Finishing A Strip Veneer Stone - Masonry - Contractor Talk
Old 05-16-2015, 05:28 AM   #1
CJKarl's Avatar
Trade: Masonry
Rewards Points: 3,926
Here's what it takes to fit a stone in this veneer.
There's Always A Market For Quality
http://www.kaufmannmasonry.com/
CJKarl is offline
The Following 5 Users Say Thank You to CJKarl For This Useful Post:
fjn (05-16-2015), Fundi (05-23-2015), Gordon Forsyth (05-18-2015), superseal (05-16-2015), Tscarborough (05-16-2015)
Old 05-16-2015, 05:29 AM   #2
CJKarl's Avatar
Trade: Masonry
Re: Finishing A Strip Veneer Stone
In the 1st couple pics. The stone has been cut with a demo saw.
CJKarl is offline
The Following User Says Thank You to CJKarl For This Useful Post:
Gordon Forsyth (05-20-2015)
Old 05-16-2015, 06:00 AM   #3
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
How do you like the fiberglass vs wood on the dummy hammer?
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 05-16-2015, 02:59 PM   #4
JBM's Avatar
Trade: Masonry
Rewards Points: 10,850
Are you cutting all the rocks like that?
JBM is offline
Old 05-16-2015, 05:21 PM   #5
mason contractors
Fancis Casini's Avatar
Trade: mason contractor
Rewards Points: 1,109
thats about what I suspected.....not what I'm used to. I guess if it works and they pay then ok...but give me the bigger ones and the 6lb striking hammer with a pail of points/tracers/and pitching tools....oh and dont leave out the stone hammers!
Fancis Casini is offline
Old 05-16-2015, 05:42 PM   #6
mason contractors
Karl try using a 4'' by 6'' x 3/8'' angle iron as a back up edge to cut against....I 've done it for years esp on stagings.. cutting stone. For those thin flat stones it'll save oodles of time/dust/gas. Yes occasionally a break will happen but once you get used to it theres nothing better. As a youngster I'd hold the irregular backs of the stone on the edge of the steel or another rock while the old man hit the face.... adjusting it as he moved up the line. Then they came out with the hydraulic slpitters which auto adjust to the countours!
Old 05-16-2015, 05:56 PM   #7
CJKarl's Avatar
Trade: Masonry
Fiberglass lasts longer, but you can't hit hard with it. Doesn't absorb any shock.
CJKarl is offline
Old 05-16-2015, 05:58 PM   #8
CJKarl's Avatar
Trade: Masonry
Yes, all the stones are generally cut the same.. corners are a bit more hand work.
CJKarl is offline
Old 05-16-2015, 09:15 PM   #9
Nick520's Avatar
Trade: Mason
Rewards Points: 514
How would you even go about
Pricing a job with that kind of time being eaten up
Nick520 is offline
Old 05-16-2015, 10:16 PM   #10
heavyc's Avatar
Trade: masonry
Rewards Points: 945
My guess would be if you have to ask
You can't afford it.
About like shopping on Rodeo Drive.
Got to love what I call money stupid clients. Blank check jobs gotta be nice as long as they are signed before work
begins.
heavyc is offline
Old 05-17-2015, 05:13 AM   #11
CJKarl's Avatar
Trade: Masonry
This project is by the hour.
CJKarl is offline
Old 05-17-2015, 12:40 PM   #12
Smarter than the brick...
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
Dunno about the dummy hammer but I love fiberglass handled brick hammers, only problem I have with them is that the heads seem to fall off too easily. Wooden handles give me callouses to the point of being painful.
Kniggit is offline
Old 05-17-2015, 07:48 PM   #13
heavyc's Avatar
Trade: masonry
Rewards Points: 945
We call them signed blank check jobs
heavyc is offline
Old 05-17-2015, 07:50 PM   #14
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Not quite sure what you're doing in that 2nd and 3rd pic....is that the top bed that you're trying to get flat? If you're using the grinder for the beds as much as it looks in the 5th and 6th pics why not buy saw cut stuff and just pitch the face back a bit to get a more natural looking bed?
Is that a wood chisel I see in the 1st pic? Using as a scriber?
www.dominionmasonry.ca
dom-mas is offline
Old 05-17-2015, 08:40 PM   #15
Kniggit's Avatar
Trade: Masonry
Rewards Points: 561
I thought he was just knocking the back off of the stone in pic 2 & 3?
Kniggit is offline
The Following User Says Thank You to Kniggit For This Useful Post:
dom-mas (05-18-2015)
Old 05-17-2015, 09:16 PM   #16
CJKarl's Avatar
Trade: Masonry
I sometimes saw the stone length wise, but it's actually faster to score and snap. Ripping deeply through the stone can get slow.
CJKarl is offline
Kniggit (05-18-2015)
Old 05-17-2015, 09:17 PM   #17
CJKarl's Avatar
Trade: Masonry
The wood chisel is used to split some of the bluestone shims we're using.
CJKarl is offline
Old 05-18-2015, 06:17 AM   #18
mason contractors
the old flagstone patios [slate] is great for the shims] comes in green/grey and red....of course they can be sharp so some dulling is sometimes needed. saves alot of looking and stone lift during insertion esp in the heat!
Old 05-18-2015, 07:18 AM   #19
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
But look at the tapered cuts. Usually you would angle the heads back so you can get super tight joints. The cut looks to angle back like it's the face, but it also looks like it angles in like it's a bed?
Oh well, end product looks awesome
dom-mas is offline
Old 05-18-2015, 05:07 PM   #20
Accent Masonry LLC
Gordon Forsyth's Avatar
Trade: Masonry
Rewards Points: 330
That looks like fun
http://www.accentmasonryllc.co
Gordon Forsyth is offline
Chicago Cut Brick Veneer Installation sokoleoko Masonry Picture Post 6 05-28-2015 02:50 AM
Stone veneer & new apron climb.on Masonry 8 05-08-2013 10:06 PM
Flashing a stone veneer chimney. PatChap Roofing 7 04-02-2013 12:19 PM
Natural Stone Veneer Around Windows euphoricme Masonry 17 06-17-2012 08:49 PM
Switch box in thin stone veneer. RZB Electrical 9 12-15-2010 10:47 PM
