Fireplace Draft - Masonry - Contractor Talk
Fireplace Draft
Old 11-30-2010, 09:41 AM   #1
ace7682's Avatar
Trade: Remodeling Specialist
Fireplace Draft
I have a client that is looking to close off the damper and make the flue weather proof put wants to leave the firebox open to place flowers or candels in.
Is this possiple? If so what is the best method?
ace7682 is offline
Old 11-30-2010, 11:25 AM   #2
Fire up the BBQ
griz's Avatar
Rewards Points: 1,072
Re: Fireplace Draft
Try these:
http://www.amazon.com/s/?ie=UTF8&key...l_72snnhzcf7_b
griz is online now
ace7682 (12-01-2010)
Old 12-01-2010, 06:23 AM   #3
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Re: Fireplace Draft
Never used one, but seems like a damn good idea to me. You don't know how many 17 and 1800 homes I work on with a big wad of nasty old fiberglass jambed up the throat.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
Old 12-01-2010, 08:21 AM   #4
ace7682's Avatar
Re: Fireplace Draft
yeah wish I'd have though of the ballon Idea!
"Remember, What your head doesn't figure out your ass will pay for!!!!"
ace7682 is offline
Old 12-01-2010, 10:16 PM   #5
Rockmonster's Avatar
Trade: Masonry
Rewards Points: 5,494
Re: Fireplace Draft
Stick a Lyemance damper on top.....if there is a flue tile protruding up top, this is an easy fix, and it stops everything up top; rain, bats, birds, whatever.
Rockmonster is offline
The Following 3 Users Say Thank You to Rockmonster For This Useful Post:
ace7682 (12-02-2010), jvcstone (12-05-2010), Tscarborough (12-01-2010)
Old 12-01-2010, 10:36 PM   #6
Working
Cole82's Avatar
Rewards Points: 2,276
Re: Fireplace Draft
Yep what Rockmonster said.
There are a couple different styles.
The boss of awesome
Cole82 is offline
The Following User Says Thank You to Cole82 For This Useful Post:
ace7682 (12-05-2010)
Old 12-02-2010, 08:18 PM   #7
ace7682's Avatar
Re: Fireplace Draft
cool, this is what I'm looking for!!!
ace7682 is offline
Old 12-05-2010, 10:01 AM   #8
ace7682's Avatar
Re: Fireplace Draft
where can I find the caps you have pictured?,,,thanks for your input and time on this
ace7682 is offline
Old 12-05-2010, 10:12 AM   #9
ace7682's Avatar
Re: Fireplace Draft
never mind wasn't thinking , found a link and am going over it with the client, thanks again to all who posted!
ace7682 is offline
Old 12-05-2010, 10:16 AM   #10
Working
Cole82's Avatar
Re: Fireplace Draft
The masonry supply that sells fire bricks can get them as well as the custum sheet metal place that makes chimeny caps. Don't have to buy online, that's here atleast.
Cole
The boss of awesome
Cole82 is offline
Old 12-05-2010, 03:04 PM   #11
jvcstone's Avatar
Trade: Masonry / architectural stone carving
Rewards Points: 250
Re: Fireplace Draft
One thing to remember if you use a flue top damper(for a working fireplace)-- the damper it's self will restrict the flue size, and in some cases makes the flue section area too small for a good draw. The solution I came up with on my rumfords was to use the next size larger damper, and cut a piece of the next size larger flue to fit snug over the chimney flues at the top.--problem solved.
John VanCamp
www.jvcstoneworks.com
jvcstone is offline
Old 12-05-2010, 03:22 PM   #12
Tscarborough's Avatar
Rewards Points: 1,460
Re: Fireplace Draft
That works and is also the solution to having a spark arrestor when you use a Top of Flue Damper. Required in many localities.
Tscarborough is offline
Tags
chimney , damper , draft , fireplace , flue
Heating new Family Room w/ gas fireplace? Slowtrawl HVAC 56 06-20-2010 05:50 AM
Smoking fireplace artisanstone Masonry 13 05-02-2010 07:43 PM
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
Masonry chimney on new EPA fireplace? GregWCIL Masonry 8 10-28-2008 08:51 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
