Historic Home Masonry Help Needed! - Masonry - Contractor Talk
Old 05-10-2019, 06:41 PM   #1
Thegoodjudge's Avatar
Trade: Gc
Rewards Points: 38
Hello from Brooklyn.
Current project is a gut renovation of an 1850s ballon frame row house. At the cellar level the party walls are brick and the front and rear walls are stone. In certain areas the brick has been painted. The brick is soft and turns to dust if you scrape it. In certain areas the joints are completely dust. Would appreciate some opinions on how to properly treat these 150yr old walls. Ultimately the owner wants to stucco over the walls (no Sheetrock). I am not sure i can get a wire lathe in to these bricks. I was thinking to repoint the open joints with a soft brick mortar (type N ) and then parging the entire walls with type N mortar as a base coat, then adding an acrylic top coat so that the wall can flex. I have read cautionary tales about using Portland on old brick walls. Ive included pictures that illustrate the existing conditions. I would really appreciate some feedback as to best practices.... Ultimately the owner wants to restore and strengthen the wall and have a smooth matte finish as the cellar will be finished and used an an accessory living space. Thank you. Jaime.
Historic Home Masonry Help Needed!-39d3ba9d-24e2-46d2-ad2b-748f7801fcc6.jpeg   Historic Home Masonry Help Needed!-abf98ae2-3c46-4f51-8f94-b56d8d505cc3.jpeg
Thegoodjudge is offline
Old 05-10-2019, 07:42 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Historic Home Masonry Help Needed!
As you say,the brick are soft,hence,I would probably not go with a type N which is a 1 : 1 : 6 mix. I think I'd go with a 1: 2 : 7.5 or 8 mix.
As far as wire lath goes,try some tapcons with fender washers. With the paint on the walls I'd be Leary to parge directly over the bare brick. If dampness down there is a potential problem,go with a synthetic plastic rather than actual wire mesh.
fjn is offline
Fouthgeneration (05-15-2019)
Old 05-10-2019, 08:51 PM   #3
Trade: Gc
Rewards Points: 38
Thanks FJN
Could you tell me what materials your ratios represent? So you would point the missing Joints with this mix and parge the whole wall with it? There is practically no dampness. By synthetic do you mean an acrylic top coat?
Old 05-11-2019, 09:50 AM   #4
fjn's Avatar
Trade: mason
Originally Posted by Thegoodjudge View Post
Thanks FJN
In all mortars in the States the binders are always the first number. Also,if portland cement is one of the binders (lime also is a binder) the portland binder is always first. Hence,the ratio I gave you is 1 part portland, 2 parts hydrated mason lime and between 7.5 -8 parts mason sand. Please note in most applications,the sand is usually 3 times the volume of the sum of binders. With that said,you could go with 9 parts sand,however,the 7.5 or 8 will give you a slightly stronger and more "sticky" mix which is easier to work. Remember to clean all loose defective mortar prior to pointing and dampen the area so the substrate will not suck water from your mix to rapidly. By synthetic,I was thinking in terms of the mesh not the mix. If you say moisture is not problematic,the wire stucco mesh should be fine. I prefer the 3.4 lb. mesh over the 2.5 lb. but either should be fine for you.
fjn is offline
Old 05-12-2019, 04:30 PM   #5
Trade: Gc
Rewards Points: 38
Thanks pal. Should I use the same mix to point new joints in the bricks as well as coating over the entire wall using mesh?
Have any experience in getting paint off the brick? How to best go about that?
Old 05-12-2019, 04:36 PM   #6
fjn's Avatar
Trade: mason
Yes,you can use the same mix for pointing and for the top coating,depends how smooth you want the finish to be. As far as paint removal,if you apply the mesh,you can leave the paint on. Paint removal is always a touch and go process. The paint remover that works on one coating will not necessarily work for another.
I have had pretty good luck with the removers made by a company called Prosoco.
fjn is offline
Old 05-12-2019, 05:51 PM   #7
Tscarborough's Avatar
Rewards Points: 1,460
1850 means lime mortar. Be very careful you don't destroy the foundation walls. whatever you use it needs to be able to breathe and not hold moisture, and it doesn't take much to do damage. I would recommend lime mortar and a lime plaster to finish.
Types S lime, hydrated into lime putty and coarse sand (torpedo or concrete, rather than masonry sand) at a 1-3 ratio for the mortar. for the stucco, the same but with masonry sand and maybe a small amount of Portland, say, 1 lime-1/10 Portland-3 masonry sand.
Tscarborough is offline
Old 05-15-2019, 12:40 AM   #8
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,835
These are "back up brick" and are so underfired they can't take ANY frost action.
Next time secure the wall THEN under mine it.... see bottom of 2cd Photo.
the blown off paint and damaged mortar can most likely be explained by movement of water moisture through the wall, a long term solution would to excavate the wall, water proof and install a drain system...
Adding any type of less pervious materials will slow the flow of the water vapour, most likely causing unintended issues. Any treatment that Doesn't include installing Vapour barriers under and behind the walls will fail.
The masonry Trash from the wall on the floor can give a fair guess on the annual loss of material, if you have knowledge of the time the floor was swept clean....
Don't forget that the paint dust most likely has lead in it, when cleaning up or working around any walls that are suffering paint flaking from this era.
You might consider using a bonding agent to improve the trowel action of the type O or N mortar for plastering, I'd use stainless expanded lathe and fasteners for a few extra decades of service in surface bond coat, after a very, very low pressure washing. (I'd wash alternate zones < 50% for safety) But anything would improve the strength of the ca-ca you have now.
