Haydite Building Question - Page 2 - Masonry - Contractor Talk
Old 04-19-2019, 07:00 PM   #21
hdavis's Avatar
Rewards Points: 2,494
Re: Haydite Building Question
So Cal have guys that do this as their bread and butter.
You can't really assess the situation just from that picture, only guess at what is happening. I'm not convinced the stucco is the underlying problem, there could be cracking above the lintels, for instance. There could be intrusion at the roof-wall juncture, you can't really say.
The same thing happens with getting moisture in a wood framed wall and plaster. Plaster gets moist, and it softens and delaminates.
Up here with exposure to salt in the winter, you'd seal the final surface with saltgard.
hdavis is offline
Old 04-19-2019, 07:23 PM   #22
hdavis's Avatar
Originally Posted by fjn View Post
Applying Herculean measures to that building is like putting perfume on a pig. Aint going to do much good. If the designer did not think enough of his design to do it correctly.........run Forrest run !
I'm not convinced it was initially done "wrong". Stucco can be used to waterproof foundations. It can also be used on a 1 story dry stack in lieu of grout.
I personally like it, BUT it's very picky about how much water, additives, exact mixing time (mortar mixer only), temp and shade/sunlight, finishing technique, etc.
If you don't want fine cracks, you aren't doing a smooth finish with a steel trowel.
Even being careful, there can be microchannels that allow some moisture into limited parts of the stucco. That's part if the reason sealing and keeping it sealed as part of maintenance is important. More work than vinyl siding, less work than wood siding.
Around here, I can order in Surface Bonding Cement. That's a fibered one coat stucco mix. By the time you add in acrylic fortified and some colorant, it about $40 per bag (50 lb?). Application thickness is 1/8 to 1/4".
I'd definitely take that stucco rehab on, I've dealt with way worse.
hdavis is offline
Old 04-19-2019, 07:42 PM   #23
fjn's Avatar
Trade: mason
Rewards Points: 11,202
The two basic rules of construction are,if you want to eliminate problems with flat roofs,eliminate the flat roof. If you want to eliminate problems with parapet walls.... This building has that and more going on.Who knows,the water could be a result of parapets without through the wall flashing,no cant strip at interface of roof and wall etc.
If it is in fact the stucco,the elastomeric coating coating made by Parex / LaHabre would do the trick. But as the old saying goes "one has to pick their battles wisely. I'd look for an easier fish to fry. Once you touch it,you own it.
fjn is offline
The Following 2 Users Say Thank You to fjn For This Useful Post:
hdavis (04-20-2019), Tscarborough (04-21-2019)
Building a pole barn/garage question? Dave in Pa Framing 3 01-10-2014 07:46 AM
Question about building corner cabinet deeper for Staggered Heights Ridicules Finish Carpentry 6 11-14-2013 06:51 PM
foundation repair question ctcarpenter Masonry 26 06-25-2012 05:25 PM
Com Bus groud to 120V powered box Question Richard_N_S Low Voltage 0 06-14-2012 11:58 AM
DuraLife Siesta Collection Question? (CorrectDeck) Max10 Decks & Fencing 7 06-13-2012 08:50 PM
