Flashing Question - Masonry - Contractor Talk
Flashing Question
Old 11-19-2019, 06:43 AM   #1
jsprplc2006's Avatar
Trade: Masonry
Rewards Points: 18
Flashing Question
I have a question about a flashing that goes on the side of a brick veneer wall, since I can't seem to find any info on it anywhere.
I've attached a pic of what the prints say; anyone seen these, or know what another name for them is so I can buy some??
jsprplc2006 is offline
Old 11-19-2019, 05:30 PM   #2
fjn's Avatar
Trade: mason
Rewards Points: 11,202
Re: Flashing Question
I'll try to 'guess' what is meant regarding flashing. When I think of sprung mental flashing,I think of a reglet cut in masonry with a metal folded a tad more than 45 degrees pushed into that kerf. Better check with architect to be positive.
fjn is offline
Old 11-19-2019, 05:33 PM   #3
Fouthgeneration's Avatar
Trade: Masonry
Rewards Points: 9,839
The Cavity Behind the tin needs vents to let out vapour, and weeps/ vent intakes to let liquid water leave the rainscreen.........which is WHERE?
Where is the "RED line" for the rain screen?
Wood studs or sheet metal studs, jamb?
I'd want a PT 2x X board to fill 95% of the cavity @ jambs and ends, but I didn't Low ball this building either. It cuts down on vermin doorways....and wall whistles.
CMUs need to be mostly DRY to survive repeated freezing/ thaw cycles, no puddles or sprinkler systems wetting them down constantly...
Add the elevation view of the jamb please/ opening section through Lintel/header ....down to grade, include horizontal flashing/dampproof flashing
You will need a MASTER tin-bender to make that front wrap look good everywhere and a diamond grinder:What happen when window or CMUs aren't perfectly plumb in all FOUR points NEEDED for this detail to be unwrinkled.....
.make the piece 2-4" over width rip it, and install with a lap fasten to the cavity filler board.
Fouthgeneration is offline
