Help With Brick Restoration On Townhouse Built In 1930 - Masonry - Contractor Talk
Old 07-25-2019, 09:41 PM   #1
Melpa214's Avatar
Trade: General Contracting
Hello all, I want to start brick restoration on my townhouse in NYC which was built in 1930. I was hoping to get some advice on the right procedure and which products to use to get the job done right. I have a few of my concerns listed below.
The house was repointed sometime in the 90s. The new pointing looks like a straight Portland/sand mortar mix. There are a few areas where the original mortar is exposed and it looks like a Portland, lime, and sand mix. (I have pictures attached). Can anyone give me an idea of what kind of mortar was originally used by looking at the pictures?
Another concern I have is that there is alot of discoloration on the brick face. It could be because of a acid cleaner or just age. What is the best method/products to clean this type of brick?
And last, I need to complete some spot pointing and I would like to color match the new mortar joints to the old ones. The mortar is much darker and discolored in some areas since its aged for 30 years or so. The mild acid cleaner I tested did not remove this staining. Should I clean the mortar then color match the new mortar or should I just color match to the existing mortar.
Thanks for taking the time to look over my post. Let me know if you have any questions.
Help with brick restoration on townhouse built in 1930-screenshot_20190725-224216_gallery_1564109045418.jpg   Help with brick restoration on townhouse built in 1930-screenshot_20190725-224225_gallery_1564109060265.jpg   Help with brick restoration on townhouse built in 1930-screenshot_20190725-224235_gallery_1564109073449.jpg   Help with brick restoration on townhouse built in 1930-screenshot_20190725-224247_gallery_1564109089500.jpg   Help with brick restoration on townhouse built in 1930-screenshot_20190725-224257_gallery_1564109102663.jpg
Help with brick restoration on townhouse built in 1930-screenshot_20190725-224308_gallery_1564109142176.jpg   Help with brick restoration on townhouse built in 1930-screenshot_20190725-224318_gallery_1564109158111.jpg   Help with brick restoration on townhouse built in 1930-screenshot_20190725-224350_gallery_1564109169824.jpg
Melpa214 is offline
Old 07-26-2019, 01:23 AM   #2
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,248
Re: Help With Brick Restoration On Townhouse Built In 1930
The 30's was a time when OPC was being more commonly added to lime mortar before it eventually took over from lime. It's possible the original was something like a 1/2/9 OPC/lime/sand mix.
Put some of the mortar in some acid and this will leave you with a sample of the sand for a colour match.
Your metal lintels look like they are expanding with rust.
The joints don't look like they were raked out properly before the last repoint.
stuart45 is offline
The Following User Says Thank You to stuart45 For This Useful Post:
fjn (07-26-2019)
Old 07-26-2019, 11:13 AM   #3
Windycity's Avatar
Trade: Masonry
Rewards Points: 8,446
I highly doubt that it was pointed with straight Portland and sand, that wouldn’t be very nice to work (tuckpoint) with
From the looks of it they used mason cement (premixed portland and lime) and bank sand
If i was trying to match the 90’s pointing in your picture i would use brixment type n and bank sand.....that would match it almost perfect with color and consistency
Windycity is online now
Old 07-26-2019, 11:49 AM   #4
stuart45's Avatar
Trade: Brickwork
You also need someone who has never used a pointing trowel before to match that style.
My 5 year old grandson would have been OK last year, but he's got better at it now.
stuart45 is offline
fjn (07-26-2019)
Old 07-26-2019, 12:06 PM   #5
Melpa214's Avatar
Yeah I know, theres alot of rushed work here in NYC. Thanks for the help stuart45!
Melpa214 is offline
Old 07-26-2019, 01:23 PM   #6
Melpa214's Avatar
Thanks for the reply windycity! I'm trying to get a hold of some bank sand here in the ny/nj area but I cant find anyone that carrys it. Do you know where I can buy some?
Update: I found someone with bank run sand, is that the same?
Melpa214 is offline
Old 07-26-2019, 03:51 PM   #7
Windycity's Avatar
Trade: Masonry
I wouldnt worry too much about the term but bank sand is real fine with hardly any aggregate in it....almost like sugar with no granulars
Sand is sand, but you need to try to match the texture and from the looks of the previous tuck pointing it looks like the sand is real smooth
The Following User Says Thank You to Windycity For This Useful Post:
fjn (07-26-2019)
Old 07-26-2019, 08:43 PM   #8
JBM's Avatar
Trade: Masonry
Rewards Points: 10,920
What were the years asbestos was used in mortar?
JBM is offline
Old 07-27-2019, 12:58 AM   #9
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,403
Not much asbestos used in straight mortars.
More in caulks, plasters and stucco finishes, water proofing tars.....
Fouthgeneration is offline
The Following User Says Thank You to Fouthgeneration For This Useful Post:
JBM (07-27-2019)
