Garage Floor Pad - Masonry - Contractor Talk
Garage Floor Pad
Old 04-04-2015, 04:10 PM   #1
JRWMASONRY's Avatar
Rewards Points: 24
Garage Floor Pad
Planning on a 48'x32' pad, with 18"x12" haunch around perimeter. Structure will be 2x6 framed with 2nd floor living area. Question I have is, the ground has roughly 4" of top soil then is shale. Not sure how far down the shale. No soil tests etc.. any ideas or advice from someone who has excavated this type of ground. I also plan on digging for a basement in a yr or so using 12" block then brick veneer from above grade.
JRWMASONRY is offline
Old 04-04-2015, 04:49 PM   #2
S.U.M's Avatar
Trade: Brick/Stone Mason
Rewards Points: 1,286
Re: Garage Floor Pad
An intro and a bit more info is required. Where are you located?
S.U.M is offline
Old 04-04-2015, 04:56 PM   #3
JRWMASONRY's Avatar
Rewards Points: 24
My name is Jesse I have 5acre property just out side Watertown N.Y.. as for more info, I will be building this structure for temporary living space while I build a house on the same lot. Property is completely flat and mostly cleared.
Old 04-04-2015, 05:21 PM   #4
S.U.M's Avatar
Check with local building codes, not from that area, good luck.
S.U.M is offline
Old 04-04-2015, 05:22 PM   #5
JRWMASONRY's Avatar
Rewards Points: 24
Thanks
Old 04-04-2015, 06:01 PM   #6
Dave in Pa's Avatar
Trade: restoration/remodeling
Rewards Points: 1,272
Not sure about the local codes in your area, BUT, in my area you need to go below frost line for every footing, no matter what! Houses/garages/decks/stairs/etc.
Dave in Pa is offline
Old 04-04-2015, 06:13 PM   #7
S.U.M's Avatar
Here in Toronto we go 4' minimum, image it would be the same more or less in NY.
S.U.M is offline
Old 04-04-2015, 06:52 PM   #8
JRWMASONRY's Avatar
Rewards Points: 24
Even for a floating pad? And yes the frost line is at 4' here, but after this winter, it might as well be at 6'.
Old 04-04-2015, 06:58 PM   #9
JRWMASONRY's Avatar
Rewards Points: 24
Ive built a lot of garages with reinforced haunchs and a slab thickness of 6". Never have any movement or cracks other than in the saw cuts where I want it to crack. Im mainly interested in information about the difficulty I may face with this shale. Expansion ,shear strength, load capacity....
Old 04-04-2015, 10:11 PM   #10
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 6,250
Soils are a complex issue. In subarctic Alaska, shale was sometimes considered safe to build on and ignore frost depth by my engineer.
Golden view is offline
Old 04-04-2015, 11:09 PM   #11
NYCB's Avatar
Trade: Concrete/Masonry
Rewards Points: 400
Shale usually means water, you should get a perc test done.
That said, are you trying to make it a budget build? Slab on grade is generally a no-go for building on in our area. Even mono-pours are tricky and I don't really trust them.
If you are just building a shack to live in while you build a house then call it a hunting camp and do whatever works, just scrape back the top soil, bring in some loads of crusher run and roll it, then pour, build your walls, slap on some trusses and dry it all in.
NYCB is online now
Old 04-04-2015, 11:37 PM   #12
Eater of sins.
ScipioAfricanus's Avatar
Rewards Points: 1,788
I think the OP may be talking about a "frost protected shallow foundation". This is an idea that is gaining a lot of traction here in the states and that small country on our north border.
The idea is really intriguing, and would save just tons of cash in the build. It has been the standard construction technique in Norway (I think) for about 40 years.
It is basically slab-on-grade foundation with buried foam insulation in strategic areas. But you guys know that.
Oh wait, I see it is in a garage, probably not heated all year round so I think this frost protected would not work so well.
Andy.
ScipioAfricanus is offline
Old 04-04-2015, 11:40 PM   #13
edward trowelhands
Trade: Diplomat
Andy.
I've done a few. The concept is frost heave happens if you have ALL 3 simultaneously:
freezing soil temps at foundation
moisture
frost susceptible soil
for safety and redundency, FPSFs eliminate all 3.
ScipioAfricanus (04-05-2015)
Old 04-05-2015, 12:27 AM   #14
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 8,281
"Floating" slab = NO TOILETS.
How about a split level house, build the half basement level first with a full bath, kitchenette, bedroom.
I consider 14" CMUs if built a veneered or all masonry house today, room for 3" of insulation and an air cavity, fewer grout cells....
Fouthgeneration is offline
Old 04-05-2015, 12:56 AM   #15
duburban's Avatar
Trade: building
Rewards Points: 1,752
I disagree. Floating slabs (properly insulated/designed) are good to go for whatever you want.
OP. seek out an energy geek in your area and you guys can run the numbers together to make sure your situation will run.
duburban is offline
Old 04-05-2015, 06:15 AM   #16
JRWMASONRY's Avatar
Rewards Points: 24
Thanks guys for the info
Old 04-05-2015, 06:46 AM   #17
JRWMASONRY's Avatar
Rewards Points: 24
I plan insulating the bottom and sides, in floor heat, boiler system.
Old 04-05-2015, 12:54 PM   #18
wazez's Avatar
Trade: masonry
Rewards Points: 774
I see your a mason also...block are cheap put in a proper stem wall to your frost line and be done with it.
wazez is offline
Old 04-05-2015, 01:03 PM   #19
JRWMASONRY's Avatar
Rewards Points: 24
I think , to not have any problems in the future I will do that.
Old 04-05-2015, 02:03 PM   #20
Eater of sins.
I think, to not have any problems in the future, you should consult with someone that knows more about this than you do. Do a proper survey of the soil conditions that you have and design the foundation system of your radiant/hydronic floor heated GARAGE properly.
Andy.
Ballpark cost for garage addition? Moze Construction 7 01-10-2015 03:21 PM
Garage conversion thoughts MarkJames Remodeling 6 02-24-2013 09:17 AM
Garage Floor Epoxy We Fix Houses Painting & Finish Work 9 12-31-2012 11:37 AM
Fire Rating of garage walls, exterior siding Richard_N_S General Discussion 9 12-12-2012 09:58 PM
Below grade attached garage, concerns new home owner Construction 1 09-06-2010 08:14 AM
