Exterior Foundation Water Protection? - Masonry - Contractor Talk
Old 04-30-2015, 11:19 PM   #1
skip_johnson's Avatar
Rewards Points: 66
Hi everyone, I'm running a larger pipe/down spout repair job on an old house with a granite stone foundation. The pipe repair work is straight forward and when I've done it in the past we would just cover them back up, pour slabs and be on our way. This time though I thought it might be worthwhile to check out exterior foundation sealant products while everything is exposed for some extra protection.
Given the type of foundation it is what would be a recommended product? Do the rocks have to be power washed in order for the sealant to bond to them? Would applying it make much of a difference in that it's not cinder block? Thanks for reading.
-Skip
skip_johnson is offline
Old 04-30-2015, 11:24 PM   #2
Rewards Points: 66
Re: Exterior Foundation Water Protection?
Actually, let me rephrase- is there a heavier duty, tar-based product that will adhere to dirty surfaces? Power washing is not an option.
Old 04-30-2015, 11:57 PM   #3
I'm a Mac
Chris Johnson's Avatar
Trade: ICF Construction
Rewards Points: 4,254
No the surface must be clean and dry from any foreign objects
Stiff broom and wire brushes perhaps to clean it?
Chris
Chris Johnson is offline
Old 05-01-2015, 09:35 PM   #4
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
Compressed air can work almost as well as water. Wire brush then air. But it takes A LOT of air
www.dominionmasonry.ca
dom-mas is offline
Old 05-02-2015, 12:17 AM   #5
Love me some Concrete
brhokel606's Avatar
Rewards Points: 4,109
I have never power washed because it creates such a mess in the bottom and takes forever to dry.
We use wire brushes attached to recip saws, then like Dom-mas said, hit it with air and works perfect. Not a clean job for the guys in the hole but better than running a dry grinder!
I know I'm crazy...I love concrete
brhokel606 is offline
Old 05-02-2015, 12:19 AM   #6
brhokel606's Avatar
Or use a larger wire cup brush on a grinder too
Old 05-02-2015, 06:58 AM   #7
JBM's Avatar
Trade: Masonry
Rewards Points: 10,448
I think some sort of rubber that you can roll out and place over the wall would be better then trying to get some gobbly gook to stick.
JBM is online now
Old 05-02-2015, 10:17 AM   #8
stonecutter's Avatar
Trade: Stonemasonry
Rewards Points: 2,356
If the surface has dirt on it, nothing will adhere to it. Once you get it clean, you have some options.
www.thewoodfiredenthusiast.com
stonecutter is offline
Old 05-02-2015, 01:52 PM   #9
dom-mas's Avatar
Trade: masonry
Rewards Points: 626
You could use platon also, or any other dimpled membrane
dom-mas is offline
The Following User Says Thank You to dom-mas For This Useful Post:
fjn (05-05-2015)
Old 05-05-2015, 10:32 AM   #10
fjn's Avatar
Trade: mason
Rewards Points: 10,952
I'M 100 % with dom on that. I have been using Platon since 2005 and have been thoroughly pleased with the results.
fjn is offline
3" PVC pipe dumpig water into sump pump - what is it? ggsubs Plumbing 9 06-06-2013 07:17 PM
Icf water proofing jeradlittle General Discussion 8 10-10-2012 07:25 PM
Ice and Water Shield over XPS Lakesidex General Discussion 8 08-15-2012 11:17 PM
Comments on replacing tank water heater with tankless CRIMPS Plumbing 3 12-04-2009 11:54 PM
instant hot water mowpar Plumbing 6 03-23-2008 09:56 PM
