Filling In Around Toilet For Flange. - Masonry - Contractor Talk
Old 05-20-2019, 05:17 PM   #1
Box Builder
Morning Wood's Avatar
Rewards Points: 10,366
We are replacing a toilet on a job. The toilet was tiled in place. The plumber broke it out and I need to bring the space up level with existing tile so they can glue in new flange and fasten it to the floor. Itís about 1 1/4Ē deep. Whatís a safe product to use for doing this? Iím more worried about screwing tapcons into the floor for the flange when they attach it. There is concrete underneath. Thanks, Nick.
Morning Wood is offline
Old 05-20-2019, 05:26 PM   #2
MarkJames's Avatar
Rewards Points: 18,835
Re: Filling In Around Toilet For Flange.
I would go with CementAll.
MarkJames is online now
Old 05-20-2019, 05:51 PM   #3
fjn's Avatar
Trade: mason
Rewards Points: 11,202
This video may help.
fjn is offline
Old 05-20-2019, 05:55 PM   #4
MarkJames's Avatar
It sounds like he's redoing it, not stacking spacers, etc.
Old 05-20-2019, 05:58 PM   #5
fjn's Avatar
Trade: mason
Ah,you may be correct,was not exactly sure from the description.
fjn is offline
Old 05-20-2019, 06:27 PM   #6
Box Builder
It is new plumbing but there is the footprint of the old 5 gallon flush toilet that needs to be brought up level with existing floor. It wonít look pretty but it will work. Those are the qualifications.
Old 05-20-2019, 06:31 PM   #7
fjn's Avatar
Trade: mason
If it is new plumbing,the flange gets set on TOP of the tile,not sub floor.
fjn is offline
Old 05-20-2019, 06:36 PM   #8
MarkJames's Avatar
Ok, but what product would you suggest to fill that toilet-shaped footprint of 1 1/4" depth?
Old 05-20-2019, 06:42 PM   #9
fjn's Avatar
Trade: mason
I would brush on a bonding agent and fill in the footprint (if it is contained on all edges) with a product like this or similar.
https://www.tools4flooring.com/ardex...waAsOcEALw_wcB
fjn is offline
SmallTownGuy (05-21-2019)
Old 05-20-2019, 06:42 PM   #10
Box Builder
The product I use to fill this is going to be the finished floor. Client dictated quality of fix. Tile is from the 30ís.
I donít have a better pic. Most of the time the toilet didnít work at all so this is still an improvement.
Old 05-20-2019, 07:29 PM   #11
tjbnwi's Avatar
Rewards Points: 3,950
Get a sheet of Hardie backer, use a diamond blade on a grinder to cut and shape the backer to fit. Mix up some rapid set mortar, use a 1/4" notch trowel to burn in and tooth the backer, burn in the floor set/work in the first piece, trowel the back of the second piece, burn in the first piece, set second piece. Using a 1/4 x 1/4 trowel should give you 1/8 between each layer for a total of 1-1/4".
To burn in, is to apply a thin tight coat of mortar with the smooth side of the trowel to the substrate.
It is easier to tooth the backer piece than try to tooth the mortar on the floor in such a tight area.
tjbnwi is online now
Seven-Delta-FortyOne (05-20-2019)
Old 05-20-2019, 09:06 PM   #12
Caleb1989's Avatar
Rewards Points: 394
Make a template, cut Saltillo tile and set in a thick bed of mortar.
Grout with the same mortar. Use a repair flange that has a rubber ring that tightens up in the inside of existing flange and your ready for a new toilet.
Caleb1989 is offline
Old 05-21-2019, 02:25 PM   #13
Renaissance Man
superseal's Avatar
Rewards Points: 5,846
Rapid set with fiber and bond coat...I'm done in under 5min.
supersealconstruction.com
superseal is offline
The Following User Says Thank You to superseal For This Useful Post:
stuart45 (05-21-2019)
Old 05-21-2019, 06:07 PM   #14
tjbnwi's Avatar
It will take you longer than 5 minutes to get to this job
superseal (05-21-2019)
Old 05-21-2019, 06:16 PM   #15
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 5,076
Then you gotta clean the bucket...
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
Morning Wood (05-21-2019), superseal (05-21-2019)
Old 05-21-2019, 08:55 PM   #16
rescraft's Avatar
Trade: residential remodeling/construction
Rewards Points: 1,863
Tell the homeowners to do this"
https://i.imgur.com/dJJixGd.jpg
rescraft is offline
The Following 2 Users Say Thank You to rescraft For This Useful Post:
KAP (05-21-2019), META (05-27-2019)
Old 05-21-2019, 09:34 PM   #17
Renaissance Man
superseal's Avatar
Add some oxide pigment too and blend that sucker in...better add another minute to that 5 however
Old 05-21-2019, 09:53 PM   #18
KAP's Avatar
Trade: Custom
Rewards Points: 39,532
That's the time allowed for bending over...
KAP is offline
Old 05-22-2019, 01:40 AM   #19
stuart45's Avatar
Trade: Brickwork
Rewards Points: 1,268
If the jobs in San Francisco add another 5 to check around before bending over.
stuart45 is offline
The Following 2 Users Say Thank You to stuart45 For This Useful Post:
KAP (05-22-2019), superseal (05-23-2019)
Subfloor sag under toilet George_Pag General Discussion 18 12-20-2018 08:47 PM
Toilet dollys platinumLLC Tools & Equipment 17 01-16-2015 08:25 PM
Is Access to a Toilet a ĎBasic Human Rightí?: (This isn't a joke!) MAULEMALL Off Topic (Non Trade) 50 05-28-2012 02:42 PM
Easy, toilet replacement fireguy Plumbing 21 05-12-2011 08:03 AM
Toilet Challenge Vermaraj Plumbing 40 11-09-2007 09:04 PM