Fouthgeneration is offline
Old 05-15-2019, 08:14 PM   #9
Bonding agent will reduce the permeability, and you do not want to use a cementious mortar anyway, it will, literally, destroy the wall.
Old 05-16-2019, 10:27 AM   #10
fjn's Avatar
Trade: mason
Exactly !
The base of the wall shows it suffered from moisture intrusion,to "camouflage" the wall with plaster whether it be cement,lime or a combo of both is just "masking" the real issue. Depending on the budget,the fix with the longest life cycle is like Fourthgen stated.
Correct details result in improved performance over " treatments" which try to band-aid the frailties of a weak battle plan.
fjn is offline
Fouthgeneration (05-17-2019)
Old 05-17-2019, 03:45 PM   #11
Trade: Masonry
AND, insulate the OUTSIDE of the masonry so the structural brick never freeze-thaw again.....
Applying water "proofing" materials on a porous masonry wall in contact with damp to flooded soil is like building levees on the Mississippi River, you just make the flood deeper upstream and longer down.....
Water vapour can travel vertically over 400'( see trees in Western USA) and miles horizontally......
What YOU have now is a semi-dry brick lined Well...
It isn't the higher moisture % that destroys the old soft brick (just the ones with some clay left to swell up and blow the fired part apart..) It is the freeze expansion that brings an early return to dust.
Cheap Energy = hard baked brick for the mass market....
The Following User Says Thank You to Fouthgeneration For This Useful Post:
fjn (05-17-2019)
Old 06-22-2019, 10:07 PM   #12
Francois's Avatar
Trade: remodel
Rewards Points: 26
It's the neighbour's basement on the other side of that wall. He said the party walls are brick; the outdoor-facing walls are stone. (It's a super-common detail in NYC century-old row housing, especially in Brooklyn; so it was an easy thing to miss in the long paragraph.)
The peeling is from moisture movement, but the source is 150 years' worth of plumbing leaks, mostly.
The front & back walls are buried, and I suppose they might contribute some moisture for the brick walls to wick... except the front yard and back yard are (90% odds) paved, at least near the house, sloping away.
(Basements tend to be dry in these houses, because most of the time, the "ground" floor is actually 2'-4' below grade.)
You may know me as "Frenchie"; but that handle was already taken here.
Francois is offline
Old 06-23-2019, 04:54 AM   #13
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,268
The treatment of damp problems, especially rising damp has been big business in the UK for over 40 years now. Many companies send a surveyor(salesman) round with a damp meter who says ' rising damp mate', 10 grand to strip the walls up 3ft, inject a DPC and replaster with a waterproof render, but it's well worth doing.
There was a book written about the fraud,
https://www.google.co.uk/search?q=th...HVpp4Vn48oGfM:
Others have followed with the theory
https://www.heritage-house.org/damp-...sing-damp.html
Opinion on the subject of rising damp seems to divide the trade, but it's well known that extensive testing is needed (like the carbide test) to determine the cause of dampness in many cases. Often it is caused by things like leaking gutters, leaking pipes, high external ground levels, blocked cavities, poor pointing, condensation to name a few.
I often see crumbling bricks in the wall in the under stairs cupboards where the lack of air flow has caused condensation and salts in the walls migrate to the surface and crystallize damaging the bricks.
stuart45 is offline
Old 06-23-2019, 05:09 AM   #14
John the Builder
SmallTownGuy's Avatar
Rewards Points: 6,114
Rising Damp, the series
SmallTownGuy is offline
The Following 2 Users Say Thank You to SmallTownGuy For This Useful Post:
fjn (06-23-2019), stuart45 (06-23-2019)
Old 06-23-2019, 05:12 AM   #15
stuart45's Avatar
Trade: Brickwork
That brings back some memories.
stuart45 is offline
The Following 2 Users Say Thank You to stuart45 For This Useful Post:
fjn (06-23-2019), SmallTownGuy (06-23-2019)
Old 06-23-2019, 05:18 AM   #16
John the Builder
D'you know, the only woman I really fancied in those days was Greer Garson. Used to see all of her films. Her and Walter Pidgeon. My God, they don't make films like that anymore, mate. Yes, always wanted to marry a woman like that.
Was your wife like Greer Garson?
No...more like Walter Pidgeon...
― Eric Chappell
Old 06-23-2019, 05:26 AM   #17
stuart45's Avatar
Trade: Brickwork
― Eric Chappell
I know a few guys who would have been happy with that.
stuart45 is offline
Old 06-23-2019, 10:57 AM   #18
fjn's Avatar
Trade: mason
― Eric Chappell
The woman I've always searched for is like Ellen from Pillars of the Earth. If one of you boys stumble upon her,send her my way,I'd be most appreciative.
Stuart, you would be the most likely,since the original hailed from your neck of the woods.
fjn is offline
Old 06-25-2019, 08:54 PM   #19
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
For interior walls, support , demo, replace, for foundation walls remove messed up bricks, replace. Use lime mortar.
To finish, brush hard, vacuum, paint with lime paint from limeworks.us. call them.
JBM is offline
Masonry Wall Art Picbrick junie General Discussion 4 07-26-2012 03:51 PM
Historic Brick House (Findlay, Ohio) WerkBrau Excavation & Site Work Picture Post 12 07-02-2012 04:54 PM
Help on Ideas for remodel needed please unhique Architecture & Design 17 06-24-2012 05:06 PM
Masonry Super Needed sdouglas Help Wanted or Looking For Work 4 10-15-2010 11:46 AM
Switching Gears: masonry for the full house? bnentrup Masonry 1 06-06-2009 03:33 PM
