with the screen were all the way through the headstone and they have a cover on the rear. I would say a flowjet/water jet would be your best bet. Would be a very nice clean edge and quick.
The other thing you can do is put a QR code on them so you could scan with smart phone and watch a vid lol
www.bcconstructionllc.com
BCConstruction is offline
Old 09-22-2012, 10:25 AM   #14
That would be alot cheaper and pander to the same audience. Those who would buy a vid tombstone likely have smart phones.
Old 09-22-2012, 10:25 AM   #15
Dang bcc you just destroyed that young man's business plan.
Old 09-22-2012, 11:09 AM   #16
Kent Whitten's Avatar
Rewards Points: 2,040
Waterjet, yes sir. That'll cut it like butter.
SalmonFallsCabinetry.com
Kent Whitten is offline
Old 09-22-2012, 01:04 PM   #17
bernie's Avatar
Trade: gc
Rewards Points: 49
The problem I see with videos and QR codes may seem like a no brainer to some but with modern technology ... who is going to have the equipment 50 years from now to read / see it? Seems like a fad in modern technology that some are jumping on but I doubt it will be around 'forever'. Bet 5 years from now the younger generation are going to say "smart what" when it comes to smart phone as they will be long gone
I sandblast rock, memorials, etc. I think the 'good ole fashioned way' will be better read 50 some years from now.
But, if I'm going to drill / cut something into a rock its usually a core drill and if I want something real detailed it goes to the waterjet guys. Grinders are good but are used to chunk out areas getting something ready for the polishing.
Bernie
bernie is offline
Old 09-23-2012, 04:39 PM   #18
stacker's Avatar
Trade: masonry
Rewards Points: 542
yes these will be solar powered.he needs the four in depth mainly for cooling fan.
i suggested adding audio to the videos by using a radio transmitter like real estate agents use.tune your radio to 99.7....use your smart phone radio and dad talks to you from the grave.a bit morbid,but i think they are on to something.
i got it all cut out to the 4 inch mark,i have about 4 hours in it.
stacker is offline
Old 09-23-2012, 06:27 PM   #19
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Nothing says 'Forever' like a plastic video screen
-Steve
TimelessQuality is offline
The Following User Says Thank You to TimelessQuality For This Useful Post:
Rio (09-23-2012)
Old 09-23-2012, 06:46 PM   #20
r4r&r's Avatar
Trade: Contractor
So you are maxed out at 14 headstones a week at a 56 hr week or 10 in a standard week. Seems like you could order them already done that way.
r4r&r is offline
Custom shower base - granite Charles_cz Tiling 16 01-08-2015 09:34 PM
problems polishing granite bkb0000 Tiling 14 06-05-2013 06:22 AM
Bad Granite Counter Installation - Help please! coveinspiration Kitchens & Baths 52 03-08-2012 06:28 PM
My fault or the granite guy's? john elliott General Discussion 86 01-17-2011 03:48 AM
